Old 07-15-2012, 04:34 AM   #1
babuja OP
babuja's Avatar
Oddometer: 353
XR 650R: Ultimate Jetting Instruction for Dummies
Hi,
after much reading i would like to start a thread for dummies and noobies like me for proper jetting the XR 650 R.
Mode: XR 650R 07 DK or U model (not sure)
Exhaust: Pro-Circuit complete exhaust
Inlet: Xronly Side Panel cutout
Altitude: Sea level < 1000feet
Temperature: 75-95ºF
Humidity: 70-90% [Angola]
Pilot: 68s
Need: B53E
Where should I start with?
Mainjet Size:
Clip Postion:
Cheers guys
Babuja
________
KTM 950 ADV
www.babuja.smugmug.com
http://www.nomadstrail.net/site/
babuja screwed with this post 07-15-2012 at 05:03 AM
babuja is offline   Reply With Quote
Old 07-15-2012, 04:56 AM   #2
babuja OP
babuja's Avatar
Oddometer: 353
Originally Posted by babuja View Post
Hi,
Mainjet Size:
Clip Postion:
According to this: http://www.xr650r.us/jetting/ maybe start with:
Mainjet Size: 175
Clip Postion: 3rd
*** XR650R Uncorked /stock header with HRC tip / B53E Comp Needle***
Use a main jet one size smaller when using a drilled stock tip instead of the HRC tip
Use a main jet one to two sizes larger when your side panel is cutout
If the stock needle is used, then ad +1 to the clip position listed below
Use a main jet one size larger with a high flow aftermarket exhaust canister
Use a main jet two sizes larger when using a larger diameter aftermarket header & exhaust canister
Cheers guys
Babuja
________
KTM 950 ADV
Old 07-16-2012, 12:05 AM   #3
babuja OP
babuja's Avatar
Oddometer: 353
anyone?
Cheers guys
Babuja
________
KTM 950 ADV
Old 07-16-2012, 01:25 AM   #4
oldxr
oldxr's Avatar
Oddometer: 1,140
Try 178 main -b53e needle 3rd of 4th groove from top 68s pilot
oldxr is offline   Reply With Quote
Old 07-16-2012, 10:50 AM   #5
babuja OP
babuja's Avatar
Oddometer: 353
Tnks oldxr fro your feedback.
Anyone with same settings?
Pilot: 68s
Need: B53E
Cheers guys
Babuja
________
KTM 950 ADV
Old 07-20-2012, 02:51 AM   #6
babuja OP
babuja's Avatar
Oddometer: 353
From all the feedback and what I read this seen to be more or lens consensus:
Pilot: 68s
Need: B53E
Mainjet Size: 175
Clip Position: 3rd position counted down from top of needle (and adjusted if needed).
Fuel Mixture: 2 1/2 turns out
Float Bowl: Don't know if any change is needed here?!
I'll prefer to jett in the richer side and the adjust.
I'll give some feedback about this ;)
Cheers guys
Babuja
________
KTM 950 ADV
Old 10-19-2012, 05:23 AM   #7
babuja OP
babuja's Avatar
Oddometer: 353
Couldn´t get my hands on a 178 and used a 175 on the 4th position down from top.
Bike running stronger, wheely comes out every time...sound perfect but need further test drive.
Just noticed some increment on oil temperature but not sure if results from higher air temperature (sommer is coming up), or any other reason.
Cheers guys
Babuja
________
KTM 950 ADV
Old 10-19-2012, 09:33 AM   #8
babuja OP
babuja's Avatar
Oddometer: 353
Low rpm...not so strong
In low rpm bike not so strong...not sure what to do.
Try do adjust air mix or move needle?
Guys, need some advice how to proceed.
Cheers guys
Babuja
________
KTM 950 ADV
Old 10-19-2012, 10:11 AM   #9
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,954
Drop to a 168 main, you knew it was rich, now it's time to tune like you mentioned.
Old 10-20-2012, 12:10 AM   #10
babuja OP
babuja's Avatar
Oddometer: 353
Readings
Hy larryboy, tnks for your feedback.
I'll do some more tests to evaluate low to mid throttle performance, midrange and three-quarters to full throtle performance, and take some readings.
I'll remove spark plug and clear it to see any changes in spark plug to help reading engine lean/rich condition and be right back with some more data.
Cheers guys
Babuja
________
KTM 950 ADV
Old 10-24-2012, 11:12 AM   #11
mung
Oddometer: 607
Jetting
Have about the same motor and pipe setup but with Hot Cam 2. Fuel screw 1.5,68s,HRC needle in 2nd clip from top,175 main.Works very good at my 6000 plus elevation.For Baja I use a 180 main.Clean,economical midrange and plenty of fuel for hard pulls.Lots of miles with this combo and it works very well for me. PS- modern gas does not give a very accurate plug color.
mung is offline   Reply With Quote
Old 10-25-2012, 01:31 PM   #12
babuja OP
babuja's Avatar
Oddometer: 353
Tnks mung...next weekend I'll do some tests with this setup and report all infos
Cheers guys
Babuja
________
KTM 950 ADV
Old 10-29-2012, 09:17 AM   #13
babuja OP
babuja's Avatar
Oddometer: 353
Gary Jetting table HELP
Need some help with Gary table.
1) What is exactly the "high flow aftermarket exhaust canister"? Is my T4 Pro circuit complet exhaus in this category?
2) What is exacty the "larger diameter aftermarket header & exhaust canister". Is my T4 Pro circuit complet exhaust in this category?
Tnks guys.
Cheers guys
Babuja
________
KTM 950 ADV
Old 10-30-2012, 04:20 AM   #14
babuja OP
babuja's Avatar
Oddometer: 353
Need some help with table.
Regarding Main Jet, Gary says: " Use a Main Jet one to two size larger when your side panel is cutout".
In using XRonly side panel cut out.
In your experience, where did you find best results with main jet: 1 or 2 size larger? Tnks
Cheers guys
Babuja
________
KTM 950 ADV
Old 10-31-2012, 03:52 AM   #15
babuja OP
babuja's Avatar
Oddometer: 353
Adapted from Gary table to my Angolan XR 650R 07:
Cheers guys
Babuja
________
KTM 950 ADV
Times are GMT -7.   It's 06:41 AM.
