Old 07-15-2012, 05:30 PM   #1
GSteve OP
GSteve's Avatar
Oddometer: 1,285
GSPD Knee Pad Glue
Question for the collective, what glue is recommended to secure the knee pads to to a GSPD tank? One side on my '95 is beginning to give up on it's struggle to stay mated to the tank.
Steve
Little Rock, AR
GSteve is offline   Reply With Quote
Old 07-15-2012, 06:44 PM   #2
Jay.T
Oddometer: 59
A few years back when I painted my tank, I pulled the pads off and reattached with heavy duty double sided tape. I ran the strips longer than the pad,stuck it on, trimmed to fit, and slapped them on. They have not moved or started to peel off after washes, rain, or hot weather.
Jay.T is offline   Reply With Quote
Old 07-15-2012, 07:51 PM   #3
bikerfish
flyfishandride
Oddometer: 1,546
I've heard 3M weatherstrip adhesive works well.
bikerfish is offline   Reply With Quote
Old 07-15-2012, 08:30 PM   #4
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
It works well enough, but I suggest practicing on something that doesn't matter,
I've seen instances where the only place the glue would stick is where I didn't want it too.
Not fun at all..
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 07-15-2012, 10:34 PM   #5
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,456
Make sure what ever weather strip adhesive you use you put it on both surfaces and let it get tacky before you install them. If you use spray adhesive put the knee pad on the tank, trace it with a pencil and spray some into a small container and brush it on the tank staying inside your pencil lines.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Boxer Metal is online now   Reply With Quote
Old 07-16-2012, 01:08 PM   #6
smorgasgeorge
Oddometer: 60
I was actually wondering this same thing yesterday.
So I'm assuming contact cement is NOT the way to go based on the responses so far?
It sure was a PITA to scrape off before repainting.
Thanks for the posts
smorgasgeorge is offline   Reply With Quote
Old 07-16-2012, 02:17 PM   #7
Grayghost66
Grayghost66's Avatar
Oddometer: 213
Clean surfaces well and then use 3M VHB (Very High Bond) double sided tape. I'm in the signage industry and this is very good stuff. Cut a few thin strips, position around the perimeter of the kneepad and a strip down the centre, line it up carefully, and rub the kneepad down firmly with the heel of your hand.
My GS pulls to the right...or the left...depending on what side of the road the Tim Horton's is on.
Grayghost66 is offline   Reply With Quote
Old 07-16-2012, 03:42 PM   #8
GSteve OP
GSteve's Avatar
Oddometer: 1,285
Thanks everyone for the suggestions and insights...time to go shoppin'.
Steve
Little Rock, AR
Old 07-16-2012, 03:48 PM   #9
windypoint
windypoint's Avatar
Oddometer: 226
Funny this question should be asked. I am about to repaint my GSPD tank and was wondering how to remove them. The other question I have is what is the best way to remove the instrument clusters for repainting the upper body pieces? It looks like a nightmare to remove it. Any suggestions? thanks
windypoint is offline   Reply With Quote
Old 07-16-2012, 03:53 PM   #10
smorgasgeorge
Oddometer: 60
The instrument cluster question might deserve its own thread (I'll be curious to hear about this too--in my limited experience, it's certainly a PITA).
To remove the pads, I just applied a bit of heat and peeled with a lot of elbow grease.
The previous owner had used contact cement.
YMMV.
Old 07-17-2012, 09:41 AM   #11
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,502
Just stuck my PD's rubber back on with bathroom silicone sealer. Worked a treat.
Rob Farmer is offline   Reply With Quote
Old 07-17-2012, 10:17 AM   #12
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Rob, keep us informed how that holds up.
That's very cool, I would have never thought of using that. It is waterproof............
www.wirewerkes.com
Old 07-17-2012, 11:24 AM   #13
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,502
It's bathroom silicone sealer. Has the advantage of pulling down as it dries. Holds most of my bike together
It's also brilliant for holding the rubber boots in place in the RS fairings.
Here's the blurb for it :-
"Silicone. Ideal for sealing joints between tiles & baths, basins, shower trays, kitchen worktops & sinks. Use on surfaces such as plastics, acrylics, glass, metal and ceramics. Forms a flexible and waterproof seal. Mould resistant and durable"
Rob Farmer screwed with this post 07-17-2012 at 11:34 AM
Times are GMT -7.   It's 06:19 AM.
