Old 07-15-2012, 04:44 PM   #1
limeymike OP
Who Me?
Oddometer: 647
Swapping final drive
Is putting a final drive from a R100 onto a R80 easy, ie bolt on? Looking to lowering the cruising rpm. Its an '86 mono.
limeymike screwed with this post 07-15-2012 at 04:53 PM
limeymike is offline   Reply With Quote
Old 07-15-2012, 05:06 PM   #2
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,543
The speedo will be off. Some put tape on the speedo glass to remind them.
Check the splines. They also get greased.
---Albert Einstein
Old 07-15-2012, 05:38 PM   #3
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
No splines on this final to grease
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 07-15-2012, 06:31 PM   #4
DaveBall
DaveBall's Avatar
Oddometer: 1,163
And if you can, grab the speedo of the R100 as well, that way it will match up with the final drive and show correct speed, or at least a lot closer to correct.
DaveBall is offline   Reply With Quote
Old 07-15-2012, 07:15 PM   #5
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,521
Direct swap between monos. Go ahead!
When swapping a final drive to a different ratio, what combo might work so that the original speedo becomes accurate?
If the oem setup is say, 7% optimistic, which setup might compensate for this and return the display to accuracy?
boxerboy81 is offline   Reply With Quote
Old 07-15-2012, 07:38 PM   #6
supershaft
because I can
Oddometer: 9,116
I think he will be going from a 3.37:1 to a 3.0:1? That's a big jump. Over 10%. If it's in the right direction you could get the speedo to a theoretical 3%? My 3.0:1 speedo isn't off nearly as much as many report according to speed sign radar and tickets I get. I would say mine reads about 2 to 4% fast? Maybe 3 to 5% at the most I would guess?
Old 07-15-2012, 07:43 PM   #7
coastranger
Oddometer: 429
easy swap adn one you might very well like. On my 85 I swaped out the final drive off a R100 and the speedo. I noticed near at least a 500 rpm drop at speed
coastranger is offline   Reply With Quote
Old 07-15-2012, 08:13 PM   #8
limeymike OP
Who Me?
Oddometer: 647
I have heard similar numbers quoted from the swap so I think it is worth it.
Old 07-15-2012, 08:19 PM   #9
limeymike OP
Who Me?
Oddometer: 647
With the stock final drive my speedo reads 70mph at an actual speed of 65mph, that's taking the actual speed from a TomTom gps that I temporarily rigged up. approx 7% error.
Old 07-15-2012, 08:44 PM   #10
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,513
That's pretty typical. You'll find that your odo is pretty much bang on though. There was a thread about speedo error a while back. It's worth a read if you can find it.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 07-15-2012, 09:30 PM   #11
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,507
Easy bolt on. Look for a speedo that says 1.078 on the face.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Boxer Metal is online now   Reply With Quote
Old 07-16-2012, 12:04 AM   #12
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,688
I thought the speedos were all the same and the gearing of the speedo drive needed to match the final drive
My bike is slow but the earth is patient.
Rucksta is offline   Reply With Quote
Old 07-16-2012, 06:08 AM   #13
Airhead Wrangler
Adios Mexico
Oddometer: 6,513
Nope. The internal gearing of the speedo has to match the final drive. Your speedo will have "W=_____" on the face. This indicates what final drive ratio it is intended for. Annoyingly they use a completely different metric for the speedos rather than just listing the corresponding final drive ratio. W = the number of rotations per mile (or km for 'rest of world' market bikes). At some point (can't remember when exactly) they changed W from thousands of rotations per mile to just rotations per mile. eg: W=1.202 became W=1202.
Airhead Wrangler screwed with this post 07-16-2012 at 06:32 AM
Old 07-16-2012, 06:22 AM   #14
Beater
Freakin' Swamped
Beater's Avatar
Oddometer: 3,371
I didn't know that. That IS annoying. Do you know if the 'W' metric takes into account the diameter of the rear wheel?
'85 R80RT G/Sified * '73 R75/5 LWB
Fred: Fascinated by All Things Simple / Easily Amused
Beater is offline   Reply With Quote
Old 07-16-2012, 06:34 AM   #15
Airhead Wrangler
Adios Mexico
Oddometer: 6,513
I've never really though about it much, but I guess it would have to.
Times are GMT -7.   It's 01:19 AM.
