Old 07-16-2012, 05:52 AM   #1
ozujiro OP
ozujiro's Avatar
Oddometer: 6
Puke Can't find contact points for horn: 1971 R60/5
Hi All,
I am new to airheads and to this community. Excited to be riding a 71' R60/5. The bike I have is in great condition, but it did not come with a horn installed. I did buy a horn from Max BMW, and tried looking for the wires (2 green and 1 black) under the tank but did not see any. I am working off of the electrical diagram from the workshop manual, but am not having any luck finding the wires.
Is there anyone out there that has a photo of the wiring to the horn or any advise that can help?
Thanks.
ozujiro is offline   Reply With Quote
Old 07-16-2012, 07:45 AM   #2
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,542
If you have the wiring diagram you should be able to say where the wires come from or identify some intermediate point. Find this. They start at the left hand handlebar control. Start there.
Horn wiring has often been changed to add a relay. A good modification because a relay handles power better than running it all through the handlebar switch. See if the wires that should go to the horn are actually going to a relay.
---Albert Einstein
Old 07-16-2012, 02:58 PM   #3
ozujiro OP
ozujiro's Avatar
Oddometer: 6
Thanks Disston.
I think I found the wires but when checking with the digital amp meter, only about .04 volts go through when the button is pressed. The old wires seem freyed, which I will try to replce.
While I had the battery on (engine not running), I noticed the coils were really hot. Do you know if this is normal?
Old 07-16-2012, 03:38 PM   #4
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,542
I have less of a problem working on my /6. It has a kill switch that I can use to stop elec going to the ignition. You don't have a kill switch and if you turn on the ignition to work on something the elec would flow thru the points and the coils if the points are closed. You could pull one of the wires to the coil or a lead going to the condenser if the cover is off. It is probably not a good idea to drain the battery or heat the coils up too much. I have heard that this can burn up ignition points.
BTW, it is the completed circuit that flows elec. So any wire discoed stops the flow.
---Albert Einstein
Old 07-16-2012, 04:30 PM   #5
ontic
Oddometer: 1,070
also, the completed circuit earths through the horn button into the handlebars (via one of those tiny slotted flat head screws in the button housing).
I had one of those screws out one day when doing some work and decided to test the horn- not working... that one took a while to figure out
1974 R90/6
1981 R80G/S
1994 XLR250R
ontic is offline   Reply With Quote
Old 07-17-2012, 05:23 PM   #6
ozujiro OP
ozujiro's Avatar
Oddometer: 6
Horn installed succesfully
Thanks Ontic and Disston for your tips.
The horn is installed and works perfectly!
Taking the bike to get the inspection tomorrow, which will make it completely legit in NYC. Excited.
Times are GMT -7.   It's 04:42 AM.
