Old 07-17-2012, 01:50 PM   #1
3Rrr OP
Read Ride Reflect recycle
3Rrr's Avatar
Oddometer: 147
Quick-adjust handlebar options
Been looking at the Wunderlich Quick-adjust and found these units on Amazon for less than half the price. Anyone try them? Also want to confirm the specs.
Kyle twitter.com/ducumph
3Rrr = Read, Ride and Reflect
09 BMW F800GS
03 TTR 225
89 Kat GSX600F
3Rrr is offline   Reply With Quote
Old 07-17-2012, 11:32 PM   #2
vudu_52
Black Magic
vudu_52's Avatar
Oddometer: 106
Send a message via Yahoo to vudu_52
Alternative clamping bolts
I purchased the Wunderlich ones for my 1150 with bar risers, didn't get to fit them before I bought an F800GS. I cut them down to fit and have recently installed them. They work exceedingly well.
I did some research before thinking about cutting them down and found these:
http://www.kipp.com/cms/wm?catId=188...inless%20steel
I believe they are what Wunderlich sell with the extra thick washer to cope with the recess in the handlebar clamp. They were considerably cheaper than Wunderlich. You may have a distributor in your area and all you will need to obtain is a thickening washer to make them work.
Hope this helps.
"Love is the condition in which the happiness of another person is essential to your own." Jubal Harshaw
vudu_52 is offline   Reply With Quote
Old 07-18-2012, 02:40 PM   #3
GH41
Oddometer: 626
The ones on Amazon say made of die cast zinc. That is pot metal!! I wouldn't want pot metal to be the only thing between me and a hospital bed! Did you notice the shipping note? 1-2 months... I also don't see what rotating the bar will give you unless your low position has the bars rolled back further than normal. The bars have so little pull back. I would loosen the back bolts and try it before investing in the snake oil. You would be better off with risers to get higher. GH
GH41 is offline   Reply With Quote
Old 07-27-2012, 09:45 PM   #4
mapuda
Crash Tested
mapuda's Avatar
Oddometer: 243
Reid Supply
These units are 8mm x 1.25 and 35mm thread length and only cost 6.77 per. http://www.reidsupply.com/sku/KHD-250/
Made by Kipp. You can get them in almost any size/dimension.
Good judgement comes from experience. Experience comes from bad judgement.
mapuda is offline   Reply With Quote
Times are GMT -7.   It's 07:19 AM.
