Old 07-21-2012, 04:07 PM   #1
spaine OP
Oddometer: 19
2002 Husaberg FE 400
As I'm sure some of you can tell from my posts, I'm looking at Dual Sport bikes, DRZ, KTM's and maybe a few others. Right now I am looking at a 2002 Husaberg FE 400. It's in great shape from what I can tell in pictures and it's street legal. Also, I want to check the air filter when I look at this bike. On Husabergs, I don't see the typical air-box behind the carb, accessible from a side panel or removing the seat. Where is it on these bikes ?
This bike looks great, I might bring it home with me.......
spaine screwed with this post 07-21-2012 at 04:24 PM
spaine is offline   Reply With Quote
Old 07-21-2012, 04:25 PM   #2
Johnf3
Oddometer: 1,055
Remove the seat and you will see the filter clamped directly to the hollow frame between the gas tank. I am a Husaberg lover (had a 2005 before my 2010), but the 2002 Husabergs had issues. When manufacturing was moved to Austria in 2004, they were as reliable as anything.
The SEM ignition and the Dellorto carb are the first issues, but there are more. I would pass on any 2002-2003 Husaberg personally.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Johnf3 is offline   Reply With Quote
Old 07-21-2012, 06:36 PM   #3
spaine OP
Oddometer: 19
Thank you Johnf3. Very interesting, I think I'll take your advice and pass on this one.
From what I understand KTM is the parent company of Husaberg ? Or is it the other way around ?
So the combining / merge happened around 2004 / 2005 I am guessing ?
spaine screwed with this post 07-21-2012 at 06:41 PM
Old 07-21-2012, 07:12 PM   #4
spaine OP
Oddometer: 19
The seller just sent me an e-mail offering it for a better price and I haven't even looked at it yet... Hmmmm........Ignition problems probably are expensive. Carb, I have heard about Dellorto's from the old days on Maico's and such. What are some of the other issues on the 2002/2003 ?
I think I probably will pass on the bike but just wondering what other issues the Husabergs from that time frame have.
Old 07-21-2012, 09:24 PM   #5
Johnf3
Oddometer: 1,055
Long story short-KTM bought Husaberg back in 1997 because KTM needed a competitive four stroke engine (which Husaberg already had). The RFS engine that KTM came up with was nearly a direct copy of Husaberg's engine at the time in many ways.
The 2002 era Husaberg engine (new design in 2001) had major issues with rocker arm bearings, cam gears (aluminum changed to steel mid-year), cam chain tensioners and cam chains, and also the auto decompressor mechanism. I already mentioned the SEM ignition and the carb.
All of these things can be fixed, and then the 400 is a great bike. If they have not been, it is a matter of time until issues start and then you have a project on your hands. Parts are going to be an issue at some point too, although they are available for now.
In 2004, Husaberg came up with a new engine again and production was moved to Austria at the KTM factory. Besides the engine, it got a Keihn carb and a Kokusan ignition just like the KTM. Huge upgrades that made the bike as reliable as any other racing four stroke made.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Old 07-23-2012, 08:34 PM   #6
spaine OP
Oddometer: 19
Very good......Or, not so good for husa's of this era .....I don't mind working on bikes but this sound like big bucks at some point.
Old 07-24-2012, 05:11 AM   #7
brucifer
brucifer's Avatar
Oddometer: 2,496
Johnf3 is making it sound like Husaberg had a completely different engine in 2004 which isn't the case. It's the same design as the 2001. It received upgrades but it's the same design.
With the exception of the SEM ignition, the '02 engine can be upgraded with all the later model pieces.
One other thing that plagued the '01 and '02 bikes is the maincase would crack where the swingarm bolt goes through.
Check this out. http://www.husaberg.org/wiki/index.p...on_and_changes
2014.5 Kawasaki KLR650 NE-2006 Buell XB12SS-2002 Husky TE570-2001 Yamaha WR250F-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F
brucifer is online now   Reply With Quote
Old 07-24-2012, 06:26 AM   #8
Johnf3
Oddometer: 1,055
Yes. You are correct. The 2004 was the same design as the 2001. It was just so much more reliable that it was no comparison to the 2001-2003.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Old 04-23-2013, 04:03 PM   #9
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,774
Does anyone know about the 2000 fe 400?
What engine parts cross over to ktm, known issues etc.?
I need a slave cylinder/ gasket, fork seals, and some other stuff.
TIA.
BK.RD.RNR is online now   Reply With Quote
Times are GMT -7.   It's 05:52 AM.
