Old 07-21-2012, 11:23 PM   #1
willis 2000 OP
neo-quixote
Oddometer: 1,224
porting
The IT175 thread reminded me of my YZ125 experience. The transfer ports were so mismatched, left vs. right that bike had no power, at all. Porting was what let the big boys run away from y'all. Here's the scene, a lowly engineer says this will work great. We'll leave the Suzukis in the dust with this. The factory was unable to reproduce the engineer dream, failure often ensued. Get out your rattail files, ease transitions, balance right and left, then get into the mind of the designer. This is when my buddies take their cylinders away from me. Go solo, figure it out. Was the designer going for a Schnurle effect or stopping the incoming transfer ports to each other, a Honda innovation. Resist the urge to hog it out. Velocity is more important than volume.
willis 2000 screwed with this post 07-21-2012 at 11:30 PM
willis 2000 is offline   Reply With Quote
Old 07-21-2012, 11:40 PM   #2
Tosh Togo
Oddometer: 1,594
Originally Posted by willis 2000 View Post
...... Velocity is more important than volume.
Do tell.
Tosh Togo is offline   Reply With Quote
Old 07-21-2012, 11:46 PM   #3
willis 2000 OP
neo-quixote
Oddometer: 1,224
Yeah
Smartass, I'm preaching to the proletariat here. You have ignored the wisdom I am imparting to the unwashed masses, it is so simple. Were you the guy that roosted me at Washougal?
Old 07-22-2012, 02:43 PM   #4
Low Budget
Mr Nobody
Low Budget's Avatar
Oddometer: 334
I need both a washing........and........a hit off the bong you are bogarting !
Low Budget is offline   Reply With Quote
Old 07-24-2012, 01:59 PM   #5
lrutt
SILENCE.....i kill you
lrutt's Avatar
Oddometer: 812
would agree, port maching and smoothing is easy cheap power. I'll be doing an RT1 soon and plan on just a cleanup of the ports.
2004 Harley Sporster 1200C, 2001 Ducati M900, 2001 Honda XR650L, 1994 Harley Heritage, 1978 Honda CB750K with sidecar, 1977 Moto Guzzi 850 LeMans, 1976 Honda CB750K, 1965 Honda 305 Dream, 1973 Norton 850 Commando, 1971 Triumph Trophy 650, 1970 Honda Trail 90, 1970 Triumph Tiger 650, 1973 Honda Z50, 1984 Yamaha Virago 1000, 1981 Honda Passport 70, 1970 Suzuki T250, 1971 Yamaha RT1 360
lrutt is offline   Reply With Quote
Old 07-24-2012, 09:29 PM   #6
Abdelhub
Blanco Trasho
Abdelhub's Avatar
Oddometer: 687
i am very interested in diy porting....i have shitloads of bultaco and ossa cylinders to experiment on.....hopefully some secrets will be imparted...
mike
the most valuable bike i own hasn't run in 20 years...
http://www.youtube.com/abdelhub
Abdelhub is offline   Reply With Quote
Old 07-25-2012, 02:01 AM   #7
willis 2000 OP
neo-quixote
Oddometer: 1,224
let's roll
Clean your cylinder of carbon first. Flat-blade screwdrivers work well.
Look it over carefully for sharp edges. Sharp edges cause problems with flow.
No tools yet, we're looking it over. Does the intake tract flow smoothly downward to the crankcase?
This is a good time to gain an understanding of 2-stroke theory. The intake flows to the crankcase, it is compressed by the downward piston movement, and pushed out the transfer ports to the cylinder.
The exhaust scavenges the burnt gases, but not too much.
Now, let's look at those sharp edges, starting with the intake tract. The intake should flow decidedly downward, and a sharp edge at the bottom edge of the intake is disruptive.
However, hogging out the intake will rob bottom-end power and your goal should be to maximize low-mid power. Often, the intake port will require a smear of jb-weld to smooth it out and ease the transition.
The precursor to jb-weld is a clean metal surface to apply. You don't want it coming loose, ever.
Removing an intake port edge by grinding often removes too much metal at the cylinder port, increasing intake timing and hurting bottom-end power.
Next, the transfer ports. Use your fingers as gauges to determine if the ports are the same size. A smooth, rounded flow is the object here. Most cylinders have a blunt edge at the base of the transfer ports, on the inner (piston) side. For the best flow, this blunt edge should be rounded, not knife-edged. Flow, not volume, is important here. The YZ125 I mentioned before was so bad it required the outer side of the transfer ports and the crankcase to be opened up on one side to match the other. I used sealer on the base gasket so it didn't leak. Fingers as gauges, use them.
The top and side edge of transfer ports at the cylinder really matter. A chamfer with 80-grit emery cloth is a start.
Now, the exhaust port. Watch out here, you can alter the powerband adversely by hogging it out. Sharp edges should be removed, but watch out, usually a chamfer job is all that's required.
I do this with rat-tail files and 80-grit emery cloth from a roll.
I spent 40+ hours on a Maico 490 jug and it was magic.
Be very cautious with power tools, they tend to get away from a guy. If you take no metal off, it cannot be worse than when you started.
willis 2000 screwed with this post 07-25-2012 at 02:06 AM
Old 07-25-2012, 05:49 AM   #8
anotherguy
anotherguy's Avatar
Oddometer: 4,359
Don't waste out of production cylinders on poorly advised exercises. And unless you are sure of the end result pay someone else to port you smoker. A good pipe and correcting the squish is cheaper and easier.
When injustice becomes law,resistance becomes duty.
Thomas Jefferson
Old 07-25-2012, 09:39 AM   #9
Low Budget
Mr Nobody
Low Budget's Avatar
Oddometer: 334
Old 07-28-2012, 02:33 AM   #10
willis 2000 OP
neo-quixote
Oddometer: 1,224
Yeah, this advice is only meant for single-cylinder owners. We're gonna use the pipe we have and you'd hafta show how we could adjust squish.
Don't touch the cylinder, yet, maybe never. Notice the transfer port flow includes the bottom of the crankcase ports. Right vs. left is a common imbalance.
Use your fingers and a base gasket as gauges.
Old 07-28-2012, 05:34 AM   #11
anotherguy
anotherguy's Avatar
Oddometer: 4,359
My intent was to save some hard to find 'taco and Ossa parts from doorstop duty. I do have a little idea what goes on inside a smoker.
Thomas Jefferson
Old 07-28-2012, 10:43 AM   #12
Low Budget
Mr Nobody
Low Budget's Avatar
Oddometer: 334
Let em grind ! The value of rare cylinders will go up another 20 % next month !
Cant tell you how many scrap metal cylinders we have tossed over the decades from home brew "Tuners" thinking they couldnt go wrong !!!!!
The factory has a bit of a clue on how to do porting.......especially with production MX bikes !
Old 07-28-2012, 10:14 PM   #13
willis 2000 OP
neo-quixote
Oddometer: 1,224
Sir, you are one of the most knowledgeable fellows on this site.
I want to pass on the knowledge I have gained through years of DIY porting. I ruined my share of cylinders before I figured it out. First, do not trust this job to a paid professional. They work too quickly, and they usually "hog it out". The plan is to match right-to-left, ease transitions and get the best cylinder scavenging while removing only a small amount of metal. With that in mind, power tools are off-limits. Use an assortment of files and 80-grit emery cloth. No grinding. This is a labor of love, it's yours, right?
willis 2000 screwed with this post 07-29-2012 at 10:16 AM
Old 07-29-2012, 06:38 AM   #14
Twin-shocker
Oddometer: 1,072
Its really very silly for those who dont know how to waste time trying to "port" a 2T cylinder, when in most cases the squish clearance is going to be way out, and exhaust and intake systems are likely to be a very long way from ideal.
Old 07-29-2012, 06:23 PM   #15
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 2,943
I learned how to port back in the early 70's from the late great EC Birt when I worked for him at Precision Cycles. Later I did all of the porting for Donny Emler when he opened Uncle Donny's Flying Machine Factory (now known as FMF). Carbide burrs in die grinders are the tools of choice, with many custom bits and angle attachments also used extensively. Files are only used to champher the edges of the ports after you've finished so the rings don't catch. Only the exhaust port is polished to prevent carbon build up, intake and transfer ports are left rough sanded.
The single biggest issue with porting is port timing. 2 stroke port timing is laid out similar to 4 stroke cam timing. Port timing laid out in degrees from TDC. How many degrees after TDC the exhaust opens and then how many degrees later the transfers open dictate where your top end an bottom end power will be. Ever since the introduction of reed valves, intake timing is WFO with the reeds controlling the action. Recent (newer) 2 stroke race bikes benefit more from a quality pipe than playing with port timing and simply cleaning up your stock ports rarely yields significant increases in HP.
"I couldn't wait for success, so I went ahead without it."
Strong Bad is online now   Reply With Quote
Times are GMT -7.   It's 10:45 AM.
