Old 07-23-2012, 07:42 AM   #1
lochridge OP
Oddometer: 135
patrs help
r80g/s/ fork boots:
do i need to buy just the boots or the other stuff listed with them?
see: http://www.maxbmwmotorcycles.com/fic...3&rnd=05012012
thank you
edit. btw i cannot spell (parts) correctly when in a hurry..... :) see the title
lochridge is online now   Reply With Quote
Old 07-23-2012, 08:38 AM   #2
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 6,910
Send a message via AIM to crazydrummerdude
You need to buy a whole new motorcycle.
Ok, what are you trying to do? What's the project? What do you need? What do you not know if you need?
crazydrummerdude is offline   Reply With Quote
Old 07-23-2012, 10:09 AM   #3
lochridge OP
Oddometer: 135
got an r80st and would like to add these to the forks.......that is all.
do i need item numbers 1,2,3,4
or just item number 3
Old 07-23-2012, 01:44 PM   #4
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 5,000
If you don't have the rubber boots on the forks what do you have? Do you have the smaller sliders, # 6? Or everything is missing? If you don't have them you will at least need the hose clamps, #1. I don't know what #2 is, it doesn't look like the fork seal. #4 looks like the hold off for the brake line, you might have #21 instead so can do with out #4 maybe. #5 looks like the wiper that the little sliders use, these don't work very well at keeping out dirt.
---Albert Einstein
disston is online now   Reply With Quote
Old 07-23-2012, 02:59 PM   #5
hardwaregrrl
Shit for brains
hardwaregrrl's Avatar
Oddometer: 4,865
you need #2, it's a doughnut that slides over the fork that the hose clamp attaches the gaiter to. There is a little pin the will slide the doughnut up into the bottom clamp. you should alread have #4, if not you can always use a zip tie. So the gaiter and the doughnut is all you should need.! Oh, and the fancy, skinny, bmw pipe clamps #1.
hardwaregrrl screwed with this post 07-24-2012 at 05:42 AM
Old 07-24-2012, 06:58 AM   #6
lochridge OP
Oddometer: 135
#6 is on there for sure, so i assume #5 is as well.
it is just 1-4 that i wasn't sure about.
Old 07-25-2012, 07:45 AM   #7
Rucksta
Chronic Noob
Rucksta's Avatar
Oddometer: 2,292
When you get your 2's there is a small hole, it's a vent.
The G/S has a roll pin through each side of the lower triple to which a hose running into the back of the headlight is attached.
The G/S triple was also drilled for 4 mounting bolts for the high fender so it's a little different to the ST.
Without some form of venting the gaiters balloon on comperssion
If the Earth is flat why are my tyres round?
Rucksta is offline   Reply With Quote
Old 07-25-2012, 08:04 AM   #8
lochridge OP
Oddometer: 135
thank you.
great information.
i will make note of that
Times are GMT -7.   It's 08:15 AM.
