Old 07-23-2012, 10:29 AM   #1
Bill Harris OP
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,888
Treating Unpainted Steel
The /5 series uses a horseshoe-shaped fork brace that sometimes twists a bit and needs to have the indexing/mating surfaces trued up. The brace is chrome-plated and once ground, the mating surfaces are raw steel. Although bolted to the fork sliders, this steel surface needs to be protected from rusting. I don't think paint will work because it will flake and peel on contact with the fork slider. I guess that I'm looking at a way to put a phosphoric acid or passivating coating on the steel surface. Any ideas?
TIA...
'73 R60/5 Toaster
Old 07-23-2012, 11:07 AM   #2
craydds
craydds's Avatar
Oddometer: 1,164
Maybe something from Eastwood? http://www.eastwood.com/rust-solutions/treatment.html
ABC #12947
'75 R90S
craydds is offline   Reply With Quote
Old 07-23-2012, 11:55 AM   #3
Bill Harris OP
Oddometer: 7,888
Yep, something like that. I'm thinking the displacement zinc-phosphate coating or some sort of "Brush Plating" system from Caswell. They have a variety of chromates and cadmium solutions available. Not only this fork brace, on a old motorcycle I have a lot bolts, fasteners and painted metal bits that are showing their age after 40 years. I don't want a rolling-off-the-showroom full resto, but I'm wanting to ditch the Rat Bike image...
I'll look into it.
'73 R60/5 Toaster
Old 07-23-2012, 12:38 PM   #4
rufusswan
rufusswan's Avatar
Oddometer: 962
I simply soak them old nuts, bolts, etc. in full strength "Deck Etching and Cleaner" that I get at Home Depot. I don't know what full strength means, by the way.
After that they all spend a few seconds on the bench grinder on which I have a brass wheel to further polish them. After that, if they are primarily a cosmetic bolt they get painted with clear nail polish/hardner from the cosmetic counter.
To make a dry phosphate coating, mix (by volume) 1 part of deck etching with 3 or 4 parts water, spray and let dry, repeat if you wish. The water will dry faster than the pha will leaving a coating of pha. Depending on what you are spraying, you may see the residue as a white coating which is pha. Gently wipe off any loose powder, and you can then paint or clear coat.
1971 BMW R75/5 Toaster LWB
1974 Honda CL200
http://zenhuckfinn.wordpress.com/
rufusswan is offline   Reply With Quote
Old 07-23-2012, 05:20 PM   #5
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,543
You could try Penetrol too.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 07-23-2012, 05:27 PM   #6
Cat Daddy
Cob Artist
Cat Daddy's Avatar
Oddometer: 837
I'd have the hardware professionally zinc plated. My local shop charges a 25 dollar minimum, but they'll plate 25 pounds for that price. So, a buck a pound.
This is all the hardware on the last bike I restored. It was 12 pounds total, so I paid the 25 dollar minimum and dropped off the dirty rusty stuff and picked this up 5 days later.
Cat Daddy is offline   Reply With Quote
Old 07-23-2012, 07:14 PM   #7
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,822
Wow... that is a DEAL...!!
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 07-24-2012, 01:16 AM   #8
Padmei
enamoured
Oddometer: 3,693
Wow that's good value for money. Will the plating last a long time or will it flake/ discolour?
Padmei is offline   Reply With Quote
Old 07-24-2012, 03:28 AM   #9
patanga
BMWAirheadsDownunder
patanga's Avatar
Oddometer: 161
I've had good results with zinc plating. Generally you have a choice of the silver or a light gold colour. If properly prepared and applied it lasts quite well. Good luck.
____________________
"The only reason people get lost in thought is because it's unfamiliar territory" (Joe Garcia)
Check us out on facebook at "BMW Airheads Downunder", (The Australia and New Zealand Airhead Community). "B.A.D"
http://www.facebook.com/groups/anzairheads/
patanga is offline   Reply With Quote
Old 07-24-2012, 07:44 PM   #10
boxermoose
Now fully goosed
boxermoose's Avatar
Oddometer: 2,852
If it's a small area - chrome nail polish, plastic, flexible and cheap
Sometimes you get the ABAT....and sometimes the ABAT gets you
boxermoose is offline   Reply With Quote
Old 07-25-2012, 08:14 AM   #11
ericrat
Oddometer: 1,211
Darn it
I can't remember the name of the stuff, Tractor Supply sells it for cleaning diary equipment. It is a phospate based cleaner that leaves a nice phosphate coating... I will try to think of it.
Have you visited ride reports lately ?. click HERE
ericrat is offline   Reply With Quote
Old 07-25-2012, 08:29 AM   #12
coastranger
Oddometer: 429
wow that stuff loooks great,
coastranger is offline   Reply With Quote
Old 07-25-2012, 11:07 AM   #13
Bill Harris OP
Oddometer: 7,888
TEC, we've got one in town. And "tractor supply" sounds properly Airheadish.
I'm still looking at options on this...
'73 R60/5 Toaster
Times are GMT -7.   It's 09:36 AM.
