Old 08-28-2012, 11:15 AM   #31
NCD
Dirty Hairy
NCD's Avatar
Oddometer: 509
Note that there are 2 check valves back at the R corner of the tank under the trim panel.
#1 is the large white unit bolted into the tank where the vent hose attaches. That is the weighted tip-over shutoff valve that you can hear knocking around when you rock the bike back and forth.
#2 is the inline check valve with the 2 way properties being discussed. It is a 1" long silver cylinder stuck inline to the vent hose about 6-8" behind #1. It is ziptied to the frame before the hose does the 180 and heads back down toward the canister.
Inside that little cylinder is a green ceramic check ball. It is porous, with microscopic holes in it.
Those pores get plugged up with the aluminum corrosion dust from inside the cylinder and cause your tank to hold pressure beyond the 5psi expected.
Solution? The cylinder splits into 2 pieces. Open it, toss the check ball in the trash, and reassemble.
Mine has been like this all HOT summer with no ill effects. Canister still attached and working fine.
This permanently cures tank POSITIVE pressure, and lets you keep the canister to control the fumes in your attached garage.
The mighty Joel W. helped me with this diagnosis - - I'm just putting this info out there for the masses. He said BOTH valves can stick, so check them independently (suck/blow through them - it tastes like shit, so be prepared.) He did say that #2 is the usual culprit.
NCD is offline   Reply With Quote
Old 08-28-2012, 11:39 AM   #32
itsatdm
itsatdm's Avatar
Oddometer: 5,000
Thank you, I feel exonerated and informed at the same time. Good info, should be in a sticky.
Old 09-25-2012, 11:41 AM   #33
tempeturtle OP
tempeturtle's Avatar
Oddometer: 35
There seems to have been a plug in some line that caused the fuel pump to heat up and cause the pressure. At least that is what I am guessing from the fault code report. It shows good voltage put very low (almost zero PSI) fuel pressure from the fuel pump.
READ OUT BELOW FROM MY GS911
10168: Electric Fuel Pump System faulty
The fault is not present now.
This fault occured 4 times.
Logistic counter: 31
Symptom: No signal or value.
MIL set: No
Fault code history:
Electric Fuel Pump Voltage 12.62 V 12.25 V 12.62 V
Odometer 15952.6 miles 15952.6 miles 15957.6 miles
Engine Speed 3280.00 rpm 1160.00 rpm 1360.00 rpm
Measured Fuel Pressure 0.39 hPa 0.41 hPa 0.37 hPa
Throttle Valve Angle 29.30% 0.00% 0.00%
If you like to work on your own bike like me then this tool (GS911) is invaluable. The reports it provides look much better then this but I was not able to transfer it directly via text.
Does anyone else have the same or different interpretation of what caused this as I do?
Original symptoms: Bike stalled from a standstill or very slow movement; It would restart but got progressively worse until it would not; and finally after it would not restart I opened the gas lid and fuel came out like a guesser (a liter or more).
Any insights would be welcomed.
andy
tempeturtle is offline   Reply With Quote
Old 09-25-2012, 05:16 PM   #34
JRWooden
Oddometer: 4,312
Andy:
I'm not sure how I would interpret that ....
For example -- lets say the impeller wheel were spinning on the shaft of the fuel pump motor, or the bearings in the motor were going bad causing it to run slowly .... or say the input filter sock were clogged ....
would the reported fault not still be the same ...
i.e. good voltage to pump, but pump output was crap?
I'm just brainstorming with you here
Old 01-27-2013, 01:41 PM   #35
space
a.k.a. Jake
space's Avatar
Oddometer: 2,635
Andy, did you ever figure this out?
I've been having the same symptoms on my HP2. Intermittent stalling and same error code on the GS911. My guess is a clogged fuel line upstream of the pump, probably due to debris in the tank or bad gas.
I'm about to take apart my fuel system and check, but I'm wondering how this turned out for you.
EDIT: yep, turns out I had a large wad of black gooey glop (technical term) backing up the screen of my pre-pump filter. I hope your problem was similarly easy to fix.
space screwed with this post 01-27-2013 at 03:53 PM
space is offline   Reply With Quote
Old 01-28-2013, 03:42 PM   #36
tempeturtle OP
Oddometer: 35
Mine was also the little porous ball that got gummed up and thus creating a blockage. Have not had the problem since. Gas in the Phoenix area just seems bad, all of my bikes carbs (harley, and a couple of honda dirt bikes) get gummed up. I am now using sea foam and it helps.
Old 11-10-2014, 06:47 PM   #37
Effisland
Effisland's Avatar
Oddometer: 304
Thank you. Your description helped, that fuel tank check valve must have been part of the reason for my stalling out, I blew it out, was full of aluminum dust, I presume, the valve wasn't passing any air. Had to take off the rear panel to remove.
I also changed the spark plugs, which also may have helped. Since I recently filled up at a totally unknown gas station in a shady part of town, and we have had about 150mm of rain the last week, so I also drained the gas and filled with new Chevron gas.
Also used never-seize on the threads, and some electrical conductivity paste on the sparkplug/coil interface part of the sparkplug. I am quite surprised of the rust on just one of the spark plugs, it's totally orange and crumbly.
There was so much crusties down there in sparkplug land, I walked to Canadian Tire and back to purchase a compressor and jet spray gun. Also another 5 Litre jerry can. Just a 2 gallon 1/2 horse compressor (light enough to carry) makes enough pressure to blow the shit out of the sparkplug hole. I also used it to blow out the fuel tank check valve.
Guess I have to say that plenty of folks have been more than ample with their time in describing issues. I've been a big reader and even though it's been a few years since my early wrenching days I'm feeling more than relieved that this problem has been fixed. It idles so well now, super sweet acceleration and just a pleasant beast again. I don't mind taking some extra time to express my thanks to all the anonymous (to me, a recluse) folk out there taking the time to take pictures and notes.
Oh yeah, but I must have put it all back together with a couple fewer screws. I gotta hand it to those BMW designers, the thing goes back together solid, not like some bikes. Challenge is in finding the right length bolts/screws. I got to the final piece over the top and I am out of long 25tx! No worries...
BTW the title of this thread should really be 'Excess fuel tank vacuum fail (solved)"
2010 BMW F800GS
Effisland screwed with this post 11-10-2014 at 06:54 PM
Effisland is offline   Reply With Quote
Times are GMT -7.   It's 06:36 AM.
