Old 07-19-2012, 09:01 PM   #1
Highside>Lowside OP
Hairier Than Thou
Highside>Lowside's Avatar
Oddometer: 821
Question 1981 IT175 Repower?
Okay, I used to race HS way WAY back when, and I picked up a cheap basket to relive old times. I'm going to go through the motor, but in the interim, do the later right drive IT175 and 200 engines swap into this frame relatively easy? Because I see good running cheap examples all over the place. Would be an easy way to get this thing running this summer.
TIA
1977 TT500- Old's Cool.
1995 620 RXC- Make my Kool Aid Grape, please.
1982 FT500- Moar Thumper
2000 M900- My new Italian Lover
Now with more Honda Sabrey GoodNess (IBA SS1000 Approved)
Highside>Lowside is offline   Reply With Quote
Old 07-20-2012, 08:01 AM   #2
Shocktower
Shocktower's Avatar
Oddometer: 8,220
What is easy
Alexa Drew Nov 9 1995- Oct 28th 2004 Miss you baby
'08 KTM 530 EXC
79 RD 400 Daytona
Shocktower is offline   Reply With Quote
Old 07-20-2012, 09:24 AM   #3
Highside>Lowside OP
Hairier Than Thou
Oddometer: 821
Bluhduh Easy
NO major changes to the exhaust or frame.
Old 07-20-2012, 01:38 PM   #4
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 30,297
dunno but sure did love the IT175! one of the greatest bikes Yamaha ever made.
"I claim to be frightened of horses but do so only to get out of attending parades. It's peculiar but ...it works. The Horses get it.
RESISTANCE IS NOT FUTILE. IT'S VOLTAGE DIVIDED BY CURRENT
Sniper X is offline   Reply With Quote
Old 07-20-2012, 01:48 PM   #5
Highside>Lowside OP
Hairier Than Thou
Oddometer: 821
Laugh
Yeah, I loved the little bugger. Trying to get this one going to relive some of that.
Old 07-24-2012, 07:47 PM   #6
stainlesscycle
stainlesscycle's Avatar
Oddometer: 1,639
you're better off starting with a it200. they're dirt cheap, and the suspension, power delivery, and handling is light years ahead of the 81 it175.
current bikes
stainlesscycle is offline   Reply With Quote
Old 07-25-2012, 04:07 AM   #7
Highside>Lowside OP
Hairier Than Thou
Oddometer: 821
But I didn't start racing Hare Scrambles on an IT200. I raced the Little White Knight...
Old 07-25-2012, 04:43 AM   #8
Hot Stuff
Road Dragon
Hot Stuff's Avatar
Oddometer: 191
Best of luck to you, sorry I can't help with any information. That's an IT 200 in my avatar.
Hot Stuff is offline   Reply With Quote
Old 07-25-2012, 06:39 AM   #9
stainlesscycle
Oddometer: 1,639
on the it175 the suspension is it's biggest weak point. swap in a set of yz forks/triples and check spring rate - all it175's are spring too soft unless you weigh 145lbs - and original springs are pretty beat up after 30 years..... change rear spring for a stiffer one. rebuild rear shock while you're at it (i can't remember if it175 81 is rebuildable, the earliest ones were not. but i assume it is). also check specs on the fork tube height in the triple trees - many set them back to even with the top, when they really should be at 50mm sticking out top (might be different for 1981 - i only know the j/k models)) the motor is what it is, runs good mid/top, not bad low grunt, but nothing like the it200, so maybe figure a flywheel weight, or work on squish/porting. the it175 motor shifts better than the it200, i'll give it that for sure.
current bikes
Old 07-25-2012, 12:19 PM   #10
Highside>Lowside OP
Hairier Than Thou
Oddometer: 821
Eek
What I would really like to know is whether I can swap a later right drive 175 or 200 into my 81. How similar are the mounts?
Times are GMT -7.   It's 01:20 AM.
