Old 07-23-2012, 05:30 PM   #1
Super rider OP
Super rider's Avatar
Oddometer: 44
Turn signal stumper
All of a sudden my left turn signal on my 75/6 won't work. Neither the front nor the back. I checked the wires and the fuses and can't find anything wrong. They were working fine yesterday now nothing. Any suggestions?
Super rider is offline   Reply With Quote
Old 07-24-2012, 07:17 AM   #2
oldroadie
Two wheel addict
Oddometer: 468
How about the switch? Can you reverse the leads on the relay to test the left side using the right throw of the switch?
oldroadie is offline   Reply With Quote
Old 07-24-2012, 08:53 AM   #3
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,629
I'd also check the relay. Of my three /6's, I don't have one decent relay. The best one you have to jiggle every once in a while to get the turn signals to work right.
crazydrummerdude is offline   Reply With Quote
Old 07-24-2012, 11:08 AM   #4
Super rider OP
Oddometer: 44
yeah its probably the relay. the front one used to not work while the bike was off, but would work when it was running. The back always worked. I just put in new LEDS in the back and they were all working fine. Now the back led yellow comes on but doesn't blink and the front doesnt come on at all. I hate wiring :)
Old 07-24-2012, 11:19 AM   #5
Ron from BC
Ron from BC's Avatar
Oddometer: 1,386
The left turn signal on my 90/6 just started to go on the fritz too. I can get it to work if I find a sweet spot on the switch itself which it never required before. It only gets ridden a dozen times a year.
Could this too be the relay? Hrmmmm
'02 BMW R1150 GSA
'06 Kawasaki KL250H Super Sherpa
Ron from BC is offline   Reply With Quote
Old 07-24-2012, 11:34 AM   #6
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,676
The one on my 100/7 has just failed. Indicators flashed but the warning light stayed permanently on. New transistors to sort it out cost $1
Rob Farmer is offline   Reply With Quote
Old 07-24-2012, 11:59 AM   #7
Jamie
Oddometer: 1,223
Put the stock bulbs back in and see what you get. It could be the flasher won't work reliably with LEDs.
Jamie is offline   Reply With Quote
Old 07-24-2012, 06:00 PM   #8
Super rider OP
Oddometer: 44
Thanks for all the suggestions. Here's what the problem was. The ground wire inside the light is attached to a metal bracket. That metal bracket must be touching the metal post that the light housing slides onto. That is apparently what causes the grounding to the bike. Being 30 years old the light housing is lose on the bracket and you can rotate it up and down and wiggle it around. Apparently it had become so lose the metal bracket was no longer touching the metal post, therefore no ground, ergo no blinker. I used a little glue to tighten up the light housing so it doesn't wobble around and problem solved.
Times are GMT -7.   It's 11:53 AM.
