Old 07-23-2012, 07:25 PM   #1
jhh OP
Guzzi Dork
jhh's Avatar
Oddometer: 22
New R80 mono owner with a bad oil leak - breather problem?
So today I picked up my new ride: a 1985 R80RT. I stopped by my house to pick up some more suitable attire, and when I come back out to ride it some more... oil everywhere. There's at least ~100ML of it all over the driveway under the bike, leaking from the "shelf" at the back of the oil pan.
My first thought was rear main seal, but... when I first test rode it, there was a little oil coming out of the airbox due to a split line. The owner (mechanic friend of mine) replaced it, and it stopped leaking. Now it's spewing even more out, however the oil that's in the crankcase is clean and clear looking, while the oil that's on the ground is black (not gear oil) and filthy. This makes me think that it's something to do with the crankcase breather/venting maybe spewing oil out from wherever it is and it trickling down behind the flywheel. There's also a lot of blowby if I run it without the dipstick inserted, however it doesn't smoke even when cold and runs very well - it also has very low mileage, at about 20K.
I won't have my shop manual in until next week - can someone advise me on how to get to the breather, or possibly anything else I should check? Maybe an exploded diagram?
jhh is offline   Reply With Quote
Old 07-23-2012, 07:38 PM   #2
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,607
If your breather is in stock configuration, it should leak any oil down the back of the crankcase. It all goes into the cylinders through the airbox. I'd pull the top off your airbox as well as the starter cover and see what's what. Sounds to me like a leaky oil pump cover or a rear main seal. After you give the breather a check, wait for your shop manual to arrive and then pull your trans off to see where the oil's coming from. Looks like you dove into the pool at the deep end.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler screwed with this post 07-23-2012 at 07:43 PM
Airhead Wrangler is online now   Reply With Quote
Times are GMT -7.   It's 11:32 AM.
