Old 10-31-2012, 07:51 AM   #1
Rockwell OP
Rockwell's Avatar
Oddometer: 670
Tune ECU Question
Can I disable both the SAS and the valve for the carbon canister with Tune ECU, and not have to use resistors to trick the ECU out?
Also, what cables are required to communicate with the ECU?
not all those who wander are lost | two earthlings ride around the world
Home | Photo Blog | The Route | The Bike | About Us | Participate!
Rockwell is offline   Reply With Quote
Old 10-31-2012, 08:24 AM   #2
Rockwell OP
Rockwell's Avatar
Oddometer: 670
Found this one on CJ's site: http://www.dualsportwarehouse.com/CJ...TUNE-C-KTM.htm
Other than software and a laptop, is this everything I will need?
Old 10-31-2012, 02:28 PM   #3
Desmofan
Desmofan's Avatar
Oddometer: 597
Yes, TuneEcu has 4 check boxes (EPC, SAS, Idle control, O2)-you can disable all with the software (leave idle control on).
I unplugged and threw away my charcoal cannister, leaving the wiring in: no fault codes or lights.
KTM990 SMT
BMW R1200 GSW
DRZ400S
Desmofan is offline   Reply With Quote
Old 10-31-2012, 03:09 PM   #4
Rockwell OP
Rockwell's Avatar
Oddometer: 670
Thanks.
Why would you disable O2? Will this ignore inputs form both lambda sensors?
Old 10-31-2012, 09:23 PM   #5
Desmofan
Desmofan's Avatar
Oddometer: 597
Yes it does. You really need to wade thru all 80 something pages of "990 got tunes ?" here in Orange crush. My SMT is tunecu mapped (from the website map library) ,with secondary throttles disabled and removed, o2 loop off, CPR airfilter etc, and it runs like a raped ape, but so smooth down low compared to stock.
KTM990 SMT
BMW R1200 GSW
DRZ400S
Old 11-01-2012, 12:51 PM   #6
Rockwell OP
Rockwell's Avatar
Oddometer: 670
Yes. I need to find the time to sit down and go through that entire thread. Just put in the order for my cable last night. Hopefully they'll have them in stock and shipped out soon. Will have the rest of the bike together this weekend.
Old 11-02-2012, 07:41 AM   #7
Vicks
gets stuck in sand
Vicks's Avatar
Oddometer: 3,204
You might want to do a bit more reading about turning off the O2 sensors and the effect it has on AFR during closed loop running at higher elevations/ambient temperatures.
2007 KTM Adv990S - Sold, 2010 KTM530Exc-Rally and 2012 KTM Adv990
530Exc Adventurization re-build
Vicks is online now   Reply With Quote
Old 11-02-2012, 08:26 AM   #8
Rockwell OP
Rockwell's Avatar
Oddometer: 670
I'll try to find that in the thread.
I'm pretty new at all this stuff, but, when you say "closed loop running", what feedback signals are you referring to when you use that term? There are throttle position sensors, O2 sensors, speed sensors, air temperature sensors, etc. I am assuming that most of these are used in the feedback loop for AFR output, but, if you disable the O2 sensors, is that still considered to be closed-loop since not all the required feedback is being received? Also, are there times when the system runs open-loop?
Maybe all this stuff is covered in the TuneECU thread? If so, I should probably get to that soon. Just need to find the time.
Times are GMT -7.   It's 06:26 AM.
