Old 09-20-2012, 06:11 PM   #31
avocadofarmer
Fruit Coot
Oddometer: 267
I've been running T6 for 6,000 miles and a year in temps from 30 to 100 (lots of 100 lately) and haven't had any clutch issues...
YMMV!
avocadofarmer is offline   Reply With Quote
Old 09-20-2012, 09:52 PM   #32
666
Agnostic and Orange
666's Avatar
Oddometer: 1,318
YMMV!
22k miles on rotella and no problems, no creeping , shifts excellent, very smooth. Never had problem finding neutral.
2006 KTM 950 ADV; 2006 KTM 525EXC; 2013 Tiger 800 street
Moab Ride Report http://www.advrider.com/forums/showthread.php?t=629423
Dusy Ershim Ride Report http://www.southbayriders.com/forums...ad.php?t=99109
666 is offline   Reply With Quote
Old 11-02-2012, 09:32 AM   #33
bighoss550
Grade "A" fancy
bighoss550's Avatar
Oddometer: 32
Originally Posted by bighoss550 View Post
ediehl all good then right? just oil jet cleaning? you mentioned you couldn't find a wire to clean it (?)... what did you do?
I have same symptoms, plus trouble engaging neutral. I guess ill flush the line again, and now the jet.
An further advice while im into it?
Finally got around to it. Basket nut could be spun by hand it was so loose. Torque'd that, and also swapped out inner most steel plate as it was scored. Simply used the next steel plate in the stack. Line bled several times too which needed it..
All is good, I'm back on two wheels and happy. Thanks to this and the other "clutch" threads for advice on all of this.
be good or be good at it
07 KTM 990A, 07 KTM 450 EXC, 05 Ducati 749D
bighoss550 is offline   Reply With Quote
Times are GMT -7.   It's 09:45 AM.
