Old 07-24-2012, 04:51 PM   #1
wildfirewaterloo OP
gk97
Oddometer: 1
Pissed Has this happened to anyone?
loosing a steel bag on a GSA-
it contained my suite and valuables- never knew these bags came off on there own.
Riding along on the highway comes off and never to be found.
be aware :
wildfirewaterloo is offline   Reply With Quote
Old 07-24-2012, 04:55 PM   #2
boxermoose
Now fully goosed
boxermoose's Avatar
Oddometer: 2,850
Beemerous casious ejectionious - they fly faster then RIM stocks plummet
Sometimes you get the ABAT....and sometimes the ABAT gets you
boxermoose is offline   Reply With Quote
Old 07-24-2012, 05:00 PM   #3
apexal
apexal's Avatar
Oddometer: 291
be aware :
What is a steel bag? Are you talking about an adventure aluminum case? There's stories on this forum about side cases coming off so it does happen.
Dover, NH
2014 R1200GS Racing Red
2014 KLR650 White & Black
apexal is offline   Reply With Quote
Old 07-24-2012, 05:52 PM   #4
WeazyBuddha
Carbon-Based Humanoid
WeazyBuddha's Avatar
Oddometer: 4,970
Really? I thought it was the Varios with that problem.
...and I got the adventure bags for my non Adventure GS. One more reason to bust out the worry beads.
A drunk driver killed someone I love
WeazyBuddha is offline   Reply With Quote
Old 07-24-2012, 07:08 PM   #5
Grumpee
Grumpee's Avatar
Oddometer: 21
It does happen , two buddies of mine lost a side case and the other his top case. Both BMW OEM cases. In both cases the latch securing the case to the rack opened?
I decided to secure mine with a spring pin, drilled a hole between the bracket of the rack and the bracket of the side case. Removable in two seconds and if the latch opens the case won't move.
Grumpee is offline   Reply With Quote
Old 07-24-2012, 07:13 PM   #6
grandelatte
Consistently Inconsistent
grandelatte's Avatar
Oddometer: 109
Were you in Colorado?
Found a BMW side bag on I-70 in Colorado
http://www.advrider.com/forums/showthread.php?t=810384
"You ain't lost if you got gas in your tank." - Tommy the KLR rider
grandelatte is offline   Reply With Quote
Old 07-24-2012, 07:28 PM   #7
David13
David13's Avatar
Oddometer: 617
There was another of those bags found near Denver. And another one lost near Detroit, last week alone.
I have heard of them being lost and found anwhere, every other week or so.
dc
David13 is offline   Reply With Quote
Old 07-24-2012, 07:31 PM   #8
Reryder
Onward through the fog...
Reryder's Avatar
Oddometer: 1,399
Tis an ancient BMW tradition the self ejecting bag, going back at least to Airhead days, when the standard precaution was a stout leather belt and buckle around the bag and mountings to hold it in place when the inevitable happened.
'77 Harley Ironhead 6,000 miles across Oz
http://advrider.com/forums/showthread.php?t=527966
Reryder (AKA Hopper)
1977 Harley Sportster
81 BMWR100RS
01 HONDA VFR800
99 SV650
Ancient Harley 45, Snortster (Sporty engine in a Norton), Norton Atlas, Honda 350/4, Ariel HS scrambler
Reryder is offline   Reply With Quote
Old 07-24-2012, 09:57 PM   #9
evilmedic13
Sarcastic & Fantastic
evilmedic13's Avatar
Oddometer: 938
Mine popped off one day. More than likely my fault, or so I've thought until now. Still pretty sure it me that fucked up, I have a semi-annual 3 screw up quota to fill.
Our greatest fear is not that we are inadequate, but that we are powerful beyond measure.
evilmedic13 is offline   Reply With Quote
Old 07-25-2012, 03:14 AM   #10
jdub
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,861
If the R1200GS Adventure aluminum side cases are installed correctly, the only way I could think one could come off accidentally is if the latch is not locked as it is a simple over-center latch design. Once the latch is locked, unless the lock breaks there should be no way for the latch to open and the bag to slide forward 2" on the solid metal mounts and then fall off the bike.
There's no way I'd not lock the latches on my bags when installing and then trust the latch to not pop open as it doesn't take much effort to overcome the over-center design when unlocked.
Current: 2014 R1200GSW
jdub is offline   Reply With Quote
Old 07-25-2012, 03:24 AM   #11
NoVa Rider
Oddometer: 2,936
Put your name, phone number on the bottom of the bag before that happens. . ..
NoVa Rider is offline   Reply With Quote
Old 07-25-2012, 03:49 AM   #12
rmarmbruster
Roba
rmarmbruster's Avatar
Oddometer: 160
The vario top box is useless they come off all the time without the bolt down kit supplied by BMW. Not sure the OEM GSA aluminium set.
Cheers
Roba.
Roba
rmarmbruster is offline   Reply With Quote
Old 07-25-2012, 07:25 PM   #13
rdwalker
Oddometer: 2,544
I forgot to lock properly the sidecases on my K12RS a few years back.
The best part was that, after I lost the right box, I re-rode the section of freeway and found the case!
The cover was ground down from spinnig on asphalt, but the body survived and no one ran it over. Lucky shot, it only cost me a new cover.
Also, had a fly-off of the Vario top box on my R12GS. I've been riding over a big hole in a dirt road and the box actually flew ahead of me! Only a few scratches resulted; I still use it, though now with the enduro mod (a pin that prevents the box from sliding forward and out of latch - it's not the bolt-down kit).
Robert in Northern NJ __ '09 R12GS, '03 R1150RT, '01 F650GS
-->> James Bay & North Road Solo Blitz -->> Patagonia / Tierra del Fuego Cappuccino Tour
-->> Trans-Labrador Highway Solo Blitz --->> South African Cappuccino Tour
rdwalker screwed with this post 07-25-2012 at 08:39 PM
rdwalker is offline   Reply With Quote
Old 07-25-2012, 08:02 PM   #14
Z50Pilot
Sparky
Z50Pilot's Avatar
Oddometer: 243
Top case
Cheers
Roba.
I have had the Vario cases on my 06 and 2012 GS's without any problems and I do not have the bolt down kit. About 70K miles and the top case is always on the bike. When riding two up my wife uses it as a backrest and tends to fall asleep.
I'm not saying that it can't happen, but I'm willing to bet that there is a lot of user error involved.
PJ
Never lend a friend your Pacific Coast. Unless you like scratches and want a beer annuity
Z50Pilot is offline   Reply With Quote
Old 07-25-2012, 08:45 PM   #15
rdwalker
Oddometer: 2,544
Originally Posted by Z50Pilot View Post
...but I'm willing to bet that there is a lot of user error involved.
That depends on situations. My own experience is that the sidecases came off due to me not locking properly - thus user error. Even further in the past, while touring PEI on my K100RS, I was chased down by a friendly local (these nice Canadians!) - the sidecase opened up and all my crap fell out. Still user error, indeed.
The GS Vario top case is a different story. The plastic will flex and allow the case to move a wee bit forward under impact. This allows it to slip out from under the latch. BMW corrected that and offers a retrofit for older cases: a pin that prevents it from moving.
They also offer a brute-force solution: the enduro kit is an extra bolt that screws the case down. Obviously, you cannot remove it anymore just by opening the latch. I decided against that inconvenience, I only applied the retrofit and it works for me so far.
Times are GMT -7.   It's 09:09 AM.
