Old 07-31-2012, 05:40 PM   #31
apexal
apexal's Avatar
Oddometer: 283
Originally Posted by jdub View Post
If the R1200GS Adventure aluminum side cases are installed correctly, the only way I could think one could come off accidentally is if the latch is not locked as it is a simple over-center latch design. Once the latch is locked, unless the lock breaks there should be no way for the latch to open and the bag to slide forward 2" on the solid metal mounts and then fall off the bike.
There's no way I'd not lock the latches on my bags when installing and then trust the latch to not pop open as it doesn't take much effort to overcome the over-center design when unlocked.
I looked closely at my Adventure side cases and have to agree 100%. But because of all the reported mishaps I'm thinking of a bit of insurance. It looks like I can run a couple zip ties through the inner gear tabs and around the side case frame rails.
Dover, NH
2014 R1200GS Racing Red
2014 KLR650 White & Black
apexal is offline   Reply With Quote
Old 08-01-2012, 06:50 PM   #32
Grumpee
Grumpee's Avatar
Oddometer: 21
Pictures of the hole in the bracket and the pin inserted to avoid the case from falling off. With this pin there's no way the case can come off (unless the pin snapped of course).
Grumpee screwed with this post 08-01-2012 at 08:31 PM
Grumpee is offline   Reply With Quote
Old 08-02-2012, 06:04 AM   #33
WoodButcher
WoodButcher's Avatar
Oddometer: 2,089
Originally Posted by bemiiten View Post
You can not remove the key from the aluminum Adventure panniers unless the latch is locked.
Well, almost. My topbox and right side cases you can't remove the key from the lock that hold them on the racks when unlocked, but the left side case I can. I've always wondered if somebody put the wrong lock/latch on that one case.
Rusty
2009 BMW R1200GS Adventure
WoodButcher is offline   Reply With Quote
Times are GMT -7.   It's 08:08 AM.
