07-26-2012, 07:47 AM
#1 |
Scope Creep's Victim
Oddometer: 2,212
Rim Job ... What size should I use?
This might be a loaded question ... but I am doing a 'StevenB' rear hub treatment to a '85 R80 (The Dobber) to make it a spoked wheel. This really means that I have a load o' options where the rear rim is concerned. The bike is now a 1000cc, dual plugged, larger carbed, extended swingarm, massive forked monster.
The question would be which rim should I lace up? These are the factors I'd like to take into account. 1. Final Drive choices. I have a good line on a 32/10, currently there is a 37/11 on it, and I could get a 33/11. I'd like for the bike to do 80mph on the highway and have the rpm's be reasonable < 5K. 2. Cheap tires and availability. Which dual purpose tire size is most common? 17" rim, 18" ... 19"? If I got a 33/11 final drive, I would probably keep the 17" rim that's on it. If I got the 32/10, I'd probably look into an 18" rim ... depending on what the outcome of this thread ... What have I forgotten? Are there more factors in play? Any advice out there? As always, Thanks in advance. Fred
Fred '85 R80RT G/Sified '91 R100GS Bumblebee Airhead Zen: Ride-Maintain-Repair-Ride On. |
07-26-2012, 08:04 AM
#2 |
More tacos than you
Oddometer: 5,115
Well. I'd go for the 33:11 if you're thinking of mostly highway. GSPDs have a 3.09:1 final drive, so 3:1 wouldn't be far off. You're current 3.36:1 is even on the low side for 800cc IMO, 3.2:1 could be a little low for 1000cc also. As for what size rim, the 130-17 is probably the easiest tire size to find anywhere and has the most options available. If you want to dish your wheel to the left a little more to fit a 140, you could move up to the 2.5"x18" rim as there are plenty of good tires made in 140-18 for KTMs. 120-18 is a little slimmer pickins though, especially outside the US, unless you're looking for full-on knobbies. Don't even consider 19". It's really only for MX bikes and you'll only find knobbies for it. Overall 130-17 is the most widely available and has the most options for dual sport tires.
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. Airhead Wrangler screwed with this post 07-26-2012 at 08:09 AM |
07-26-2012, 08:35 AM
#3 | |
Oddometer: 2,212
Exactly the information I wanted to have. Thanks Spencer.
07-26-2012, 08:48 AM
#4 |
More tacos than you
Oddometer: 5,115
I just remembered Anton's gearing comparison page. It looks like 33:11 would get you 84mph at 5000 rpm. Go check it out.
http://largiader.com/articles/gearing/
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. |
07-26-2012, 09:59 AM
#5 | |
Oddometer: 2,212
You see it's a bit of a wash with a 17" wheel and a 33/11, vs an 18" wheel and a 32/10. The 33/11 is ~6% taller than the 32/10, but the 18" wheel is 5.3% taller than the 17". The 17" rimm would give the swingarm more travel ... but the 18" rim would give a smoother ride. Loads to debate. I'm leaning toward the smoother ride, and loss of 1/2 of travel. But, I'm still on the fence.
