Old 07-29-2012, 08:42 AM   #1
MikeMike OP
MikeMike's Avatar
Oddometer: 4,150
Coil Stick removal suggestion
Seeing that the coil stick puller that arrived at the local dealer here when I ordered it 8 weeks ago was for an earlier type of coil stick (narrow head, not the tear drop shape), I was left with my...in my hands.
I found that by gently folding up the rubber skirt (reversing it) I was able to get a decent grip on it and began to patiently, very patiently and gently rock and pull the coil stick.
Cylinder 2 was fairly easy, only about 5 minutes. Cylinder one required a tiny squirt of WD-40 (without getting any on the inverted skirt) and about 10 minutes of patiently working it out.
Be careful, it is very, very tempting to lift on the rear extended piece where the wires plug in, but you really have to resist this. No pliers either. I thought about using the screwdriver trick the GS1150/1200 guys use but there is really not a great amount of space in order to fold up a rag and pry the things out. Also, the lip on the tear dropped shape piece is very narrow.
For me, it seemed that the rubber skirt gave me enough grip, but you have to go really easy and be patient.
Also, when you get all the plastic of the air chamber/batter carrier off, be careful with the plastic piece that remains below where the battery is carried. This spacer piece likes to get a little crooked. Also, watch for the seal on the crankcase breather hose where it bolts to the motor, mine was missing and I used a line of sealer that should hold ok.
I really think the proper puller tool, that $25 buck metal one that is for sale should be used, it probably makes a 15 minute and risky job (coil sticks are really friggin expensive) a breeze.
Moral of the story, in a "pinch" you might be able to get yours out with the method I used. Just be real patient.
Regarding the plugs, I used some copper based anti-seize on the threads (a very, very light application) and a normal drinking straw to screw them in. Just put the end of the drinking straw over the end of the plug (it will hold it suspended if it is snug enough) and then lower the plug in and gently start the threads. The idea here is that it is like using a piece of rubber tubing (that I never have sitting around) and the straw will slip if the plug is cross-threaded. I was able to use the straw to get the plugs all the way in and used an old socket I had (believe it or not, one that came from the first tool kit I ever owned back in 1971 when I worked on my liittle Kawasaki) and been keeping it all these years. It is a very, very narrow space in there. I wouldn't recommend using any socket unless it measures around 21 mm outside diameter or less. Mine measured just under 22 but had an old sticker on it. The sticker was actually rubbed off near the base, that is how little space I had. Just for giggles, I tried another socket I had and it did not fit and would have gotten stuck (very bad!). It is also worth checking the gap on new plugs, one of mine was out.
Other things, there is a new air filter design (well, new to me) that has a metal grid with two humps in it reinforcing the top (like an automotive filter) and the silicone rubber lip is noticeably stiffer. It also has a new part number and a 30% higher price.
Just thought I would pass this along, it might be helpful to someone.
MikeMike screwed with this post 07-29-2012 at 08:56 AM
Old 12-05-2014, 12:13 PM   #2
Effisland
Effisland's Avatar
Oddometer: 302
thanks
what's the resistance in one of those coils?
2010 BMW F800GS
Effisland screwed with this post 12-05-2014 at 01:15 PM
Effisland is offline   Reply With Quote
Old 12-05-2014, 12:27 PM   #3
Rider 101
Wannabe adventurer
Rider 101's Avatar
Oddometer: 1,106
Be a little careful using copper anti seize. It can cause embrittlement of steel at higher temperatures. Nickel based is far better. Loctite make a good product.
Alcoholno good story starts with salad
Rider 101 is offline   Reply With Quote
Old 12-05-2014, 01:22 PM   #4
Effisland
Effisland's Avatar
Oddometer: 302
In the case of flames coming through the throttle intakes...wonder if it would flame so much without a spark?
2010 BMW F800GS
Old 12-05-2014, 01:39 PM   #5
jengel451
1 Cool MotherF#$cker
Oddometer: 802
jengel451 is offline   Reply With Quote
Old 12-05-2014, 01:55 PM   #6
Effisland
Effisland's Avatar
Oddometer: 302
Originally Posted by jengel451 View Post
BIG SIGH
Beast baby has been down for the last month or so. Torrential downpours and darkness, no garage, then freezing and work/life balance and network testing I have been unable to successfully troubleshoot the problem.
I have the airbox off, injectors back in, throttle bodies exposed. Started it up, run crappy then flames and coughing out of the right hand side throttle body.
I have already changed gas (though not completely so I am about to do it again, and check fuel pump filter). and cleaned tank vent check valve. Removed spark plugs, the one on the right side was all rusty. With compressed air I sprayed out a whole whack of rusted bitlings out of the spark plug hole (with plug screwed in). Installed new plugs. Ran ok for a while, then started up same as before, A different thread...
2010 BMW F800GS
Effisland screwed with this post 12-05-2014 at 02:36 PM
Times are GMT -7.   It's 08:30 PM.
