Old 07-29-2012, 10:34 AM   #1
990 OP
BM Trouble U
990's Avatar
Oddometer: 117
Oil Change
Would it be a good idea to change the oil before the first 10000 km service (surley most wear takes place in the first 10000 km). What oil should I use and what is the oil change procedure ( 990 was beyond my mechanical ability)
Smith & Wesson the orginal point and click interface
12 BMW GS 800 Triple Black
08 KTM 990 Adv
07 KTM 300
990 is offline   Reply With Quote
Old 07-29-2012, 11:29 AM   #2
Hucker
Lost
Hucker's Avatar
Oddometer: 516
I assume you mean 1,000km, not 10,000km...
First service (break-in) is at 1,000km. On this bike, it is very easy to change the oil...
Remove bash plate (if installed; can be done with it in place, but I find oil from the filter makes a mess and spreads like cancer with the friggin thing installed)
Remove oil plug (10mm Allen needed) and drain
Remove oil filter
Install new filter
Reinstall oil plug with new crush washer
Reinstall bash plate (as needed)
Put bike on center stand if equipped
Fill with 2.9L 15W-50 (the newest BMW recommendation; see oil threads everywhere here on ADV)
As for changing the oil before the 1,000km mark, that's a personal choice...some do, some don't. I was in the latter group.
Tools needed:
10mm Allen key (or socket)
Oil drain pan
Filter wrench (depending on the filter tightness)
Whatever is needed to remove the bash plate...depends on brand...
Cush
Hucker is offline   Reply With Quote
Old 07-30-2012, 11:44 AM   #3
990 OP
BM Trouble U
990's Avatar
Oddometer: 117
Thanks for the great explanation on the oil change I meant changeing the oil after the 1000km service but before the 10000 km service ( I have 5000km on now). I have been riding the bike quite hard in top (between 8 and 9 thousand).
What brand of oil should I use? There is an old wives tale that says Castrol GTX is not good for a wet clutch?
08 KTM 990 Adv
07 KTM 300
Old 07-30-2012, 06:55 PM   #4
Hucker
Lost
Hucker's Avatar
Oddometer: 516
I refuse to get into the "which oil" thread.
Read this thread here to see why...lots of opinions on the matter.
Onto your other Q, some will agree with changing it every 3,000 miles or so, and others will say you are wasting your money...
Cush
Old 07-30-2012, 10:28 PM   #5
Nacho911
Nacho911's Avatar
Oddometer: 366
Motul 3000 Mineral
Nacho911
Nacho911 is offline   Reply With Quote
Old 07-31-2012, 05:40 AM   #6
redbastard
redbastard's Avatar
Oddometer: 1,035
oil change interval
My thought is the on year or 6000 mile oil change interval is a little long. No harm in changing the oil and filter a little earlier than that. Yes the oil change on n F800 is much easier than on a ktm 990 :)
redbastard is offline   Reply With Quote
Times are GMT -7.   It's 01:52 AM.
