07-29-2012, 02:53 PM
#1 |
Oddometer: 307
650t Doesn't Show Routes
OK, so I'm a noob at this, but this isn't working. I transferred a route from Basecamp on my Mac, which showed the exact path I was going to follow (a trail) to the 650t Montana. The route showed up on the 650t with the correct name. I took off for the trail, but when I got there and brought up the route, it only showed me the crow-fly direct path (which does me no good at all unless I'm on my boat or in my plane :) ) How do I get the the thing to follow the path on the ground, not connect me waypoint to waypoint? Shouldn't be this difficult....(I know a noob) Oh, the 650t has the 24k maps installed for my location along with the 100k maps it comes with.
'10 990 Adventure '60 BSA Gold Star Clubman (in process) '76 BMW R90S '85 Laverda RGS1000SFC (also in process) '12 Jeep Wrangler Unlimited Sport S |
07-29-2012, 05:15 PM
#2 | |
Road Captain
Oddometer: 9,364
Pain in the Butte Ranch Durango, Colorado - Calculated risk or forbidden fruit? |
07-29-2012, 06:41 PM
#3 | |
Long Haul Adventurer
Oddometer: 3,250
Cheers,
Cheers, Dan |
07-29-2012, 07:01 PM
#4 |
Oddometer: 307
Well, asecamp must be set up for on-road, because it shows the path following the trail on the computer, but when it's transferred to the 650t, it doesn't follow the route, it goes direct. I have the auto set up on the 650t, so I don't understand why it goes direct. These things are frustrating.
07-29-2012, 07:02 PM
#5 | |
Oddometer: 307
07-29-2012, 07:07 PM
#6 | |
Oddometer: 307
07-29-2012, 07:10 PM
#7 | |
Oddometer: 3,250
Cheers,
Cheers, Dan |
07-29-2012, 07:15 PM
#8 | |
Oddometer: 307
07-29-2012, 07:22 PM
#9 |
Procrastinators
Oddometer: 6,046
Setup/map, enable or disable each map through there. But it's usually a bad idea to have more than one map enabled at a time. Basemap is the exception; keep it enabled.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
07-29-2012, 07:36 PM
#10 |
Oddometer: 307
Thanks, I found it, again. I didn't know what it was for the first time I saw it. Anyway, a new twist. The 650t does not have the 24k topo of the SW loaded. I thought I had transferred it, but guess not. Is there some reason the 650t wouldn't want/let me transfer from the Mac to the 650t? Guess that explains ? why it showed the route direct? Hmm.
07-29-2012, 07:51 PM
#11 | |
Oddometer: 307
07-30-2012, 06:11 AM
#12 | |
Oddometer: 307
07-30-2012, 06:15 AM
#13 | |
Procrastinators
Oddometer: 6,046
07-30-2012, 07:16 AM
#14 | |
Oddometer: 307
07-30-2012, 08:04 AM
#15 |
Oddometer: 1,235
You are going to have to learn how to transfer the 24k Topos to the Montana. (I only have a 60cx now, and don't know anything about transferring maps to a Montana.)
Or you can convert your route to a track in Basecamp and download that track to the Montana - my recommendation no matter what map you have. Or you can create a finely sampled route in Basecamp and transfer that to the unit. |
