Old 07-29-2012, 06:15 PM   #1
TheMuffinMan OP
TheMuffinMan's Avatar
Oddometer: 3,703
Cylinder Missing!!
So I'm on a 7000 mile trip with 6000m miles down and an issue has come up. One of my cylinders has started misfiring when the bike is over 68 mph, but then it'll miss and idle on one cylinder for a few minutes (or the engine dies alltogether) If i keep it at 65 indicated (about 60 actual) it seems to happen much much less frequently. When giving it gas I get backfiring on acelleration/throttle after an episode.
I'm thinking it might be vapor lock, it doesn't seem fuel pump related, put a dr beans kit on a brand new pump 12,000 miles ago. Front carb throat is a little oily but not out of the ordinary. Carbs are securely clamped into the boots. The front head ticks a little at startup but it's always done that.
I'll see if it reoccurs tomorrow when the bike is cool. But figured i would ask for input since I'm about 1000the miles away from home.
"Civilize the mind, but make savage the body."
To the house of a friend the way is never long.
"Show respect to all, but grovel to none."
'12 690 Enduro // 690 Wiki
TheMuffinMan is offline   Reply With Quote
Old 07-29-2012, 06:21 PM   #2
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,532
At that speed any jets should be fully active, I would imagine. So a stopped up jet is unlikely.
The backfiring means that there is fuel being ignited, so you have flow. Supporting the jet theory.
I know that there is an occurrence called "heat soak" that wreaks havoc on the Isle of Man TT bikes. When they cut the engine in the pits, the heat from the engine literally soaks the entire bike, making it very difficult to start. With the heat wave that we're having right now, super heated air in the air box means less air density. Possibly enough to not allow ignition within the cylinder? Going by this theory the faster you go the worse it gets.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee
Katoom119 is offline   Reply With Quote
Old 07-29-2012, 06:45 PM   #3
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 829
Balance the carbs they could be out of sync.
I've had a 950 and a 990 exhibiting these characteristics before.
Some TPS tuning and a Carb Balance worked.
Max
Da oggi la strada
é senza limiti
MAXVERT is offline   Reply With Quote
Old 07-29-2012, 07:08 PM   #4
TheMuffinMan OP
Oddometer: 3,703
Max
Hrm, this is possible. I didn't have a flowmeter to sync the carbs at the last valve check 1200 miles ago. I stupidly removed the vacuum hose nipples and blocked the ports. Because I bought a flowmeter, but forgot to bring it on my trip.
Could definitely be heat soak, I had been running the bike all day with no stops except gas really. And it didnt start until I came down into a hot valley.
Old 07-29-2012, 08:49 PM   #5
corndog67
Oddometer: 867
Mine is missing on one hole when idling or putting around on the pilot circuit. My mechanic buddies are about 99% sure the pilot is plugged or there is some crap in the float bowl causing an obstruction. Off the pilots, it runs real good. It's coming apart very soon, and I'll post up.
Ducati S4 916 is history.
KTM 950 SM, my main squeeze now.
1970 CT-70
And now, an XR75,
corndog67 is offline   Reply With Quote
Old 07-29-2012, 08:49 PM   #6
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,149
How about telling us WHERE you are.
There is someone sure to be close by who might be able to lend a hand with tools and a place to work on the bike.
Just my .02
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
WWW.DSM8.whereamiriding.com
DSM8 is offline   Reply With Quote
Old 07-29-2012, 09:16 PM   #7
TheMuffinMan OP
Oddometer: 3,703
I'm near Seely Lake, Montana along Highway 83.
Old 07-29-2012, 11:40 PM   #8
TcRulz
Oddometer: 270
What about one of your coil sticks or spark plugs breaking down when they get real hot. You could pull the plugs and read them to see if there wet (from unburnt fuel) or dry (from no fuel). Might have to do this while it's happening which could be a pain (pun intended)
TcRulz is offline   Reply With Quote
Old 07-30-2012, 12:57 AM   #9
mousitsas
Oddometer: 2,138
Is it speed related or rpm related? If it is rpm related, chances are it is electrical. If speed related then a fueling issue.
Old 07-30-2012, 01:39 AM   #10
68deluxe
68deluxe's Avatar
Oddometer: 9,594
Originally Posted by tcrulz View Post
what about one of your coil sticks or spark plugs breaking down when they get real hot. You could pull the plugs and read them to see if there wet (from unburnt fuel) or dry (from no fuel). Might have to do this while it's happening which could be a pain (pun intended)
+1
2010 KTM 990ADV
2004 KTM 250SX
68deluxe is online now   Reply With Quote
Times are GMT -7.   It's 05:21 PM.
