Old 07-29-2012, 06:28 PM   #1
IAfire OP
Oddometer: 42
front steering shutter
Okay i have k60 on the front and about 28lbs in it am going to try pumping it up a little higher. But i have a little bit of a back and forth shake in the bars when i let go in the 25 to 50ish mph usually smoothes out a little above that to non existent most the time. You guys have any other suggestions of what to try i bought so new fork oil and may replace the fork oil make sure they are equal had a small leak when i had some crap in the seal but got it all cleaned and it quite leaking after that. Thanks for any input
IAfire is offline   Reply With Quote
Old 07-29-2012, 07:25 PM   #2
njoytheride
NJOYN' THE JOURNEY
Oddometer: 950
had the same issue with the K60. put on a TKC80 on the front and the wobble disapperared.. Love the K60 rear tire but the front tire had problems. Hope changing the front tire works for you too. <>< Njoy
njoytheride is offline   Reply With Quote
Times are GMT -7.   It's 02:10 AM.
