Old 07-30-2012, 07:40 AM   #1
crownhorse OP
Oddometer: 18
Question abs
i have a o7 gsa and the brake falure light is on no abs working need some advice
crownhorse is offline   Reply With Quote
Old 07-30-2012, 07:43 AM   #2
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,928
Have you done any work on the bike, dropped it, or has anything rlse changed? There are multiple potential causes for these kinds of issues.
Jim
Old 07-30-2012, 08:04 AM   #3
crownhorse OP
Oddometer: 18
abs
[QUOTE=JimVonBaden;19245189]Have you done any work on the bike, dropped it, or has anything rlse changed? There are multiple potential causes for these kinds of issues.
Jim [/QU
Old 07-30-2012, 08:06 AM   #4
crownhorse OP
Oddometer: 18
abs
friday the light came on and when i shut off motor and restarted the light went off , to day it came on and will not go off
Old 07-30-2012, 08:18 AM   #5
JimVonBaden
"Cool" Aid!
Oddometer: 41,928
How old is your battery? Changed tires recently? Done any maintenance recently?
Jim
Old 07-30-2012, 08:23 AM   #6
crownhorse OP
Oddometer: 18
abs
no, batt about 1 yr old
Old 07-30-2012, 08:25 AM   #7
crownhorse OP
Oddometer: 18
rear tire near time to replace, bike has about 31k miles
Old 07-30-2012, 09:28 AM   #8
TaterHarry
Redneck Emeritus
TaterHarry's Avatar
Oddometer: 1,538
There have been a few reports of 2007-models with ABS pump failures. Have you had the fluids changed regularly? The circuits should be flushed every two years. Neglecting this important service is the main cause of pump failure IMO.
OK with the worst case scenario out of the way - check for debris around the front ABS ring and sensor. Also check all the wires (front and rear) for chafing. Still nothing? Look for excessive metal shavings on the rear sensor; you'll have to pull the rear wheel to do this, be very careful with the soft Torx bolt, and be prepared to replace the o-ring (though they usually can be reused).
If you're still out of luck then you'll want to find a GS-911 and read the fault codes from the ABS controller. Good Luck
EDIT - I forgot to mention the handguards - since you have an '07 your handguards can twist and interfere with the brake lever - thus JVB's question about dropping the bike - but it doesn't always take a drop for them to twist.
TaterHarry screwed with this post 07-30-2012 at 10:48 AM
TaterHarry is offline   Reply With Quote
Old 07-30-2012, 05:12 PM   #9
JStancampiano
PhotoJoe
JStancampiano's Avatar
Oddometer: 334
Check this out:
:http://www.advrider.com/forums/showthread.php?t=803593
This company below fixed buddies 07 abs unit for less that $200.00 plus shipping. We got it back last week and it works great!!
http://modulemaster.com/store/
Joe
2007 R1200GS ADV, 1978 R100T, GL1800 wing
JStancampiano is offline   Reply With Quote
Old 07-31-2012, 06:26 PM   #10
mudmullet
Oddometer: 160
I have an 04 1150 and about went nuts trying to figure out why the ABS wasn't working. Servo worked, but not abs. Ran out of ideass and ended up getting a GS911 and it told me to replace rear abs sensor. Sensor looked good, no frays, dings, or busted anythings. Replaced it and everything's been running fine ever since.
mudmullet is offline   Reply With Quote
Times are GMT -7.   It's 12:30 AM.
