Old 08-02-2012, 08:18 AM   #16
devo2002
-Devo
devo2002's Avatar
Oddometer: 3,832
This is all talk until someone who has done this and reports their engine blew up or it went 100k+ miles.
Unless someone has ridden the same bike brand new, one via moto
Method, one via service manual, and ridden the same way, there is simply no way to verify which is better
2014 DL650 Vstrom
devo2002 is offline   Reply With Quote
Old 08-02-2012, 08:39 AM   #17
pretbek
pretbek's Avatar
Oddometer: 1,064
I thought this was pretty convincing:
Identical engines, "According to manual" on left, "Motoman method" on right.
I am a mechanical engineer and I understand and agree with Motoman's explanation of why he thinks his method works. It makes sense mechanically. You warm up the engine, you load the piston rings significantly under positive and negative pressure, then change the oil to remove possible contaminations.
If the only reasoning for preferring according to manual is "because the manufacturer said so", that is not much of a scientific argument.
pretbek screwed with this post 08-02-2012 at 08:39 AM Reason: Speling mistkae
pretbek is offline   Reply With Quote
Old 08-02-2012, 12:18 PM   #18
kirb
should be out riding
kirb's Avatar
Oddometer: 1,722
So, there is more scientific methods used with Motoman? (see, that shit works both ways)
How many engineers do MFGs employ- many
How many engineers does Motoman employ- none
How many MFGs suggest the 'slow' break in- all
How many MFGs suggest the motoman style method- none
Why would every motorcycle MFG suggest the same style of break in, since I can remember- at least into the 70's?
At some point you have to look at the big picture.
A Ducati, some Guzzi, a KTM, and a Excelsior...Indian in resto.
kirb is offline   Reply With Quote
Old 08-02-2012, 12:32 PM   #19
tcourdin
Resident Spooner
tcourdin's Avatar
Oddometer: 10,622
I just ride my new bike, and change the oil. Never had a problem. I've heard lots of different opinions in all my years of riding on how to break in an engine, none seem to matter as long as you're not bouncing it off the rev limiter when you leave the showroom.
My SPOT
tcourdin is offline   Reply With Quote
Old 08-02-2012, 06:27 PM   #20
bmac
Oddometer: 328
I do not agree with the statement that all MFG's recommend a "slow" break in. Generally, they suggest varied RPM's with no steady throttle. Many do suggest avoiding prolonged full throttle operation but that is not the same as "take it easy".
Loading the engine with varying throttle input is generally considered the correct way to break in an engine. Positive and negative pressure help produce a good ring seal against the cylinder wall. Easy, or steady state, throttle is not the way to go.
bmac is offline   Reply With Quote
Old 08-02-2012, 08:33 PM   #21
rallyhound
Macho stud guy
rallyhound's Avatar
Oddometer: 871
I'm a Motoman follower.
Klr650 with 45,ooo miles and Dr650 with 25.000 plus on it.
Both bike made a round trip journey of 6000 miles and used no oil whatsover.
Not even a drop.
You don't really think the OEM's can recommend you take your new bike out and ride it hard. There would be wrecked bikes all over the place.
It isn't about what's best for your engine with them.
They just cover their asses.
When it's all said and done, More will be said.
You dont have to wish me luck for me to know that I need it.
rallyhound is offline   Reply With Quote
Old 08-02-2012, 08:45 PM   #22
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,256
I'm no mechanic. I read things and some things make sense more than others. I ran in my old Buell Uly pretty much by the "Motoman book". That bike used no oil in the 12,000K miles I owned it. Pretty rare for a Buell!
When I bought my XC, I did kind of a Motoman/Calsci combo. The stopping/starting to allow the engine to slightly cool down made sense to me. My XC has never used a drop of oil, and it's pretty quick.
The methods make sense to me, and frankly, who wants to baby a new bike for 1,000 miles? Like I said, I'm no mechanic. At the end of the day, we make choices and we need to live by them. Frankly, I don't keep my bikes long enough to know long term. Happy with how they run while I own them though
Click Here!
2012 Triumph Tiger 800 XC
2008 Yamaha WR250R
1971 Lambretta DL
levain is offline   Reply With Quote
Old 08-02-2012, 08:49 PM   #23
protondecay123
protondecay123's Avatar
Oddometer: 466
My FJR1300 is eight years old with 50K on the clock and has never used a drop of oil either.
Sometimes the Lights are all Shinin' on Me
Other times I can barely see
Lately It Occurs to Me
What a Long, Strange Trip it's Been!
protondecay123 is offline   Reply With Quote
Old 08-02-2012, 10:44 PM   #24
mousitsas
mousitsas's Avatar
Oddometer: 2,750
Had an R1150GS
Broke it in with Motoman method
Kept it for 60k miles
Never used oil
Pretty rare for an R1150GS
Old 08-03-2012, 05:19 AM   #25
omeoxlv
omeoxlv's Avatar
Oddometer: 263
Originally Posted by DeejayP999 View Post
I fear that you've misunderstood the Motoman method.
There's nothing harsh or rough about it - and we're not "Getting away with it now because of superior engineering ability". In fact it's nothing new - I've seen the same method recommended for old Brit bikes, by one of the most renowned Brit Bike engine builders of the day.
So it's a sound, long established process.
It's simply a methodical system of loading and unloading the engine in order to ensure proper seating of the piston rings - surely a far better approach than simply following the age-old recipe of certain revs for a certain mileage.
In fact the only possible downside is that it may be a waste of time with some modern engines - ie those which are already run-in on the bench (doubtless using a similar method) before they even leave the factory.
So at worst you waste some time, at best you end up with a smoother, more efficient engine.
Your fear is correct. I did misunderstand and didnt go and have a look at it for myself. Quite agree with what you ( and others in same vein) say. Really stupid of me to make assumptions. Can only offer that recently in another forum there was a similar discussion which promoted the idea that you go out and "run the bike hard, flat out, dont worry about anything" I jumped to conclusion that this was similar. Apologies all round.
cheers Graeme
omeoxlv is offline   Reply With Quote
Old 08-03-2012, 06:08 AM   #26
ridelife1
ridelife1's Avatar
Oddometer: 2,246
same here.
i used to go to the marysville ohio honda homecoming every year before they shipped the goldwings overseas to be built. during the plant tour those technicians on the dyno runs ran it up hard to 60-70 mph to make sure everything was in proper working order. i think that whole break in thing is a thing of the past & as someone else wrote is something written by the bean counters & lawyers.
Originally Posted by Trailrider200 View Post
Went to the Marysville MD honda motorcycle plant a few yrs ago when they were still building Valkyries and Goldwings there. Took the tour through the assembly line, get to the intial startup/run dyno platform that ALL new bikes go to. Each bike was run through the gears to a top speed of 60 mph. The bikes were not run to redline, but the operator was far from easy on the rpms going through the gears doing his different tests. Valkyrie and GW engines are known for 400+K miles longevity and never burn oil. The motoman is right!
anybody who is around the building and tunning of new race engines on a dyno will tell u he is right. nobody puts 600 hundred easy miles on a race engine before it goes on the dyno.
ridelife1 is online now   Reply With Quote
Old 08-03-2012, 08:39 AM   #27
Kawidad
Kawidad's Avatar
Oddometer: 4,808
I neither agree or disagree with the method, but...............
Who is "Motoman"?
What's his name?
What's his training?
What's his education?
What's his expertise?
What's the engineering behind his methodology?
There's anecdotal evidence, but that's not science, so where is the science?
BTW, those are rhetorical questions mostly, but before you decide what break-in method you use, you have to at least ask those questions.
For me, when I recently purchased my new motorcycle I did ask those questions of myself. To me, the answer was clear enough so I did it by the book that came with the bike.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is online now   Reply With Quote
Old 08-03-2012, 05:01 PM   #28
Strokizator
Strokizator's Avatar
Oddometer: 245
I've used the motoman method on all dirt bikes that received a top-end kit. I've used this method on street bikes too. Or you can go by the manual which was probably written by some guy using last model's manual for a template as did the guy who wrote that one, and so on. It's your bike do whatever you want. Sharing of information shouldn't be criticized. As far as anecdotal evidence goes, I think the pictures speak for themselves.
4 metal plates, 28 screws, titanium shoulder & surprisingly little talent.
Strokizator is offline   Reply With Quote
Old 08-03-2012, 11:09 PM   #29
porkandcorn OP
FortesFortunaAdiuvat
porkandcorn's Avatar
Oddometer: 296
Great Discussion
Thanks everyone for your input. It's been an interesting topic to watch.
In the end, I decided to apply varied throttling and acceleration/deceleration cycles in all the gears, but did so - and will continue to do so - completely within the parameters of the Triumph's recommended break-in. I agree that those two techniques are not new, nor the exclusive domain of this infamous "Motoman" character. But I will credit him and his devotees of making me think more deeply about the topic and approaching my break-in from a slightly more educated standing.
porkandcorn is offline   Reply With Quote
Old 08-05-2012, 10:12 AM   #30
mousitsas
mousitsas's Avatar
Oddometer: 2,750
Who is "Motoman"?
What's his name?
While searching for this method in da net, a while ago, I came across several articles from older days by race mechanics who actually have been using thiis same method in their race car engines. So, it is not something new really. I believe it became known as the 'motoman method' in da bike world, for some reason. Oh, don't ask for links, that was many years ago.
Times are GMT -7.   It's 11:53 AM.
