Old 08-04-2012, 06:21 AM   #1
georgej OP
Oddometer: 181
1974 dt400
I have a chance to get a DT400 for $800. the bike is stock and running. The owner tells me the woodruff key broke and he replaced it and it broke again.He replaced it again and said the problem is that it need the correct one from Yamaha. This is the only known problem with the bike. And no title. What do you think? It would make a good woods bike wouldn't it?
georgej is offline   Reply With Quote
Old 08-04-2012, 05:32 PM   #2
Bleary
Oddometer: 20
I think '75 was the first year of the 400. This was probably made in '74 as a '75 model.
Woods bike? I guess it depends on how fast you want to go. Suspension is not very good and they are pretty darn heavy. But if that was the bike I had... it would be my woods bike until I could get something more modern and lighter.
Yes, get the correct woodruff key. You may still have issues if where the crank contacts the flywheel is buggered up. You may have to use some lapping compound to make sure you have good contact. Also you have to replace the crank seals, its not that hard but it must be done so you don't suck air and seize the piston.
Bleary screwed with this post 08-04-2012 at 05:39 PM
Bleary is offline   Reply With Quote
Old 08-04-2012, 10:15 PM   #3
Shocktower
Shocktower's Avatar
Oddometer: 9,454
Yeah the magneto will slip with a greasy shaft, and break that thing, clean the shaft and magneto taper Oh yeah it is a fine woods bike
Alexa Drew Nov 9 1995- Oct 28th 2004 Miss you baby
'08 KTM 530 EXC
79 RD 400 Daytona
Shocktower screwed with this post 08-04-2012 at 10:16 PM Reason: didny say enough
Shocktower is offline   Reply With Quote
Old 08-05-2012, 01:10 AM   #4
Hunsta
Have guns will hunt
Hunsta's Avatar
Oddometer: 5,457
Hell yeah. Yes the 400 replaced the 360 in late `74. They are "the ducks nuts Max". Suspension is and will be a bit wooden, but I have always had the opinion that if you can ride the wheels off something that really wooden, you`ll be so much better when you step up to the 21st century.
The bikes a classic. Get it for the hell of it. They dont make em like this anymore.
I REALLY AM A NICE GUY. JUST ASK ANYONE WHO HASN`T MET ME.
Hunsta is offline   Reply With Quote
Old 08-12-2012, 06:20 PM   #5
georgej OP
Oddometer: 181
I got the bike,paid $500 for it. I started a new thread stating I got this bike and probably shouldn't have(started a new thread).i apologize in advance to those I have annoyed or offended.
Times are GMT -7.   It's 03:50 PM.
