Old 08-06-2012, 06:41 AM   #1
alongat OP
alongat's Avatar
Oddometer: 1,255
FIXED ! ! ! 2008 KTM 690 Enduro stalling / no start AND cannisterectomy help please
So my bike is currently apart chasing the dreaded occasional stall / won't start again / wait anywhere between 3 - 20 minutes for restart issues. Once in a while, it stalls and then I can't restart it until I wait some insane, undefined period of time - perhaps could be a clogged fuel filter overloading and overheating the fuel pump as I've read is suspected in other threads of similar symptoms...
1- I've taken the fuel pump out and all looks good
2- I am off to my local auto parts store to get a generic fuel filter replacement (and hose clamps) instead of the KTM OEM unit (which looks quite dark - assuming it's dirty)
3- the screen at the bottom of the fuel pump seems clean and perfect - no black or white debris as described in other threads - literally looks brand new
4- everything inside the tank seems as it should be and clean - no dirt or anything else came out, no loose hoses, etc...
Well, since I have the bike half-apart, I noticed that the previous owner did what I would call a "partial cannisterectomy" - one of the hoses that comes out of the charcoal canister is bent over and tie-wrapped to seal itself - no idea if this is right or not but I thought while I'm in there and have everything apart, I might as well remove as much unwanted emissions stuff like the canister, etc but I couldn't find any threads that describe the required parts, process and hopefully some pictures to help me along.
Can anyone share a link or something with me while I'm at this today? For reference, the bike is a 2008 690 Enduro with an FMF Apex muffler and an aftermarket air filter (foam, two round chambers, well-oiled - brand unknown) and the bike has a three position switch mounted on the handlebar for engine map switching...
Thanks in advance everyone
Thanks in advance
Toronto, Canada
KTM 1190 ADV, KTM 530 EXC
Gone: Ducati 999R, KTM 530EXC, KTM 990ADV-R, KTM 950ADV, KTM 690, KTM 640ADV, kTM RC8R, Ducati 996S, Yamaha R1
And how can this be? For he is the Kwisatz Haderach!
alongat screwed with this post 08-16-2012 at 04:59 AM Reason: Update to title...
alongat is offline   Reply With Quote
Old 08-06-2012, 07:33 AM   #2
SKINNY
SKINNY's Avatar
Oddometer: 668
This thread will point you in the right direction for the canisterrectomy...
http://www.advrider.com/forums/showthread.php?t=666269
As for the stalling...
there must be at least 10 or 12 different possiblities...
most of them not easy to diagnose...
SKINNY is offline   Reply With Quote
Old 08-06-2012, 01:32 PM   #3
alongat OP
alongat's Avatar
Oddometer: 1,255
Thanks for the link.
Update: I changed the fuel filter with a different one similar to the NAPA filter I've seen in other threads. Bike started with no issue and I let it idle for the "15 minute reset". Within one minute, it stalled so I restarted it and started the clock again. It stayed idling properly for literally 15 minutes and 35 seconds then the idle began to hunt a bit, it decreased than it stalled. I restarted it, it idled low with some hunting and then stalled. I threw my wrench at the wall and put the bike back in the garage.
Now what? Any ideas? I'm afraid to try to ride it to my "local" KTM dealer for diagnosis (somewhat because I don't want to get stranded on the road and somewhat because most dealers do very little to diagnose problems and would rather just charge time and material for throwing new parts onto the bike).
A few other notable things (perhaps notable):
- The pump makes its priming sound each time I go to start the bike.
- I didn't notice any dimming of the headlight and the battery appears to be strong and healthy
- I have no idea what else to report
Any ideas???
Thanks again everyone
Toronto, Canada
Old 08-06-2012, 02:22 PM   #4
SKINNY
SKINNY's Avatar
Oddometer: 668
Check the fuel line connections at the pump...more than one person has found leaking connections that will allow starting, but bleed down below acceptable pressure after a while...
Some fuel pumps have wiring problems....
try a new fuel pump...
have the dealer check to see what map is installed for the FI and EPT
Old 08-06-2012, 02:56 PM   #5
Velociraptor
TrackBum
Oddometer: 1,139
Pump may be bad. Also injector could be clogged. Also could be electrical. Several inmates have had problems with bad rectifiers or poor coil connections.
I had one ride where bike kept stalling out and ended up being loose coil connection but seemed like a fuel issue.
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 08-06-2012, 03:05 PM   #6
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 929
throttle position sync MUST be done in addition to other things
replace the spark plug...the 690 is sensitive to spark issues. also look at the plug cap...mine was cracked
clean injector. if i open the line after or at the inline filter i disconnect the injector and flow a bit of fuel through....the hole in the injector is so small you will never see the shit that clogges it.
the last problem I had was stalling and it turned out to be the main/starter relay going bad. I would try the other things first starting with the throttle sync
good luck
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is offline   Reply With Quote
Old 08-06-2012, 05:48 PM   #7
alongat OP
alongat's Avatar
Oddometer: 1,255
argh ! ! ! ! ! ! !
Toronto, Canada
Old 08-06-2012, 07:31 PM   #8
SigPig
SigPig's Avatar
Oddometer: 217
Originally Posted by alongat View Post
argh ! ! ! ! ! ! !
Agreed.
My 690's fuel pump was failing intermittently and then stopped working all together. When replaced, the new pump fired up and the bike started. During the initialization cycle the bike died after only two minutes of idling. It will no longer start. There is a clicking noise from under the air box somewhere. The fuel pump still hums every time now where as the old one would not turn on at all so that is no longer the issue. It seems to have come up with a new problem now. Needless to say, I am very frustrated as well.
PS: I have just over 5000 kms on this bike. The only performance mod was replacing the fire hazard stock pipe with a Wings and Akra remap which was at around 1500 kms. Everything was working perfectly until I rolled 5k.
SigPig screwed with this post 08-06-2012 at 07:33 PM Reason: PS
SigPig is offline   Reply With Quote
Old 08-07-2012, 04:08 AM   #9
alongat OP
alongat's Avatar
Oddometer: 1,255
I'm taking off the FMF Apex muffler and putting the stock furnace back on to see if there is a difference...who knows - stranger things have happened...maybe a lack of back pressure is creating a lean mixture and fouling things once it runs for a bit.
Toronto, Canada
Old 08-07-2012, 05:53 AM   #10
alongat OP
alongat's Avatar
Oddometer: 1,255
Update:
FMF Apex muffler removed and original thermo-nuclear reactor installed. I did the 15 minute reset run on it -
1- it did not stall within the first minute as it's been doing lately (though when it has stalled within that first minute lately, it restarted immediately)
2- it ran the entire 15 minutes glitch-free with a steady / consistent idle speed
3- after 15 minutes, I shut it down and restarted it several times with no issues
WTF? I guess it really needs some back-pressure from the catalyst and the muffler design itself. I have no idea which map is loaded on the bike but I am prepared to try having my dealer load the Akrapovic map for the bike since it accommodates for less back-pressure. Could it be this simple? The most annoying things in life often are solved with simple solutions, aren't they? In any case, I believe that I am prepared to rule out the fuel pump at this point - check all electrical connections and inquire with my dealer about that optional map. Any other suggestions or words of wisdom?
Toronto, Canada
Old 08-07-2012, 06:41 AM   #11
SKINNY
SKINNY's Avatar
Oddometer: 668
I'd have the stock map re-installed and see if it will run with the FMF...then try the Akro....
Old 08-07-2012, 09:09 AM   #12
alongat OP
alongat's Avatar
Oddometer: 1,255
Good advice - thank you.
Toronto, Canada
Old 08-07-2012, 10:25 AM   #13
SnapCracklePop
Re-Noobified
SnapCracklePop's Avatar
Oddometer: 7
Update:
I wanted to keep mine quiet , but try to get rid of the heat so I drilled out the cat inside the muffler.
It stayed pretty quiet (quieter than my FMF Q4) but started stalling intermittently, and 'hunting' about at low rpms.
I did the 15-min idle thing , didn't help (it has the Akra mapping) .
I put the Q4 back on and it runs perfectly.
It really seems to me that it needs the backpressure to run right.
tho as always , YMMV.
- Rick
'08 KTM 690 Enduro
SnapCracklePop is offline   Reply With Quote
Old 08-07-2012, 02:13 PM   #14
alongat OP
alongat's Avatar
Oddometer: 1,255
Another Update:
Went for a slightly longer ride and it almost conked out on me. While waiting at a red light, the engine began to run up in temps (as expected) and I swear that when the fan kicked in (with two bars left up top of the temp range - as it always does with the stock temp / fan switch), it started to idle lower and then started to make its way toward a stall. I immediately gave it gas and kept the revs up. What I then noticed on the rest of the ride was that when the fan kicked in, when I revved it past idle, there was an obvious change in fan speed. I would expect some change but not as significant as it seemed to me. This suggests something like some power starvation / decrease in output to support the fan. If this is correct, I will bet that the fuel pump is also seeing a drop in current and perhaps that is what is causing the bike to stall (or even spark or anything else that is current-dependent). I am going to have a closer look at diagnosing the stator and battery tomorrow. I wouldn't hurt to check the condition of all grounding points and other vital electrical connections...
Anyone have any experience with stalling relating to low voltage from stator and/or battery performance / condition?
Thanks again - especially for letting me use this crowd as a sounding board and source of experience.
Toronto, Canada
Old 08-08-2012, 12:31 PM   #15
alongat OP
alongat's Avatar
Oddometer: 1,255
ARGH ARGH ARGH - I'm going to have an aneurism ! ! ! !
So I can now confirm that when this stall and no-start business occurs, the pump is NOT priming the system as when everything is fine.
Does this help or sound familiar??? Please...my dealer is awe-struck and lost...
Toronto, Canada
Times are GMT -7.   It's 10:29 PM.
