Old 08-08-2012, 01:43 PM   #16
Velociraptor
TrackBum
Oddometer: 1,129
Originally Posted by alongat View Post
ARGH ARGH ARGH - I'm going to have an aneurism ! ! ! !
So I can now confirm that when this stall and no-start business occurs, the pump is NOT priming the system as when everything is fine.
Does this help or sound familiar??? Please...my dealer is awe-struck and lost...
Sounds like either the pump is dying or some upstream electrical issue so no juice getting to the pump. Are all the other electrical systems working (that you can check) when this happens?
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 08-08-2012, 04:09 PM   #17
alongat OP
alongat's Avatar
Oddometer: 1,246
Everything else works with no apparent issues. It's really strange - I rode 40 minutes at 130 kph on the highway today without a single glitch and then literally as soon as I exited the highway and hit the red light at the off ramp, it stalled and I had to wait nearly ten minutes before it started again. On the way home, same thing - flawless performance on the highway and then as soon as I was in stop and go traffic, it started stalling and not starting again. This leads me to believe that there may be a power starvation issue at idle (or near idle at low revs) - perhaps exacerbated by the current draw of the rad fan. I am going to unplug the stator tonight and measure its output to see if I can rule that out. Does anyone know how to measure and determine the health of a stator?
If I had any hair, I would pull it all out...
Toronto, Canada
KTM 1190 ADV, KTM 530 EXC
Gone: Ducati 999R, KTM 530EXC, KTM 990ADV-R, KTM 950ADV, KTM 690, KTM 640ADV, kTM RC8R, Ducati 996S, Yamaha R1
And how can this be? For he is the Kwisatz Haderach!
alongat is offline   Reply With Quote
Old 08-08-2012, 04:53 PM   #18
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 921
so you think its a electrical problem of low voltage at low rpm.........right?
but only after it gets hot................. right
you think it may be the stator is not putting out enough voltage/current at idle............? right
check the reg rectifier when hot.....that is the time you will notice beginning stages of rr failure
truth is there are many things that can go wrong with a fi bike that have similar symptoms
the more you can narrow it down the better you can trouble shoot it without as some have put it "throwing parts at it
i have had symptoms similar to yours with:
fuel pump beginning to fail
fuel pump hose knotted from the pump coming out of the holder
dirty injector
fouled plug (how do you foul a plug on a fi bike?? wtf)
cracked plug cap and doggy wire
master starter relay
low battery
good luck
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is offline   Reply With Quote
Old 08-09-2012, 03:39 AM   #19
alongat OP
alongat's Avatar
Oddometer: 1,246
dirty injector
low battery
good luck
With what little mechanical knowledge I have, I sort of believe it is electrical related - also somehow related to heat. Again, 40 minutes at 130kph on the highway without missing a single beat (assuming the rad fan never ran during that run) and then as soon as I get off the highway for a red light, bam!
I will figure out how to check the stator and regulator rectifier but you're right in saying that it will need to get right up to high temps when I do test them...somehow...
Toronto, Canada
Old 08-09-2012, 09:03 AM   #20
alongat OP
alongat's Avatar
Oddometer: 1,246
I ran a multimeter on it just now. Over 14 volts at rest, hardly any change when I turn the ignition on, no drop below 12.6 volts when cranking, running steady at 14.x volts when idling and higher RPMs. I let the bike run for 20 minutes at idle, letting it get good and hot and measured voltage - no change. I turned the bike off, good high voltage over 14V, cranked and started it again, no issues. I'm guessing my battery and stator / regulator rectifier are doing their job as designed.
Incidentally, the bike did not stall or not-start this time despite getting hot, etc.
I'm losing my mind...
Toronto, Canada
Old 08-09-2012, 09:29 AM   #21
SKINNY
SKINNY's Avatar
Oddometer: 662
With no fault indicators on your dash panel, it would seem to rule out a bad IAT or air pressure sensor....
try setting the map switch under the seat to the full power setting and see if that helps..
If the fuel pump is intermittent, either try a new pump or start looking for wiring problems.
One of my riding group had his 690 go completely dead which turned out to be several wires grouped together that had rubbed off the insulation
until they shorted...
SKINNY screwed with this post 08-09-2012 at 09:39 AM
SKINNY is offline   Reply With Quote
Old 08-09-2012, 09:34 AM   #22
JRP
Old guy
JRP's Avatar
Oddometer: 1,528
I'm don't own a KTM..but that won't stop me from giving advice
Have you tried taking off the fuel cap when it stalls to see if it might ba built up vacuum problem?
Could be a needed vent hose is pinched somewhere.
"What could possibly go wrong? " The Jerk
2014 Royal Enfield Continental GT
2012 TE 250
2010 F 650 GS
1983 R 80 G/S
JRP is offline   Reply With Quote
Old 08-09-2012, 11:48 AM   #23
StepOnIt
Assitoner
StepOnIt's Avatar
Oddometer: 1,031
t[s
I have a friend who had kinda the same sort of thing happen. It turned out it is the TPS is starting to go. They re-installed the map and seems to be working fine for now. There is no way unless you hook it up to see if it is wrong.
The road less traveled is the road I travel more.
"I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day." Dean Martin
StepOnIt is offline   Reply With Quote
Old 08-09-2012, 12:22 PM   #24
alongat OP
alongat's Avatar
Oddometer: 1,246
I finally caved and brought it to my dealer. The four codes that he was able to read were all voltage related. THAD and other settings are spot-on. He's throwing in a new battery and reloading the ECU map. He is confident that all my described symtoms match the causes. We'll see..he did also confirm that KTM has acknowledged a fuel pump issue and if he had one in stock, he would swap it. I'll have to take it home as is with the new battery and map-load to see what happens.
Toronto, Canada
Old 08-09-2012, 02:33 PM   #25
Uller
Uller's Avatar
Oddometer: 1,690
[QUOTE=alongat;19321648] KTM has acknowledged a fuel pump issue QUOTE]
Holy Shit.
I predict time will stop tomorrow....
Sorry about your running issues. It's no fun....
My response about fixes will be something very similar to Bob's so, I'll refrain.
Uller is offline   Reply With Quote
Old 08-09-2012, 02:38 PM   #26
alongat OP
alongat's Avatar
Oddometer: 1,246
[QUOTE=Uller;19322596]
Holy Shit.
Hey, guess what...same F*#KING problem still. I called my dealer who said "oh, it may be the fuel pump afterall - please bring it back to us so we can pressure test the pump. By the way, the pump is $428 and is on back-order for the next three weeks" I said "if KTM has acknowledged it as a known issue, ask them to give me a new pump" and he told me that the claim process could easily take 6 weeks but either way, they need to diagnose it again.
I suppose that if I need a pump, I should just get the cacycleworks.com pump for $129 instead, right?
Toronto, Canada
Old 08-09-2012, 06:17 PM   #27
Tncobra
Oddometer: 16
I didn't read all posts.
07 690sm
Did the dealer load both maps then do the 15 min on a dead cold engine? Try the throttle reset and idle again.
After new tips on my bike it did the exact same thing you describe. Slightly different bikes but stinks of the same prob. After the dealer loaded two "KTM" maps from KTMs website my bike ran perfect until the tank hose kinked. That hose gave me once a day stall problems for a few days until I spotted it.
Tncobra is offline   Reply With Quote
Old 08-10-2012, 08:00 AM   #28
alongat OP
alongat's Avatar
Oddometer: 1,246
I'm going to do the 15 minute cold start idle thingy now...
Toronto, Canada
Old 08-10-2012, 08:00 AM   #29
alongat OP
alongat's Avatar
Oddometer: 1,246
I've also ordered a fuel pump from CACycleworks just in case...
Toronto, Canada
Old 08-10-2012, 08:05 PM   #30
SigPig
SigPig's Avatar
Oddometer: 217
I didn't have the stalling issues with mine. Just the pump not priming therefore the bike not starting. Replaced with the ca cycleworks pump and so far so good. I'll have to ride it for a good week or so to make sure though.
2014 Beta Evo 250
2011 KTM 200 XCW
SigPig is offline   Reply With Quote
Times are GMT -7.   It's 07:42 PM.
