Old 08-06-2012, 12:28 PM   #1
ubercooper OP
Oddometer: 16
KTM 300EXC cylinder walls ok? (pics)
Im doing a top end on my 00 300 and noticed the cylinder walls looked worn... Is this normal?
There is no actual scoring, but Im wondering if it will be ok with a good cleaning or I should it sent off to be re-sleeved/plated ?
Thanks in advance
ubercooper is offline   Reply With Quote
Old 08-06-2012, 02:24 PM   #2
2trally
User Awaiting Email Confirmation
Oddometer: 62
Its hard to tell from a picture, but it might just need to be honed.
2trally is offline   Reply With Quote
Old 08-06-2012, 04:36 PM   #3
ubercooper OP
Oddometer: 16
Here are a few better pics of the 2 spots I am worried about.. I will try honing it tomorrow and see what it looks like... I have also heard of people deglazing the cylinder but that might be more trouble than its worth
Old 08-07-2012, 12:12 AM   #4
Twin-shocker
Oddometer: 1,673
I would guess that either the piston is totally worn out, or more likely dirt has got into the motor somehow.
You wont be able to hone Nikasil using conventional stones, but you can use them to remove material form a seized piston though. If the piston is worn/damaged then it would a good idea to get the cylinder re-plated, and if it looks like damage has been caused by dirt also check bottom end carefully.
Old 08-07-2012, 12:15 PM   #5
ubercooper OP
Oddometer: 16
Thanks guys.. Ended up going with a replate from PowersealUSA
Old 08-07-2012, 03:01 PM   #6
Shocktower
Shocktower's Avatar
Oddometer: 9,483
I have heard in England they use Nail polish to repair those
I am J/K Twin shocker
Alexa Drew Nov 9 1995- Oct 28th 2004 Miss you baby
'08 KTM 530 EXC
79 RD 400 Daytona
Shocktower is offline   Reply With Quote
Old 08-07-2012, 03:03 PM   #7
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,867
DIAMOND HONE! Thats what the shops use,1 very quick pass is all it gets,if the tolerances are there its good to go.
That does look like a good amount of dirt ran through it.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 08-08-2012, 04:41 AM   #8
Twin-shocker
Oddometer: 1,673
Where can I buy a diamond hone? Wok on Nikasil motors quite a lot and it would be a useful thing to have.
Old 08-08-2012, 01:23 PM   #9
PSchrauber
PSchrauber's Avatar
Location: Summer: Kemiö, Finland; Winter: North Germany
Oddometer: 869
Here for example:
http://www.diahon.de/de/Honleisten.html
PSchrauber is offline   Reply With Quote
Old 08-09-2012, 09:37 AM   #10
Twin-shocker
Oddometer: 1,673
Thanks..............looks way too costly for occasional use though? I get the feeling that something like a flex hone might be more suitable?
Old 08-14-2012, 07:28 PM   #11
Pmason
Pmason's Avatar
Oddometer: 143
From my research at ktmtalk, I decided NOT to use a hone on my cylinder. Most recommend using dawn soap and a green pad to remove the glazing. If you have any scoring or scuffing (something you can catch a nail on), a replate is the best option.
2008 KTM 300 XC-W
Pmason is offline   Reply With Quote
Old 08-15-2012, 11:36 AM   #12
Ever Onward
Time Killer
Ever Onward's Avatar
Oddometer: 856
Good idea, because if you hone the plateing to thin on the high spots, you run the risk of flakeing.
You can even start with the red pad before the green to clean up quicker.
Ever Onward is offline   Reply With Quote
Times are GMT -7.   It's 02:46 PM.
