Old 08-06-2012, 03:33 PM   #1
FORE! OP
pretender
FORE!'s Avatar
Oddometer: 51
AdvTank for the F800GS
Adventure Tank LLC now has an auxilliary tank for the BMW F800GS! This tank carries approximately 1.6 gallons and can be the difference between riding it out and pushing it out. The tank comes with an anodized aluminum top plate with convenient tie down points.
The mechanics behind the tank - the advtank drains into the stock tank as the fuel level is pulled down. The advtank effectively empties first - automatically while you are riding. No need to stop and unpack.
The advtank bolts into the stock grab-handle and mounting holes in the rear fender.
The advtank plumbs into your existing stock vent line system, and there is no need to remove your carbon canister.
This tank has been used and reviewed elsewhere at advrider.
For the month of August 2012, get 20% off your BMW tank order by using this coupon code at checkout - 'inmate'. Which makes right now, the perfect time to pick up one!
Come on over and see us at www.advtank.com
FORE! is offline   Reply With Quote
Old 08-06-2012, 06:42 PM   #2
GB
Mod Squad
GB's Avatar
Oddometer: 56,854
Read more about my experience with this great product here:
http://advrider.com/forums/showthread.php?t=770522
Old 08-10-2012, 07:58 AM   #3
neduro
Addict
neduro's Avatar
Oddometer: 12,022
I was involved with the design of this thing and wanted to add a comment or two.
Our design goals:
- 6 gallons total in the F800 = ~300 miles- Check!
- Low cost: this setup costs $240 on the deal FORE! is running right now- that's a very cost effective solution
- Easy to install/ remove - Check!
- Compatible with most stock and aftermarket luggage - Check! I believe Jesse is the only luggage that requires some work to install.
- Simple and reliable plumbing- Check!
Overall, this gives you a great improvement in range for not much money. It includes the rear rack as well, hard to beat that.
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Old 08-21-2012, 05:00 AM   #4
bigdon
Oddometer: 2,662
I just put one on my F800 last night. Now I see the 20% off. Crap!
Guess I should have done more research but I needed it NOW.
I'll be giving it a good test in a couple of weeks!
ADV Relay Rider 08 (The Texas Connection)
Ride Pooie Ride
Don't stop riding until you get to the crash , you might save it!
bigdon is offline   Reply With Quote
Old 08-22-2012, 12:57 PM   #5
bigdon
Oddometer: 2,662
I like it !
Ride Pooie Ride
Old 08-22-2012, 01:03 PM   #6
Graniteone
3,2,1...Beer me!
Graniteone's Avatar
Oddometer: 467
Great idea! Could this be used on a R1200GS? I would interested in one for my R1200GS. An extra 70+ miles could make all difference sometimes.
Graniteone is offline   Reply With Quote
Old 04-29-2013, 01:46 PM   #7
jwnsc
Hang in there.
jwnsc's Avatar
Oddometer: 329
Will this tank fit the 2013 F700GS?
If so, any modifications, necessary?
"The traveler sees what he sees, the tourist sees
what he has come to see." G.K. Chesterton
"Travel is fatal to prejudice, bigotry, and narrow-
mindedness." Mark Twain
jwnsc is offline   Reply With Quote
Old 06-02-2014, 01:55 PM   #8
SQ Beemer
Oddometer: 299
FORE!
Suggestions for top cases?
SQ Beemer is offline   Reply With Quote
Old 06-02-2014, 02:20 PM   #9
FORE! OP
pretender
FORE!'s Avatar
Oddometer: 51
Top Case
Any case that has a mounting system that bolts to a plate or a rack would work. Just need to drill the holes and go.
Scott
Times are GMT -7.   It's 05:34 PM.
