Old 08-07-2012, 11:30 AM   #1
cobrakai OP
Oddometer: 82
High Speed Wobble
Getting some handlebar wobble around 70mph and above, more noticeable under power, on smooth straight asphalt. I understand I need to increase Rake/Trail. To do this, I should:
Increase rear sag (lower ride height)
Decrease front sag (raise ride height)
Lower forks in clamps (raise ride height)
Increase tire pressure in the...?
Change damping?
cobrakai is offline   Reply With Quote
Old 08-07-2012, 11:48 AM   #2
JimVonBaden
"Cool" Aid!
Oddometer: 53,290
Make, model, year of bike? Yes, it matters.
Jim
JimVonBaden is online now   Reply With Quote
Old 08-07-2012, 12:33 PM   #3
the_gr8t_waldo
Oddometer: 2,122
before messing with the bikes geometry, first check the wheel bearings...both front n back.................................. fact is, while the front is proped up, check the steering head bearings as well.
the_gr8t_waldo screwed with this post 08-07-2012 at 12:40 PM
the_gr8t_waldo is offline   Reply With Quote
Old 08-07-2012, 01:01 PM   #4
cobrakai OP
Oddometer: 82
2007 BMW G650 Xmoto
I checked the steering bearings and they feel solid. No wiggle noticeable. The bike's only got 7000 miles all on the street, feels real solid still.
Old 08-07-2012, 01:36 PM   #5
Possu
de-nOObed!
Possu's Avatar
Oddometer: 5,221
Front wheel balanced? Rimlocks?
www.possu.smugmug.com
Possu is offline   Reply With Quote
Old 08-07-2012, 02:33 PM   #6
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,316
Did the wobble just start happening? If so, then something has changed and you need to find out what it is and then you can start figuring out how to fix the wobble.
GreaseMonkey is offline   Reply With Quote
Old 08-07-2012, 02:48 PM   #7
GH41
Oddometer: 822
Originally Posted by cobrakai View Post
2007 BMW G650 Xmoto
I'll bet the head bearing is the problem. To do a wiggle check the front end has to be off of the ground and the handle bar centered. If you have the dvd and tools just adjust it. The hardest part is getting the bike off of the ground. Why would you change the rake by moving the tubes up and down? Give BMW some credit for designing the damn thing. GH
GH41 is offline   Reply With Quote
Old 08-07-2012, 03:48 PM   #8
cobrakai OP
Oddometer: 82
No, it's not a new thing. I have noticed it less with the addition of more tire pressure, up from the stock 26f/29r to 32f/35r, but it's still there. I can induce the wobble by rocking the bars side to side. It doesn't get much worse, but it requires my constant feedback to keep it stable.
I did in fact lift the front of the bike using a stand, loosened the upper triple clamp, and torqued the bearing per the service manual. There is no slop there. The wheels have been balanced somewhat recently using static balancing.
Old 08-07-2012, 04:04 PM   #9
GreaseMonkey
Preshrunk & Cottony
Oddometer: 5,316
Did you do anything like install panniers, or change the seat or handlebars? Does it ever go away, or is it always there?
Old 08-07-2012, 05:17 PM   #10
Switchblade315
Switchblade315's Avatar
Oddometer: 5,691
new /old tires. bent rim?
When I die bury me upside down so the whole world can kiss my ass.
"My mind jumped off the high dive into the deep end of the gutter and took scuba gear with it" Me.
Switchblade315 is online now   Reply With Quote
Old 08-07-2012, 05:19 PM   #11
cobrakai OP
Oddometer: 82
No gear or extra weight on the bike at all. It's always been like this, I'm just now trying to figure it out.
This is not a dangerous tank slapper of any kind, it feels more like a wobble or general uneasy feeling. Other motorcycles I've ridden are very solid.
Old 08-07-2012, 05:24 PM   #12
GreaseMonkey
Preshrunk & Cottony
Oddometer: 5,316
Is the tire size the same as recommended? Might as well start there. You can put the bike up on the center stand and spin the tire to verify there is no physical defect. Sometimes you can use a screwdriver to pry the front pad away and move the caliper so it does not rub, and have it be friction free enough you can do a gravity balance check on the wheel.
And just so all the bases are covered, check the back tire for any wobble including swing arm play.
That should, keep you busy for 4 or 5 minutes.
Old 08-07-2012, 05:33 PM   #13
drmajor
drmajor's Avatar
Oddometer: 531
Wobble
Check your tires... Run your hand over the tire. Does it have high/lows....ie, cupping or feathering.??
Had this on my LT. New tire fixed it. On the GS, the cupping still happens, just usually don't feel wobble, but do feel a vibration in turns.
drmajor is offline   Reply With Quote
Old 08-07-2012, 07:36 PM   #14
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,078
Change damping?
It's most likly the tire. Been there done that, got the Tee shirt.
Tires I have used and wobble coefficent ( 0 = none, 10= uncontrollable at 70+ ):
MT-21, 10
XCMH, 8
908RR, 4
Unicross, 0 ( PS: up to 95mph )
Two bikes tested, XR650L and TE610e.
Of course if your head stock bearings, wheel bearings, or swing arm bearings are shit, you have a problem.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 11-21-2012, 01:17 PM   #15
gkgeiger
Every ride is an ADV
gkgeiger's Avatar
Oddometer: 643
I'm resurrecting this thread since I just developed this on my NC700X. The answer to greasemonkey's question is yes, I've done all the above. Did the bars first, no problem. Did the seat next, still no problem. Just installed panniers and top case today. If I take my hands off the bars it gets into a violent wobble instantly. If left alone it would turn into a tank slapper and I would crash. Up until today it was a steady as a rock. This machine only has 800 miles. I tried it with the panniers only, still does it but not as bad. I tried it with the top case only, same thing. If I take both off it doesn't do it but feels like it wants to. I know, don't take my hands off the bars, but somethings wrong.
Getting old is not for Sissy's!
Gene
'14 R1200GSW
'12 NC700X/D
gkgeiger is offline   Reply With Quote
Times are GMT -7.   It's 06:29 PM.
