Old 09-03-2012, 09:26 AM   #16
pingvin OP
pingvin's Avatar
Oddometer: 523
Originally Posted by Cowboy Don View Post
Damn, Too late for you but plenty of cheap options to bolt on a disc front end from mid 80's bikes. Magura do a retrofit hydraulic clutch kit, I had one on my XT.
http://www.magura.com/en/powersports...-off-road.html
The actuator fits in the same bracket on the engine where the stock one does. Just measure up the length of travel from the bracket to the clutch actuator arm and order the right kit.
These are good kits for those having troubles with their clutch.
OK, thanks, I might just buy a new TT/XT later. Right now I needed the cash for MX bike for my daughter anyway.
2006 KTM 950 SuperEnduro
2010 KTM 530 EXC-R
2006 Suzuki RM-Z 250
1981 Husqvarna 420 AE
pingvin is offline   Reply With Quote
Old 09-04-2012, 08:46 AM   #17
Euromad
Oddometer: 281
First disc brake was on a mid 70's Rokon Enduro. A late 70's PE 250 or IT 250 work well and still have parts available. Neither clutch is heavy.
Husqvarna 250's we used to weld on a longer clutch arm to make the pull easier. There was a aftermarket clutch lever- maybe EZ pull? Changed the leverage at the handlebar.
Euromad is offline   Reply With Quote
Old 09-05-2012, 06:30 PM   #18
WacoDirtryder
WacoDirtryder's Avatar
Oddometer: 303
Im sure it was KTM first with the hydraulic clutch i can remember being at the races and they stopped working and they were trying to bleed them but then if it didnt quit working something else on the bike would. They earned it Kant Take Much.
WacoDirtryder is offline   Reply With Quote
Old 09-07-2012, 08:51 AM   #19
pingvin OP
pingvin's Avatar
Oddometer: 523
Googled Rokon and that is really the perfect bike for me, at least from spec. Disc brakes and, even better, CVT transmission so no clutching. Where can i get one?
Do you know when? Must be from seventies. Bit of a KTM guy, had 6 KTMs and still got 2.
2010 KTM 530 EXC-R
Old 09-08-2012, 06:59 PM   #20
nachtflug
infidel
nachtflug's Avatar
Oddometer: 46,675
yes go for it. let us know how you like the pull start.
nachtflug is offline   Reply With Quote
Old 09-20-2012, 11:12 AM   #21
pingvin OP
pingvin's Avatar
Oddometer: 523
About to buy this 1981 Husqvarna 420 Automatic (modified to 430cc). Twist and go, no clutch, problem solved Only brakes left, will try with the drum brakes but minimize braking and see how works first.
2010 KTM 530 EXC-R
pingvin screwed with this post 09-20-2012 at 11:55 AM
Times are GMT -7.   It's 08:54 PM.
