Old 08-11-2012, 08:16 AM   #1
MPH OP
MPH's Avatar
Oddometer: 725
CS Seal Leak, '78 TS185
Hey All:
My original 1978 Suzuki TS185C has a small oil leak. After sitting for a week or two, there will be some oil on the bottom of the shift lever. I removed the left cover, cleaned everything out, retested, and it appears to be transmission oil (10W40), and not 2-stroke oil, so I'm guessing that it's coming from the countershaft seal, behind the sprocket.
Can this seal be replaced from the outside, or do the cases need to be split in order to get at it?
Thanks in advance for any advise/suggestions.
Mark
MPH is offline   Reply With Quote
Old 08-11-2012, 09:25 AM   #2
Twin-shocker
Oddometer: 1,673
Seal can be replaced from outside, but its easier if you have the special tools required, and if not it might be better to find a good shop to do the job for you.
Old 08-11-2012, 10:33 AM   #3
Shocktower
Shocktower's Avatar
Oddometer: 9,480
One way to remove them, is drill a small 1/16 hole 2 of them and use a drywall screw and some pliers, and tugg that bugger out
Alexa Drew Nov 9 1995- Oct 28th 2004 Miss you baby
'08 KTM 530 EXC
79 RD 400 Daytona
Shocktower is offline   Reply With Quote
Old 08-11-2012, 11:33 AM   #4
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,473
+1, may want to cut just the tip of the sheet rock screw off so as not to damage the sealing surface if you lever it out incorrectly. damhik.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is online now   Reply With Quote
Old 08-11-2012, 04:11 PM   #5
Shocktower
Shocktower's Avatar
Oddometer: 9,480
That's a good idea
'08 KTM 530 EXC
79 RD 400 Daytona
Old 08-12-2012, 11:05 AM   #6
MPH OP
MPH's Avatar
Oddometer: 725
Thanks for the suggestions, all. I have at my disposal the Harbor Freight Blind/Pilot bearing puller kit, perhaps that can be deployed to some degree (at least the slide hammer part of it).
I'll start my parts search...
Mark
Times are GMT -7.   It's 06:54 PM.
