Old 08-12-2012, 08:59 AM   #1
RFK OP
Oddometer: 121
How to remove BMW lock cylinders
I am having a hard time figuring out how to remove the lock cylinders from my BMW system cases and also my ignition assembly. I am trying to rekey my bike and have already rekeyed the gas cap with no problem but I am having a really hard time removing the cylinders from the cases and ignition. I have gone through a lot of old threads and I seem to be doing everything I am supposed to but I am not having any luck.
I need some guidance figuring this out.
Bob
RFK is online now   Reply With Quote
Old 08-12-2012, 10:10 AM   #2
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,359
The procedure for r&r of the ignition, seat and helmet hook lock cylinders is covered in the BMW REProm. The cases? Can't help you there.
def is offline   Reply With Quote
Old 08-12-2012, 11:48 AM   #3
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,130
Some times the case lock cylinders can take a bit of finesse. Wiggle the straightened paper clip or whatever you're using to remove them while you gently pull and slightly twist the key.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 08-12-2012, 12:05 PM   #4
roger 04 rt
roger 04 rt's Avatar
Oddometer: 2,262
Bob
This might help. It's about how to make the key removable unlocked but has the info you want.
I'm planning to show some photos of how to rekey if you get a new case and want to get it to match your other locks. I'll probably have the photos in a week.
I have seen a write up of how to do what you are looking to do which I found in a google search. The idea is to make it possible to remove the key in the unlocked position. Here's the link: IBMWR Lock Article
RB
Remove Lock
Lock Pieces from IBMWR
roger 04 rt is offline   Reply With Quote
Old 08-12-2012, 12:50 PM   #5
RFK OP
Oddometer: 121
Thanks so much for the advice... I finally got both the ignition and the bag locks out. What a pain in the butt... with enough jiggling and wiggling, the locks reluctantly popped out. I can't tell you the instant joy that came over me when they popped out:) Rekeyed and installed... this site rocks!
Old 08-12-2012, 03:55 PM   #6
MIXR
MIXR's Avatar
Oddometer: 662
Understand what's happening
It helps to understand what's being done with the system cases. All that you are doing is depressing the bottom wafer against its spring to release the lock. The wafer moves away from the detent slot and the lock freely comes out. That's why it requires a small diameter thin probe of some sort. What I find best is a small allen key (hex key). It has the strength, flat face and sharp edges on the hex to grip the slightly rounded wafer and push it back enough to release the lock barrel. There should be little need for heavy wiggling or hard pulling once the locking wafer is depressed against its spring. Aligning the probe (hex key) with the wafer is the only problem. The hex gives you a nice 'handle' that is out of the way, so it works better than a flat probe like a nail that has a pointed end and is stronger than a paper-clip that has too much give.
And so ends my 'Adventure' era (SOLD)
IBA # 39193
MIXR is offline   Reply With Quote
Times are GMT -7.   It's 02:38 PM.
