Old 08-20-2012, 07:27 AM   #1
pm_wizard OP
Oddometer: 72
1200 GS won't go into first gear from standstill
Before I take it in to the dealer under warranty, I thought I would get some ideas.
On my 2011 1200 GS I can't first time periodically select first gear from a standstill. If I am downshifting, no problem, but going from neutral to first after starting the bike, it feels like there is no first gear detente.. If I let the clutch out again I can then find first gear. The green "N" flickers and then goes out when it clicks into gear.
It is low mileage, less than 1,000 km on the bike
Thanks,
John
pm_wizard is offline   Reply With Quote
Old 08-20-2012, 07:30 AM   #2
ragtoplvr
Oddometer: 6,533
This is normal.
A dry clutch does not have any drag, so if teeth are not lined up, it will not go in.
What we all do is pull up on the lever with foot, let out clutch slowly, there will be a clunk, and you are in first.
Becomes automatic after a bit.
Rode long, ride far, the bike is fine.
Rod
ragtoplvr is offline   Reply With Quote
Old 08-20-2012, 07:31 AM   #3
WoodButcher
WoodButcher's Avatar
Oddometer: 2,111
That's actually fairly normal.
Rusty
2009 BMW R1200GS Adventure
WoodButcher is offline   Reply With Quote
Old 08-20-2012, 07:36 AM   #4
JLeather
Bike Butcherer
JLeather's Avatar
Oddometer: 298
I have a slightly different approach to offer. On my 11GS and my friend's 12GS the way I get into gear at a standstill is that I shift into first as I'm pulling in the clutch. That way the shaft is still spinning a little bit from the momentum even though the clutch has just become fully disengaged. It doesn't clunk and now it's second nature.
JLeather is offline   Reply With Quote
Old 08-20-2012, 07:59 AM   #5
Tbone
off-ramp slayer
Tbone's Avatar
Oddometer: 4,327
Sometimes I'll just pushed the bike back lightly with my right foot and it'll go in to gear too.
Tbone is offline   Reply With Quote
Old 08-20-2012, 08:20 AM   #6
pm_wizard OP
Oddometer: 72
Thanks everyone for the very prompt replies. The answers are very helpfull (and reassuring!).
I will go away and try again with these new techniques.
John
Old 08-20-2012, 10:07 AM   #7
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,916
As others have said - perfectly normal! Let the clutch out and back in, then shift into first within 1/2 second or two while trans shafts are still turning. It will go easily.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 08-20-2012, 03:14 PM   #8
JoshBMW
JoshBMW's Avatar
Oddometer: 353
This.
Josh
"Integrity, justice, courage, and action - without these, a person is of no consequence." Don Nelson my friend gone from us, 06/06/04.
JoshBMW is offline   Reply With Quote
Old 08-20-2012, 04:31 PM   #9
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,451
THIS
Don't do anything but, when in neutral, let the clutch out and then pull it back in. Click into first.
So easy a monkey could do it.
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug is offline   Reply With Quote
Old 08-20-2012, 06:08 PM   #10
ZachZ
Oddometer: 57
Yeah, this monkey does that! And it's easy
ZZ
'12 R1200gs
'78 R100S
Don't protect yourself by a fence, but rather by your friends.
ZachZ is offline   Reply With Quote
Old 08-20-2012, 07:25 PM   #11
Haydon
Haydon's Avatar
Location: Left coast a bit north of the big orange bridge
Oddometer: 45
Just re-engage (or double clutch) the clutch lever, then shift into first as normal.
"Do or do not, there is no try." Master Yoda
Haydon is offline   Reply With Quote
Old 08-20-2012, 07:46 PM   #12
blackfriar
blackfriar's Avatar
Oddometer: 226
Mine does the same thing and I think I've used all of the techniques listed above. I remember being a little nervous when I couldn't get my brand new bike in first gear to drive it out of the dealer's lot!
1966 Honda CL 160 sold
1998 Harley Davidson Sportster 1200C sold
2004 HD Lowrider
2009 KLR 650 sold
2011 BMW R1200GSA
blackfriar is offline   Reply With Quote
Old 08-21-2012, 08:14 AM   #13
Jim Moore
Jim Moore's Avatar
Oddometer: 14,215
Or hold the shifter down and ease the clutch out slowly. Accomplishes the same thing.
Jim Moore
Jax, FL
Pay the lady, PirateJohn, you thieving piece of garbage.
http://advrider.com/forums/showthread.php?t=949341
Jim Moore is offline   Reply With Quote
Old 08-21-2012, 10:49 AM   #14
Zeke013
Village Idiot
Zeke013's Avatar
Oddometer: 116
This is what my dealer told me. Works.
Sent from my Galaxy Nexus using Tapatalk 2
Zeke013 is offline   Reply With Quote
Old 08-21-2012, 01:59 PM   #15
bdarling
Weatherman
bdarling's Avatar
Oddometer: 428
As everyone has said above, this is totally normal. It is good to know what's actually happening inside your transmission when you shift through the gears. If you are interested, the link below is good enough to give you a basic understanding of a manual transmission.
http://auto.howstuffworks.com/transmission2.htm
Bottom line: the transmission has spun down to a stop and the engagement dogs on the shift collar are not alligned with the holes in the gear you're trying to select. Applying a slight drag to the clutch spins up the transmission just enough to align the dogs and holes.
-B
SoCal Dual Sport - http://www.socaldualsport.com
bdarling is offline   Reply With Quote
Times are GMT -7.   It's 08:07 PM.
