Old 08-20-2012, 09:15 AM   #1
wegimex OP
wegimex's Avatar
Oddometer: 50
900 gs
Anybody heard anything about a 900GS ? Given that the 650 was modified in design and engine (F700) I ask myself why the Husky Nuda 900 engine was not incorporated and the 800 was not modified at all. Maybe they are waiting for the new 1200 and then launch the 900 as a 2014 ? I am interested in an 800 (900 respectively) but certainly not with the old setup months before the new is ready for launch. Have heard rumours again rgd a 900 ADV also.
R100R Mystic 94, 1190 ADV T 2014
wegimex screwed with this post 08-20-2012 at 09:58 AM
wegimex is offline   Reply With Quote
Old 08-20-2012, 02:26 PM   #2
Camel ADV
aka Oso Blanco
Camel ADV's Avatar
Oddometer: 1,468
The 650 wasn't modified engine wise. It has been and remains a 798 despite the 650 and now 700 badging. Since they just did a face lift on the F8 and F7 I doubt there will be a complete redo for a couple years. If there was an F900GS for next year (or two) I expect they would have left the F series unmodified. Change=expense
Camel Tank auxiliary fuel tank for F series BMW twins. www.Camel-ADV.com
AT-BZ-CA-CN-CO-CR-CZ-CH-FR-DE-GB-GT-HN-IE-JP-KZ-KR-LI-LU-MX-NL-NI-PL-RU-SV-UA-US
'09 BMW F800GS, '14 KTM 1190 ADV-R
Camel ADV is offline   Reply With Quote
Old 08-20-2012, 03:20 PM   #3
wegimex OP
wegimex's Avatar
Oddometer: 50
What face lift for the 800 ? There are no changes but colours and the ESA and slip control options as far as I know while the 700 is modified optically and the engine has a changed software and 4 more HP plus a different gear ratio. The 800 has the same output and design i.e. is unchanged since the launch. Or so I believe
Old 08-20-2012, 03:27 PM   #4
iJabberwocky
iJabberwocky's Avatar
Oddometer: 225
2013 f800gs
I was in Touratech today and they just got there new 2013 F800GS. The only noticeable differences were the ESA of course, turn signals on left side so no more right hand push button for signal. The beak has two large holes going through it into the radiator area. Voltage regulator is a little more protected and the stock rear rack surrounding the exhaust and right side of the bike. The rear handle to ride two up had two little knobs in the middle of it, kinda weird. It looked pretty nice but am not regretting buying my 2012 a while back.
Iakona
2011 KTM 990 ADV R
iJabberwocky is offline   Reply With Quote
Old 08-20-2012, 03:38 PM   #5
Mav
Something witty...
Mav's Avatar
Oddometer: 3,713
The body work has definitely been tweaked on on the F800 for this model year.
2013:
2012 (albeit a lowered version)
As for an F9GS, I think it's more likely there'll be an off-road Nuda:
Mav
All the gear.. no idea!
Mav is offline   Reply With Quote
Old 08-20-2012, 03:39 PM   #6
wegimex OP
wegimex's Avatar
Oddometer: 50
Just what I said. No face lift that one right ? Have fun on the 2012 GS !! I'll keep my 08 1200GS (only 45 k so far) and still hope for the 900 ADV.
Old 08-20-2012, 04:13 PM   #7
itsatdm
itsatdm's Avatar
Oddometer: 4,903
No engine changes for the F800. The 700 got some new cams based on the HP and at what rpm it is delivered at, plus the need for premium gas.
There are enough spy photos out of the waterhead 1250gs, to be a 2013 model.
I expect BMW engineers had some input into the 2 Husky 650 models and the Nuda, since they are all Rotax derivatives.
In other words to many irons in the fire to deal with engines for the F800.
Husqvarna has already said the Nuda is not coming to the US for a while, if ever. I don't think the entire engine is for dirt, unless you are an expert. Big valves, lumpy cams and 13:1 compression. The only part I want to see changed is the displacement and crankshaft. OK maybe the suspension, if it is any better.
Maybe next year.
Old 08-20-2012, 07:39 PM   #8
gus007
gus007's Avatar
Oddometer: 111
I test rode a Nuda a few months back. The motor on that thing kicked ass. It felt totally different then the 800 but I don't know why they made it a 900.
I really wish someone would make a small lightweight twin with at least 180 mile range and decent components. Give it a strong subframe and keep it under or around 350 pounds. I don't get the push to just make bikes bigger. 700cc's should be enough power for my needs. Pipe dream I know.
gus007 screwed with this post 08-21-2012 at 02:59 AM Reason: spelling
gus007 is offline   Reply With Quote
Old 08-20-2012, 10:03 PM   #9
itsatdm
itsatdm's Avatar
Oddometer: 4,903
Amen, I would settle for 400lbs.
Old 08-21-2012, 02:01 AM   #10
Ceri JC
UK GSer
Ceri JC's Avatar
Oddometer: 2,462
It's unlikely that there will be a proper model in the range, but there's a fair chance you'll be able to get hold of one. I've been talking to Touratech about the possibility for a limited run of X-cross Nudas, or at least kits to allow customers to build their own, as they do with the Oryx. There was no word on one from Germany, but TT UK were trying to get the specs of the part used to build the one shown at Erzberg, with a view to getting a small run of the parts built themselves. Projected cost was to be in the region of 12,500, which I said seemed very reasonable.
When I rode the Nuda R, the overwhelming sensation was one of lightness, I think the X-cross would be a brilliant offroad bike for most of the stuff most people who ride adventure bikes go on. As with the F8, ground clearance would be the limiting factor in the tricky stuff. For fast open fire roads, you'd murder most dirt bikes with the Nuda's performance.
I like my bike because I can overtake 4x4s down farm tracks with a week's worth of shopping on the back.
Ceri JC is offline   Reply With Quote
Old 08-21-2012, 08:22 PM   #11
bodhizafa
How hard can it be?
bodhizafa's Avatar
Oddometer: 645
Doesn't Aprilla make something like this....SXV or something, supermoto though, probably has a weak subframe. Not close to 700 cc's either, OK maybe I'm wrong......
I'll have one if you do.....
bodhizafa is offline   Reply With Quote
Old 08-24-2012, 10:12 AM   #12
sebastianp
Oddometer: 261
I've ridden the Nuda 900 and, while it's a sensational motor, it's too thirsty and buzzy to be a replacement for the standard F800 engine, especially if it's meant to live in a GS.
sebastianp is offline   Reply With Quote
Old 08-27-2012, 01:58 PM   #13
RobertAmsterdam
www.twbastards.com
RobertAmsterdam's Avatar
Oddometer: 189
the dealer said in 2013 there is a new f800gs launched
2010 F800GS + TWBASTARD TW200
www.twbastards.com
RobertAmsterdam is offline   Reply With Quote
Old 08-27-2012, 02:43 PM   #14
ebrabaek
Oddometer: 4,757
Bouy oh boy oh boy ohhhh boyyyy...... new colors.......
Erling
Times are GMT -7.   It's 03:26 AM.
