Old 08-20-2012, 06:05 PM   #16
skidxr
Excuses
skidxr's Avatar
Oddometer: 396
I thought they sucked and couldn't wait to get rid of them. I have no idea if they did anything for balancing the tires. They did however cause the tire to completely deflate every time I checked the pressure. The little beads get stuck in the valve core and you sit there and watch it deflate then pull the core clean and re-inflate. Every damn time!!! Actually had one get stuck so bad I had to replace the core.
YMMV...
skidxr is offline   Reply With Quote
Old 08-20-2012, 07:38 PM   #17
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,043
I thought the dyna beads did a good job of balancing the wheels.
The problem with them, as I found out riding in Mexico for a few months this
Winter, is, the beads break down and the smaller pieces clog up your valve stems.
The result is that when you check your tire pressure the valve sticks open
and will only close when you get your air compressor out and refill the tire.
I'll never use them again.
I would also guess that they would trash the new tire pressure sensors
found on the new touring bikes.
Max
Da oggi la strada
senza limiti
MAXVERT is offline   Reply With Quote
Old 08-20-2012, 07:45 PM   #18
Hookapelli
Adventure-Junkie
Hookapelli's Avatar
Oddometer: 2,655
I use them. 6,000 miles on these tires so far and no where near needing replaced. No issues so far.
I only got 5,000 miles out of the stock tires and they were dead- but that's not a good reference since stock tires seem to suck for some reason.
I got nothin'....
Hookapelli is offline   Reply With Quote
Old 08-20-2012, 08:00 PM   #19
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,837
The instructions that came with mine said that you either had to use their valve cores with a plunger to keep the beads out or to hit the stock cores with a pump if air to clear the beads before check your air pressure.
I have about 800 miles on mine so far and I'm about to put them in my Duramax too. We'll see what happens.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 08-20-2012, 08:18 PM   #20
corndog67
Oddometer: 1,281
What's wrong with just balancing your wheels? Or do like I do, don't balance them at all, I'm not doing 150mph everytime I ride any more, and I don't notice any difference at all. And my bikes eat tires at the rate of 3000 miles or so for a rear, and 5000 for a front. Didn't matter if it was a 955 Daytona, 1200 Bandit, CBR1000, Ducati S4 or anything else, 3000 for a rear, 5000 for a front. I don't expect any different for my 950SM either.
corndog67 is offline   Reply With Quote
Old 08-20-2012, 08:36 PM   #21
GazzaFish
GazzaFish's Avatar
Oddometer: 595
Originally Posted by dpforth View Post
But the bottle demo impressed me:
Well there ya go. The bottle demo definately seems to prove the point... I stand corrected... (Probably still not going to use them.... )
GazzaFish is offline   Reply With Quote
Old 08-20-2012, 11:59 PM   #22
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,066
I would suggest you have your valve stem seating high.
This way the beads would stay clear from the valve.
However the beads rubbing and wearing the inside on the tube seems serious.
Cheers.
Old 08-21-2012, 06:09 AM   #23
wallache
wallache's Avatar
Oddometer: 378
YMMV...
That is pretty much my experience. Bought a cheapo Harbor Freight tire balancer and never looked back.
wallache is offline   Reply With Quote
Old 08-21-2012, 06:42 AM   #24
Katoom119
Katoom119's Avatar
Oddometer: 1,837
On my 21/18 knobbie wheels I don't balance them at all, and the standard wheel weights work well, but supposedly the Dynabeads reduce cupping and will keep balancing the tire as it wears. I figured for my 19/18 wheels I might as well try them once just to see.
Old 08-21-2012, 06:44 AM   #25
Noone
Oddometer: 1,437
Originally Posted by Deepc View Post
Whos got them? Where did you buy them? How much do you use? I have a 950A and I'm trying to extend the life of my tires.
Thanks,
JB
I use them on tube tires. They don't do anything for extending tire life, just used for balancing. A pain to get them into the tube but I'm satisfied.
Noone is offline   Reply With Quote
Old 08-21-2012, 12:21 PM   #26
knobbyjoe
knobbyjoe
knobbyjoe's Avatar
Oddometer: 525
I've had dyna beads in my Mefo's for 6,000 and the tires are still balanced well and never had a problem...yet. I think they are the real deal.
KJ
KTM 400 XCRW with Thumper Racing 450 kit and 450 cam 2007
KTM 450 XCRW with Christini AWD and Plated 2008 now has 520 Thumper Racing kit
KTM 990 Adventure 2008
knobbyjoe is offline   Reply With Quote
Old 08-21-2012, 07:44 PM   #27
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,597
Seems like if they work they would only work on road. Off road the beads would get bounced out of place by rough terrain.
What am I missing?
Yellow Pig is online now   Reply With Quote
Old 08-21-2012, 07:53 PM   #28
AdvGa
AdvGa's Avatar
Oddometer: 1,320
Originally Posted by Yellow Pig View Post
.... Off road the beads would get bounced out of place by rough terrain.
What am I missing?
True... when you are on ROUGH Terrain, it does NOT matter... but it does on Smooth Terrain where it does matter.
AdvGa is offline   Reply With Quote
Old 08-21-2012, 08:07 PM   #29
dpforth
no inline fours
dpforth's Avatar
Oddometer: 330
That and the fact that you'll need 4 oz to balance a rim lock.
This species has amused itself to death
dpforth is offline   Reply With Quote
Old 08-22-2012, 01:04 PM   #30
Helajames
Oddometer: 25
I have not seen but one post about running them with tubes, I Put some Kenda Big Blocks on to replace my stock scorpions and it is severly out of balance on the highway now.
this sounds like the ticket for those of us running Knobbies all the time but not sure if they will work with tube tires.
Anyone running this with tubes?
Jim
Helajames is offline   Reply With Quote
Times are GMT -7.   It's 08:39 AM.
