Old 10-27-2012, 02:21 PM   #1
dmftoy1 OP
dmftoy1's Avatar
Oddometer: 247
Pressure plate balance and clutch plate question.
Ok, so I'm going to be replace my rear main seal and oil pump o-ring. Took the clutch out today and I mic'd it @ 5.36mm and minimum appears to be 4.5 mm. As near as I can tell from the manual I've got about 2/3rd of the service life left. Would you replace it while you're in there or just go with it?
Ok, now for the more important question. Didn't realize that the 74's don't have any balance marks on them. I'm about 80% sure I've made the correct index marks on pressure plate and flywheel but is there any way to be 100% sure or is it a matter of tearing it all down and reindexing pressure plate to flywheel if I have noticeable vibration?
Any/all input gratefully accepted.
Have a good one,
Dave
dmftoy1 is offline   Reply With Quote
Old 10-27-2012, 02:33 PM   #2
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,662
I would use it. Some might see some advantage to fresher parts but I would rather spend money on stuff I think I need. Maybe I'm just cheep.
No worry about balance. The advice to mark the parts and return to original is over rated.
With the new seal, did you set to original depth with the tool? This is something that should be done. A lot of seals get driven in till they are flush with the engine block. They may work at this depth but it is more correct for the seal to be a couple of mm proud of the bore in the block. When I did mine several years ago I found the old seal driven in till it was flush with the surrounding rear face of the block. I could see by the part of the flywheel the seal rode on that it was running on the very edge of the flywheel. Installed new seal to a more proper depth so it rode a litter higher on the flywheel.
---Albert Einstein
Old 10-28-2012, 07:26 AM   #3
dmftoy1 OP
dmftoy1's Avatar
Oddometer: 247
Doing seal today so ill set my seal driver stops based on old one before I pull it. :)
Old 10-28-2012, 07:51 AM   #4
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,600
65%? I'd definitely use it.
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is offline   Reply With Quote
Old 10-28-2012, 08:18 AM   #5
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,662
That seal installer tool makes this job a lot easier. The rear seal is just a little too big to be driving in with a hammer and a block of wood. And it's difficult to get the right depth with a hammer.
---Albert Einstein
Old 10-28-2012, 12:45 PM   #6
ME 109
ME 109's Avatar
Oddometer: 2,941
Don't forget to block the crank!
Lord of the Bings, kangaroo farmer
ME 109 is offline   Reply With Quote
Old 10-28-2012, 02:47 PM   #7
Martian
Oddometer: 1,104
When I replaced my clutch plate, etc, there were no marks on the new parts. So, I put it all together before mounting it on the bike, and suspended the grouping from a piece of rope run through the middle of everything. It took several times of repositioning, but eventually, the flywheel/clutch assy stayed level when suspended from the rope. The bike is really smooth.
FWIW/YMMV
Tom
'93 R100R
'02 F650GS sold)
'93 R100GSPD(sold)
http://frommars.smugmug.com
Martian is offline   Reply With Quote
Old 10-28-2012, 06:01 PM   #8
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,190
I'd also continue with the original clutch disc. I like to get my money's worth out of stuff. Don't bin it till it's used up.
Some have been fairly close to balanced no matter how I positioned the parts, and others weren't. I suspend the parts like Martian and they come out smooth.
Old 10-28-2012, 07:39 PM   #9
bmwrench
Oddometer: 2,173
Whether you renew the clutch parts depends on what size motor you have. The '70-'80 clutch can barely handle a stock 1000cc motor, but is adequate for the 750-800cc motor. If it's an R100 and there is any grooving of the pressure plates or wear on the disk, it will slip.
bmwrench is offline   Reply With Quote
Old 10-29-2012, 03:35 AM   #10
ME 109
ME 109's Avatar
Oddometer: 2,941
I think the clutch in my 81rs is just about bullet proof.
I put a new friction plate in towards the end of the last millennium and it's still going strong
Old 10-29-2012, 05:57 PM   #11
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,397
Originally Posted by me 109 View Post
don't forget to block the crank!
+1
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
Times are GMT -7.   It's 01:05 PM.
