Old 08-21-2012, 11:39 AM   #1
Skylar OP
Tryin' not to die
Skylar's Avatar
Oddometer: 67
1984 R80RT Broken turn signal switch. Replacement options?
A plastic part on the inside of the left controls has broken and now the turn signal is actually stuck on left. I took it (somewhat) apart and saw the toggle's intact, but a piece connected to it is broken.
...I need a replacement turn signal regulator. I gather the R100 will also work, I'm unsure of what other models would bolt on a R80/7.
Should I keep checking ebay? Thanks for your time. - S
Skylar is offline   Reply With Quote
Old 08-27-2012, 06:58 AM   #2
Other Bob
Other Bob's Avatar
Oddometer: 448
Skylar,
My switch was intermittent and I broke the plastic 'frame' of the switch itself (the 'snap-in' tab) while removing it from the handlebar housing to clean it. I was able to glue the parts together with superglue and they worked fine. They're fairly well supported once inside the housing.
I don't think that BMW sells this switch as a separate part from the whole housing assembly. Take a look as Max-BMW's fische listing:
http://www.maxbmwmotorcycles.com/fic...9&rnd=08102012
I'm not aware of an independent source for these switches. I'll let you know if I come across one.
Bob
Other Bob is offline   Reply With Quote
Old 08-27-2012, 07:54 AM   #3
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,330
I got lucky and got a Euro left switch group on my R80RT when I got it I guess because the PO broke something as well. Mine now has the headlight switch which can be turned off.
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Times are GMT -7.   It's 12:24 PM.
