Old 01-25-2013, 09:40 PM   #76
stormsearcher
Oddometer: 975
protection
i am in the process of getting an xt660r and doing a big adventure trip.
looking at diet plans and protection.
exhaust- i like the metalmule but i also like the racing headers from OTR to which i am thinking of fitting 2x carbon danmoto cans. so i will need a huge bashplate and although i miss out on ground clearence i dont plan on hopping logs/etc/ just fast high speed desert runs. opinions please??
bash plate from B&B?
engine guards from HB?
barkbusters/
rear luggage rack
screen
how about 18" rears? as i like running mousse in tyres not tubes.
do i need KEV mod?
it will be a 2009 + bike.
Don't tempt fate,TAUNT IT!
stormsearcher is offline   Reply With Quote
Old 01-25-2013, 11:00 PM   #77
boneman660
Try Hard
boneman660's Avatar
Oddometer: 359
barkbusters/
rear luggage rack
screen
do i need KEV mod?
Yep, got all those mods apart from the engine bars & Kev Mod (have a Power Commander V)
All OTR gear apart from the B&B rear rack & of course Barkbusters guards..
So far, so good...
boneman660 is offline   Reply With Quote
Old 01-26-2013, 05:25 AM   #78
stormsearcher
Oddometer: 975
Hey Bone man r u using metal mule headers with Akra pipes? Did u get the headers separately?
Also if possible can you tell me what is the diameter of the exhaust where it joins the end can please ?
stormsearcher screwed with this post 01-26-2013 at 11:15 AM
Old 01-26-2013, 02:41 PM   #79
motormail OP
Supermoto Posty
motormail's Avatar
Oddometer: 459
Hey Boneman, is that just some heat shield tape you've got on the radiator hose closest to the header? How come you needed it, was it rubbing on the 2 in 1 header?
motormail is offline   Reply With Quote
Old 01-26-2013, 06:36 PM   #80
boneman660
Try Hard
boneman660's Avatar
Oddometer: 359
Hi mate, will measure up when the rain lets up....
The headers are OTR, got most of the mods all at once from OTR Germany.... I put the header tape on as a precaution. The headers run close to the radiator reservoir hose, so I thought it would be prudent. Also on the OTR website, the RallyRaid XT660Rs have tape on so thought it would be a good idea...
So far, so good...
Old 01-26-2013, 07:45 PM   #81
John 171
Oddometer: 116
Pannier Racks
Hi all,
Made some aluminium soft pannier racks to match my B&B rack. Also moved the blinkers up onto the B&B rack where they are more protected and fitted a smaller taillight and better mud flap.
Cheers.
John.
John 171 is offline   Reply With Quote
Old 01-26-2013, 08:14 PM   #82
boneman660
Try Hard
boneman660's Avatar
Oddometer: 359
Thumb Nice racks John 171
Nice work on your racks John.
Is there any possibilty of you posting a pattern, or photos without the rubber?
Would live to make some up myself. I gather you have attached them to the exhaust mounts?
Cheers,
Boneman
So far, so good...
Old 01-27-2013, 05:49 AM   #83
stormsearcher
Oddometer: 975
boneman
Hey bone man if you look on the OTR site they have racing headers, 4 mm bigger dial than stock but same layout, twin pipes. How much clearence do you get with 2 into 1? Am thinking twin racing headers with carbon cans from danmoto.I assume B&B fits this set up or swmotech bash plates and toolbox set up.also thinking 5 ltr rear tanks like Dakar bikes and lower exhaust cans. Opinions?
Old 01-27-2013, 03:43 PM   #84
motormail OP
Supermoto Posty
motormail's Avatar
Oddometer: 459
Ride report from WoopWoop on his White XT660R
http://advrider.com/forums/showthread.php?t=857704
Old 01-27-2013, 03:53 PM   #85
motormail OP
Supermoto Posty
motormail's Avatar
Oddometer: 459
WoopWoop's soft bag panniers
Anyone interested to know about WoopWoop's soft bag panniers check here. WoopWoop now uses Gotcha brand straps.....simple, effective and cheap, which can be found at Gotcha Straps
Old 01-28-2013, 01:27 AM   #86
motormail OP
Supermoto Posty
motormail's Avatar
Oddometer: 459
Hey WoopWoop, I did a search on heat shield tapes for the radiator hose...frig me there's hundreds, which one did you use?
Robo
Old 01-28-2013, 03:38 PM   #87
John 171
Oddometer: 116
Racks
Boneman,
" nice racks" yeah their not augmented either.
The racks are made out of 3.5mm aluminium plate 350mm wide and 300 high. They are mounted using 8mm high tensile bolts four per side. Two are screwed into the exhaust mounts and two into the mounts for the B & B Rack.
The spacers are made out of 20mm aluminium rod with a hole drilled up the middle for the bolts to pass through.You make them as long as the need to be so the racks clear the exhaust and whatever else they need to clear but the shorter they are the stronger the set up will be. It is important not to mount them to high so you can still double someone and the pannier bags seem to sit and take weight better if the straps are resting against the seat. The bike will handle better the more forward you mount them as well. I cant take the rubber off as I have glued them on with contact cement but the holes in the plate for straps etc. can be put where ever you need them for whatever brand bags you are using. (mine are Andy Strapz)
Cheers
John.
Old 01-28-2013, 04:42 PM   #88
John 171
Oddometer: 116
Bloody Computers /Learner driver.
Sorry about the layout of the last post.
Old 01-31-2013, 03:10 AM   #89
woopwoop
will think for food
woopwoop's Avatar
Oddometer: 5,590
Robo
Robo,
No mate, not me.......You mean Boneman perhaps?
woopwoop is offline   Reply With Quote
Old 01-31-2013, 05:22 AM   #90
boneman660
Try Hard
boneman660's Avatar
Oddometer: 359
Question Header Tape....
Robo
Mate, I got the tape from the local Autobarn I think. It came in a kit with metal cable ties for holding it in place. There were different widths, I went for the narrow one for ease of fitment. The tape's been on for over a year, still seems pretty sound...
So far, so good...
Times are GMT -7.   It's 12:15 PM.
