Old 08-22-2012, 10:47 AM   #1
Dadayama OP
Constant Adventurer
Dadayama's Avatar
Oddometer: 603
Tubes in Tubeless Tires
Hey
Question: can you put a tube in tubeless tire? Specifically an f650gs?
I'm probably over analyzing here, but lets say a person was going on a two week trip far from home in rural america... and got a flat that couldn't be plugged, could said person put a tube in the tire? If you can, does anyone have any pointers...?
Just thinking and planning for said two week trip...
thanks
Ich Fahre Nicht Zu Schnell, Ich Fliege Nur Niedrig
Oklahoma Adventure Trail
YouTube
Dadayama is offline   Reply With Quote
Old 08-22-2012, 10:51 AM   #2
epicxcrider
epicxcrider's Avatar
Oddometer: 653
Yes, you can put a tube in a tubeless tire.
Old 08-22-2012, 11:46 AM   #3
Bucko
In a parallel world
Bucko's Avatar
Oddometer: 819
But if there's a hole in your tubeless tire, put a patch over it on the inside so the tube doesn't find it's way through or abrade itself till it pops.
Bucko is offline   Reply With Quote
Old 08-22-2012, 11:56 AM   #4
KTM250rm
KTM250rm's Avatar
Oddometer: 28
If its a radial tire, make sure you get a radial tube. Radial tires aren't finished smooth inside and the roughness will chew up a tube. Radial tubes are twice as thick as a non-radial tube.
KTM250rm is offline   Reply With Quote
Old 08-22-2012, 02:58 PM   #5
Dadayama OP
Constant Adventurer
Dadayama's Avatar
Oddometer: 603
So the same problem and the use of a patch would also apply to an F800GS if they had that bad of a flat?
YouTube
Old 08-22-2012, 08:54 PM   #6
sorebutt
Oddometer: 1,998
I'm running tubeless tires with tubes. No problem.
I wounder why you would want to put a tube in the tire when you can plug a tubeless tire without having to take it off the bike. I've plugged everything from motorcycles to ATVs and have never had a problem. You can put a patch on the inside if a plug doesn't work. That is still easier than mounting a tire with a tube.
sorebutt is offline   Reply With Quote
Old 08-23-2012, 10:24 AM   #7
Dadayama OP
Constant Adventurer
Dadayama's Avatar
Oddometer: 603
I am probably over analyzing, but i'm going on big trip, in the nowhere lands of Utah. Was wondering if i should take some tubs incase i had some type of really bad flat that couldn't be plugged. Now i'm wondering if i should look at a tire patch kit if that would be better. I'm running on a plug right now on my rear tire, and have for awhile. I do have a new tire in the garage, that i'm going to put on before i leave.
thanks for the info
YouTube
Old 08-23-2012, 07:55 PM   #8
Kiwi Tinkerer
Ross
Kiwi Tinkerer's Avatar
Oddometer: 390
plug kit
Take a plug kit. They can be applied without taking the tyre off. If you seriously think you might make a big hole then take a tube along as a spare. Practice removing the tyre and fitting the tube before you go.
Having the tube already installed defeats the purpose. If you get a hole that can be plugged it is easier without a tube. (5 minutes) If you get a hole too big to plug you will need to take the tyre off and put a patch over it so the tube does not poke out.
Might be a good idea to take a tube but not pre- fitted.
If you hit something hard enough to put a big hole in the tyre you are likely to bend the rim too.
A tube might be handy if you have a problem with sealing against a slightly bent rim. Might, at least, get you home.
Also recommend some rim protectors so you don't damage the rims with your tyre levers.
And take a couple of unopened tubes of rubber cement. Nothing worse than going to do a repair and finding the cement has gone off.
Good luck. .
Kiwi Tinkerer is offline   Reply With Quote
Times are GMT -7.   It's 06:56 AM.
