Old 08-23-2012, 07:58 AM   #1
D0dja OP
Sandwurm
D0dja's Avatar
Oddometer: 28
Mayonnaise in engine. Head gasket blown (KTM 640 Adventure)
Last weekend I stripped around the top end to check my valve timing. And found in the oil hoses from frame thick, white gloop.
I'm thinking head gasket leak. I noticed my coolant level kept dropping, but blamed my radiator cap not sealing properly.
I don't want to even contemplate what this means.
Someone please tell me there is another possible explanation?
Apart from completely tearing down the engine, is there any way to test where the problem might be?
-- Ride it hard! Harder! HARDER! --
D0dja is offline   Reply With Quote
Old 08-23-2012, 08:06 AM   #2
Dexter2811
Dexter2811's Avatar
Oddometer: 205
Yup, those are a blown head gasket symptoms... you'll have to, at least, remove the head and check it...
2010 NX4 Falcon, 440cc Wiseco Big Bore, Stage II Hotcams, XR400R clutch, XR600 40mm Mikuni carb, MX handlebar (Wirtz), Custom exhaust.
Dexter2811 is online now   Reply With Quote
Old 08-23-2012, 08:54 AM   #3
crazybrit
crazybrit's Avatar
Oddometer: 8,039
I found same once in my SXC hose. Creeper told me it was nothing to worry about. I can't find the message anymore where he explained what it was.
crazybrit is offline   Reply With Quote
Old 08-23-2012, 11:53 AM   #4
Luke
GPoET&P
Luke's Avatar
Oddometer: 3,758
Could be the water pump seals. Check it while you're on your way to the head gasket. When my head gasket broke it was sudden, not gradual like you're describing.
How fast are you losing coolant?
If were just goop in the breather hose without losing coolant that it could just be an oil/condensation mix. What does your oil look like? Oil or chocolate milk?
Luke is offline   Reply With Quote
Old 08-23-2012, 02:08 PM   #5
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 2,703
Most likely this if it is the breather hoses where the goop was, & there is no oil in the coolant or vice versa. I usually see a little milky goop in the engine - frame breather pipes when I remove them.
If I overfill the rad on mine it always spits out the excess coolant until it finds it's happy level just at the top of the core while upright.
If you do have a problem with the water & oil not staying where they should it is more likely to be the water pump needing a rebuild than a head gasket issue. It's usually pretty easy to see if the water pump is shagged when you strip it down.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is online now   Reply With Quote
Old 08-23-2012, 05:58 PM   #6
KTM AL
Oddometer: 102
Probably condensation if your antifreeze isn't going low
If your engine oil is milky and antifreeze is going low
than its probably your water pump seals, which can be rebuilt or replaced, rebuilt mine for about $60.00
KTM AL is offline   Reply With Quote
Old 08-23-2012, 06:24 PM   #7
swimmonkey
JMS
Oddometer: 54
Puke My take
Coolant and oil. Don't put it on a sandwich!
swimmonkey is offline   Reply With Quote
Old 08-23-2012, 07:05 PM   #8
bmwktmbill
Traveler
Oddometer: 4,012
Waterpump, check the bearing numbers and the seal numbers in the parts book, you can get them from any bearing house...the shaft is the problem if it is scored.
Most of us own a couple ruined ones.
PIA.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 08-23-2012, 09:43 PM   #9
Ride Now
Graybeard
Oddometer: 27
Hold the mayo............
Oh great; this is probably gonna start a "What brand of mayo is best for my engine?" threads..............
Ride Now is offline   Reply With Quote
Old 08-23-2012, 10:54 PM   #10
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 2,549
PIA.
bill
+1, KTM waterpumps just do that.
Zak
ktm
old bmw
others
slackmeyer is online now   Reply With Quote
Old 08-29-2012, 06:12 AM   #11
D0dja OP
Sandwurm
D0dja's Avatar
Oddometer: 28
Thanks for the pointers, gents. After giving it a think, reading some other threads and talking to some folks, I'm inclined to believe it's the inner waterpump seal. Plenty of evidence points to this.
Also, believing it's the waterpump seal is much nicer then believing it's head gasket,
After cleaning out as much goop as I could find, topping everything up, and going for a couple of hours ride, the coolant level did not drop a lot, and the bike seems to be running fine. I've not been riding that much recently, which would seem to make it more likely a seal got stiff than the head gasket would suddenly let go.
Found a really good step by step to rebuild the waterpump (and hopefully fix an annoying oil leak from the top of the head that's been irritating me for years). Will order the parts and do a rebuild in a couple of weeks (currently in midst of moving house).
Old 08-29-2012, 11:47 PM   #12
bmwktmbill
Traveler
Oddometer: 4,012
While you are at it better do the cam followers or you will cry.
That's the standard.
bill
Bill Shockley
Old 11-27-2012, 05:23 AM   #13
D0dja OP
Sandwurm
D0dja's Avatar
Oddometer: 28
Think it really is blown this time
Ah bollocks. Rebuilt the water pump with new bearings, seals, etc. Took a bit of time to seal up exhaust port bolt oil oooze, and re-seal the valve cover.
All tight as a drum, no more oil-slicks down the side of the engine.
Also re-faced the radiator mouth -- it was a bit scored and pitted and the cap was leaking. Took it for a couple of good hard runs and pressure was holding, coolant levels stable.
Then big offroad ride on Saturday. Temperature went ballistic, check the radiator, coolant almost gone.
I had noticed a lot of white smoke from the exhaust when starting -- in hindsight it looked more like steam.
Looks like the head gasket has failed.
I am not happy.
At all.
Old 11-27-2012, 07:29 PM   #14
bmwktmbill
Traveler
Oddometer: 4,012
Can't say I blame you, been down that road myself...twice.
Second time I lost the piston due to cracked ring(s). I know it's an extra step but if it was me and especially if you have run some shit gas I'd consider pulling the barrel and check the rings.
How's the bore look?
http://advrider.com/forums/showthrea...ghlight=piston
pics here...
http://advrider.com/forums/showthrea...ghlight=panama
and here...
http://advrider.com/forums/showthrea...ht=overheating
bill
Bill Shockley
bmwktmbill screwed with this post 11-27-2012 at 07:41 PM
Times are GMT -7.   It's 12:32 PM.
