02-19-2013, 10:28 PM
#1471 | |
Yeah! I want Cheesy Poofs
Oddometer: 17,772
Not to jack this thread but I had a Vtec VFR for a number of years, I'm far from a bike technician but managed to bleed my linked brakes just fine with no troubles. |
02-20-2013, 12:58 PM
#1472 |
Oddometer: 86
Maintenance Info.
I wondered what maintenace requirements there are. My cbr250 required an initial valve adjustment at $360 and 600mi. I think it is every 8000mi. after that. I asked at the dealer and they said they thought the valve adjustment would be $390 on the 1100 and be the same interval as the 250. One vs. four cylinders the cost especially doen't seem right. Anyway, you would think there would be someone from Australia or Japan that would want to chime in on ADVrider. But then again they would get bombarded with 10,000 questions on this thread.
02-20-2013, 01:19 PM
#1473 |
Oddometer: 45
02-20-2013, 01:24 PM
#1474 |
long time rider
Oddometer: 354
I was wondering what it meant, too. Since you don't show a location, I'm not sure whether you get ice and snow there or not. Maybe Dave knows where you live.... dd50 tomp
dpg, is the tupperware that involved to deal with, that it takes almost 4 hours to adjust eight valves? Figuring around $100 an hr labor. For what we pay for this two wheel hobby, valves shouldn't need checking at 600 miles. If the potential for such actual adjustment is needed so early in the engine's life, then the Mfgr should pay for it. We drive four valve dohc engines in out cars and trucks for 100,000 miles plus and never need to check the valves. dirtdreamer50 screwed with this post 02-20-2013 at 01:34 PM |
02-20-2013, 01:43 PM
#1475 | |
Dummy
Oddometer: 203
I'm sorry to be off topic but I had to laugh when I saw this nugget of wisdom in the CTX thread
![]() Quote:
As for the cb1100, I wasn't able to go to the chicago bike show and it seems that it will be hard to find one sitting at a dealer so I don't know when I will be able to get a good look at one. I do know that I haven't been this interested in a new bike in a long time.
1972 Honda CB350F 1972 Honda CB750 K2 1976 Honda CB750 K6 |
02-20-2013, 01:53 PM
#1476 |
long time rider
Oddometer: 354
Some have been tough on JerryH on that thread, for really liking the new CTX. He, I thought, was offering rather sage advice to the nay sayers and harassers, with out getting nasty. tp
02-20-2013, 02:14 PM
#1477 | |
Motorcycle nut
Oddometer: 268
Here is procedure for the ST Brake Lever 1. Left Outer (upper) bleed valve. 2. Right Outer (upper) bleed valve. Brake Pedal 1. Remove and tilt left front caliper 15 degrees (wood shims inserted between the pads will keep the pads from extending while~if pedal is pumped) 2. Proportioning Control bleed valve. 3. Rear Brake Center bleed valve. 4. Right Front Center bleed valve. 5. Left Front Center bleed valve. 6. Rear Outer (forward) bleed valve. Anyhow, Ive never had valves adjusted at the 600 mile service. Its oil, filter, and check nuts and bolts and throttle play, chain slack etc. It is crazy that Honda requires valves to be adjusted at 8,000 miles. My FZ a much higher performance bike with 5 valves per cylinder calls for the first valve adjustment at 26,000 miles. The other Ferret screwed with this post 02-20-2013 at 02:30 PM |
02-20-2013, 02:33 PM
#1478 |
Oddometer: 595
The CTX with auto, would be a great bike for my daughter. The Cb1100 would be a good bike for her boy friend.
02-20-2013, 03:16 PM
#1479 | |
Oddometer: 9,698
Costs for this service vary all over the map, so it is difficult to make comparisons. Typically a four-cyl will be more but not 4X more since the lion's share of the work gaining access to valve train is more/less the same, regardless of the number of cylinders. - Mark |
02-20-2013, 03:35 PM
#1480 | |
Oddometer: 86
02-20-2013, 05:16 PM
#1481 |
Oddometer: 2,483
It was sarcastic a comment about your requirement that a bike have anti-lock brakes.
Yeah, they're nice, but they're hardly a deal-breaker for most people. I've locked up the front tires on street bikes plenty of times, mostly on dry pavements, and not ever thought that I would only buy bikes that had anti-lock from there on after. I think it is a stupid stipulation that a bike has to have it.
"After reading through this thread I've come to the conclusion that more people cruise the internet looking for reasons why X bike won't work in Y scenario rather than actually riding their motorcycles." -- RyanR |
02-20-2013, 05:33 PM
#1482 |
long time rider
Oddometer: 354
Opinion differences abound...
An ABS thread is kinda like a best oil thread, or best tire thread. Everyone has an opinion, and one generally isn't any better than another. My RT came with ABS and semi linked brakes. and can emergency stop on a dime and give change.
The Duke and the Dyna don't have ABS, and one with Brimbos, stops on a dime and the other on a fiver. You can guess which one is which. Just saying that learning your brakes is all important in understanding how the bike will react under duress, whether it does or doesn't have a specialized braking system. If you want ABS, get ABS, it's a personal decision not a stupid one, just as not getting ABS is personal, not stupid....tp dirtdreamer50 screwed with this post 02-20-2013 at 05:54 PM |
02-20-2013, 06:20 PM
#1483 |
Oddometer: 136
I got a kick out of John McGuinness' recent comments:
"I'm really pro-ABS. I think every bike should have it. People say they don't want it. They stand in the pub and say they're better than ABS. But nobody is." I'd love to see one of those guys put their skills up against those of McGuinness who can count 19 Isle of Man TT victories amongst his accomplishments. Nevertheless, choosing whether or not to go with ABS comes down to personal preference. I'm just glad that ABS is an option on the CB1100 for those of us who would like to have it. |
02-20-2013, 06:41 PM
#1484 |
long time rider
Oddometer: 354
I wonder if the MotoGP guys could keep up with Mc Guinness and his crowd at the TT. Just watching it on the TV gives me the shivers. Those guys are insanely good on country and city roads at GP speeds... tp
02-20-2013, 06:48 PM
#1485 |
Oddometer: 136
