Old 08-25-2012, 11:09 AM   #1
Helowarrior OP
Oddometer: 4
Tire pressures and spring setup?
Heading out tomorrow morning on a 7 to 10 day ride around the Trans Labrador Highway Loop. Have my F800 GS loaded up quite heavy. I am 240 pounds and probably another 100 pounds of gear. Running new K60 Scouts front and rear.
Any ideas on tire pressures and shock settings?
Thanks in advance.
Helowarrior is offline   Reply With Quote
Old 08-25-2012, 11:58 AM   #2
vtbob
wanderer
Oddometer: 539
Turn up your preload if you have not already. If you are bottoming in bumps/pot holes, the preload is likely too low.
The tire pressures should be on the high end of the range printed on the tire while on pavement. You may want to lower it when on the dirt road portions....if you are carring a pump so you can restore it when needed.
Have fun
vtbob is offline   Reply With Quote
Old 08-25-2012, 09:07 PM   #3
sorebutt
Oddometer: 1,772
I don't believe the tire has a range. Just a max pressure and load. The owners manual has a range. Go with a higher pressure from the range. Watch your tire wear. It the center is wearing a lot faster that the side then lower the pressure (or go faster in the corners lol). If you are getting the edges rounded then add air or slow down in the corners.
sorebutt is offline   Reply With Quote
Old 08-26-2012, 07:10 AM   #4
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,306
Try 36 psi front and back. That is what I use with them fully loaded.
Have fun on the Labrador trip.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is offline   Reply With Quote
Old 08-26-2012, 08:15 AM   #5
JRWooden
Oddometer: 4,232
Let me second the motion on the preload - I think I'd have it all the way up ~40 clicks or 20 full turns.
Also I'd set the rear damping a bit higher/stiffer - turning the screw clockwise makes it stiffer.
I would gently run the screw all the way in to "lightly seated" then back out Counter-clockwise
by something like 1.0 to 1.5 turns and see how it goes. From the factory I it set at 2.0 turns from seated IIRC...
Times are GMT -7.   It's 01:56 AM.
