Old 08-26-2012, 08:14 AM   #16
Barman
Way Offline
Barman's Avatar
Oddometer: 1,162
Neon gas with opaque sidewalls...Bling!
I am at one with my duality.
Barman is offline   Reply With Quote
Old 08-26-2012, 08:15 AM   #17
Goti
Goti's Avatar
Oddometer: 795
Originally Posted by Nomadix View Post
For best results, I'd suggest a mixture comprising roughly 78% nitrogen
Catalina38 uses the same percentage you guys know something we don't know.
I use beer's nitrogen and always carry a six pack just in case.
KTM 990 Adv
Goti is offline   Reply With Quote
Old 08-26-2012, 08:23 AM   #18
syzygy9
syzygy9's Avatar
Oddometer: 240
Originally Posted by SE Steve View Post
snip. From what I have been told is that nitrogen molecules are larger than oxygen molecules. So over time the nitrogen filed tires will lose less air pressure from leaking through the rubber layers
Air = ~80% N2 and ~20% O2, N is 7 on the periodic table and O is 8, add some trace elements (H2O and Ar) and I think you will find the average molecule size is larger for 'air' - for whatever that is worth.
Pure N2 and O2 are both as close as to each other and to an 'ideal' gas that their PV to T relationship is virtually the same.
Pressure changes for N2 vs 'air' filled tyres are due to the water in the air evaporating (=gas), condensing (=water), freezing (=ice) - effectively taking some of the 'gas' out of the tyre.
'Air' filled tyres don't leak any more (or less) than pure N2 filled tyre - unbelievable how there is so much mythology around N2 in tyres!
__________________________
bikeless no longer! welcome home, 2011 KTM 990 Adventure!
syzygy9 is offline   Reply With Quote
Old 08-26-2012, 08:53 AM   #19
timekeeper
timekeeper's Avatar
Oddometer: 15
Originally Posted by Azmontana View Post
What hassle? It's a piece of piss to fill your tyres with Nitrogen.
Azmontana, Piss,no it isn't yellow or wetIt is a hassle every time you need to fill or adjust to have a can of Nitrogen there for that purpose. They market it as if your tires will never change PSI as you drive or temp changes,truth be known it does change just not AS much as compressed air. For someone with little experience on the reality of actually having it in one of there own rides I suppose it seems like the best thing since sliced bread. In reality if your tracking or touring tires do need adjustment and Nitrogen is not as available as the alternative, or worth the "hassle".
1980-R100/EML
1980-R100T
1984-R100/RS
1991-R100/RT & 2002 R1150RS
2006 ZX-14/Hannigan HP Hack
timekeeper is offline   Reply With Quote
Old 08-26-2012, 09:06 AM   #20
catalina38
Contrarian
Oddometer: 1,412
Google is my friend
Dry air contains roughly (by volume) 78.09% nitrogen, 20.95% oxygen, 0.93% argon, 0.039% carbon dioxide, and small amounts of other gases
Born 10,000 years too late
Scientific Wild Ass Guesser:hmmmm
catalina38 is offline   Reply With Quote
Old 08-27-2012, 01:14 PM   #21
Azmontana
Oddometer: 29
I've had it running on my car for around a year and checked tyre pressures once a month. In that year I only had to top up with nitrogen 2 times. It's more of a hassle filling your tyres up with air every couple of months.
Azmontana is offline   Reply With Quote
Old 08-27-2012, 01:30 PM   #22
Bullspit
Oddometer: 33
For best results, I'd suggest a mixture comprising roughly 78% nitrogen, 21% oxygen and 1% argon. Don't worry about trace amounts of other gasses.
Also, for optimum performance and longevity, I recommend snake-oil in your engine .
Excellent balance, and it is the argon that really does the trick.
Bullspit is offline   Reply With Quote
Old 08-27-2012, 08:41 PM   #23
jimmex
Guero from SanAngelo
jimmex's Avatar
Oddometer: 1,431
Originally Posted by Peanuts View Post
I used Helium in my 990 Adv tyres. The whole bike now weighs less than my 250 EXCF.
Honest ;)
I also lube my chain with snake oil
Oh shit that's funny.
jimmex is offline   Reply With Quote
Old 10-31-2012, 12:19 AM   #24
Builtdesign
Oddometer: 2
Here's some additional info on the subject (relating to cagers) nitrogen in tires
Don't forget to lube your clutch cable with snake oil too...
A superior rider is one that uses his/her superior knowledge to avoid situations that would require the use of his/her superior skills.
Builtdesign is offline   Reply With Quote
Old 10-31-2012, 06:38 PM   #25
Dustodust
Dustodust's Avatar
Oddometer: 672
Nitrous Oxide filled for at night around the campfire, a bottle of Presidente' and some Led Zeppelin
......a Green Slime compressor and some hair of the dog for the morning after
04 KTM 950 S
04 KTM 525 EXC street plated
Old 10-31-2012, 06:44 PM   #26
corndog67
Oddometer: 867
I guess if you've got plenty of money or a gas supplier to keep in business, it makes sense. Also, the pit racing thing might put you in the lead with Nitrogen pressured tires. The guys at Starbucks would just drool over that. Maybe you can make a buck by filling everyone's tires for, say, $3.00 per tire out of your bottle?
Ducati S4 916 is history.
KTM 950 SM, my main squeeze now.
1970 CT-70
And now, an XR75,
corndog67 is offline   Reply With Quote
Old 10-31-2012, 07:04 PM   #27
Dustodust
Dustodust's Avatar
Oddometer: 672
What happens when you fill your tires with helium
04 KTM 950 S
Old 11-01-2012, 08:08 AM   #28
crofrog
Oddometer: 1,376
Originally Posted by henryroten View Post
I was thinking that with this hot summer and all the reports about tire failures I would try replacing the air in my tires with Nitrogen gas. I know that race car drivers everywhere use it as it doesn't expand with heat, keeping the tire pressure from over heating and inflating the tires to dangerous levels (Nitrogen gas is also used in shocks for the same reasons).
Nitrogen expands when hot (like any other gas ever) but it does it predictably. Which allows you to repeatedly hit the hot pressures you're looking for.
The other benefit is that pressure should stay equal in elevation changes which are plentiful in the area where I do most of my riding (northern Utah).
Um yeah, no.
crofrog is offline   Reply With Quote
Times are GMT -7.   It's 11:55 AM.
