Old 08-25-2012, 06:48 PM   #1
andresg OP
Oddometer: 23
Eh? Handlebar and front wheel strong vibration
Hey Guys,
I have my 950 adventure '05 but lately I've had a lot of vibration in the front wheel.
When I raise my hands off the handlebar between 10Km/h and 60Km/h, the Adventure goes steady as well between 75Km/h and up.
But between 60Km/h and 75Km/h the handlebar just becomes a whole vibration w/out control at the point that could make me fall and crash.
Specially goes worst off-road when in bumps when the front wheel goes up and touches ground again.
Does anybody have had a similar experience? Do you know what could cause this problem and how to fix it?
Thanks guys.
Andres
andresg is offline   Reply With Quote
Old 08-25-2012, 07:38 PM   #2
Stumpalump
Oddometer: 128
Put it on the center stand and spin the front tire. Look for a tire problem or bent rim first.
KTM 950A
Rokon 2X2
Montesa 315R trials
KTM 200 EXC.
XR400
Stumpalump is offline   Reply With Quote
Old 08-25-2012, 07:39 PM   #3
GrenDesb
Oddometer: 328
Front tire
Suspension setup
Head bearings
Common sources of front end shake
GrenDesb is offline   Reply With Quote
Old 08-26-2012, 01:16 AM   #4
Chewy750
Chewy750's Avatar
Oddometer: 52
What tyres, part worn scorpions cause this.
Chewy750 is offline   Reply With Quote
Old 08-26-2012, 02:11 AM   #5
bigkuri
bigkuri's Avatar
Oddometer: 779
+1
Actually I find part-worn pretty much anything causes this, especially if I've been road riding and heavy on the front brake.
Current Bikes: 2006 Honda XR650R & 2007 KTM 950 SMR
bigkuri is offline   Reply With Quote
Old 08-26-2012, 12:35 PM   #6
andresg OP
Oddometer: 23
I have a part worn Scorpion front tire, however the problem appeared after installing the brand new...
I got it balanced but didn't work-out.
Old 08-26-2012, 09:47 PM   #7
GrenDesb
Oddometer: 328
Did you made any changes other than the tire?
If not, it must be the tire.
What's the air pressure in it?
Old 08-26-2012, 10:10 PM   #8
andresg OP
Oddometer: 23
None, just the tire.
I normally use 28 -30 psi front...
Tomorrow I'll change the rim for a new one from Behr, move the hub, discs and spokes, get it all balanced and see what happens...
I'll check suspension bars torque, triple clamps and wall-nut again, so far those where correctly tightened though.
Old 08-26-2012, 10:37 PM   #9
Yascher
Yascher's Avatar
Oddometer: 388
mine does this from worn scorp, uder braking bike just starts to wonder all over the place+wibes
Yascher is offline   Reply With Quote
Old 11-06-2013, 12:56 PM   #10
Wastedavid
Oddometer: 33
Bluhduh
Any other solution to this problem??? My bike has new tires, actually is brand new... I guess there are no worn tires or parts on my bike but it's exactly the same problem, between 60 to 80 Km/h if you don't hold the handlebar strongly... kiss the road
Wastedavid is offline   Reply With Quote
Old 11-07-2013, 10:09 AM   #11
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,002
Have you checked wheel bearings?
I had worn wheel bearings and the result was wobbling of the front wheel.
You could sound- check the spokes. I had one broken once...
Cheers.
Old 11-07-2013, 11:09 AM   #12
ADVill
Oddometer: 609
Scorpion. Stand up, lean forward and look at the tire while it's rolling. Looks like a wheel out of true. Can't wait to get mine off.
'08 990 Adventure Orange of course
'00 520 EXC
'14 500 XCW
ADVill is offline   Reply With Quote
Old 11-07-2013, 07:42 PM   #13
DesertSurfer
Tail sprayin
DesertSurfer's Avatar
Oddometer: 1,463
Loose the Scorps...
This same post appears year in and year out. The 950 stock front springs are soft and causes a dive to the front end. The front Scorpion wears unevenly due to this dive and the weight imposed on the front wheel. The Scorpions along with the Behr front wheel don't balance well either. Also the Scorpions do not wear well with tire pressure below 32 psi on pavement. Add all of this up and you'll constantly hear complaints about "head shake".
I"ve experienced this very same problem with fairly new Scorpions and pitched them immediately... problem solved.
My personal opinion of the Scorpions are they suck anyway. I'd rather ride an extremely worn set of TKC80s on the pavement.
Now, my current Scorpion Rally front tire is working really well and would also make a much better selection.
But then I'm of the belief it's better to have a more aggressive tread pattern then a lesser one. And an extremely worn out aggressive tread pattern is as good to me as a worn out street tire... where bald is bald.
Just my humble and biased personal op. YMMV.
'"This whole memory lapse is gett'in to me. Hopefully I think I'll outgrow it."
DesertSurfer is offline   Reply With Quote
Old 12-25-2013, 06:58 PM   #14
Wastedavid
Oddometer: 33
Same problem, new bike
Hi guys! I was reading this and I´m worried about this because my bike is brand new, 3500 km and it has this terrible vibration between 50-75 Km/h and some days ago I was trying to fight with a S Teneré 1200 and a Vstrom 1000 and when I was reaching 190 Km/h, the bike was going from one side to another, very strange but I got scared and preffered to release accel and see the other guys leave me behind...
I have to check if maybe the problem is the rim but I really don´t think so...
Let´s see what´s going on
Old 12-25-2013, 08:03 PM   #15
superhak31
superhak31's Avatar
Oddometer: 87
Behr
First off, don't replace Behr rim with a Behr Rim. Get an Excel or Dirtstar DID.
1.85" way stronger than stock wheel. And costs less. And I put in stiffer front springs to avoid bottoming out while off road. No front shake ever.
superhak31 is offline   Reply With Quote
Times are GMT -7.   It's 08:02 AM.
