Old 05-19-2013, 12:50 PM   #31
Head2Wind OP
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
Hung most of the plastic on the bike, need to make the decision to go 2 into 1 into 2 or into 1 muffler..... I am leaning toward 2-1-2 for several reasons. One being that if I make it 2-1-2, if I decide to put the ADV exhaust back on the bike, then the mufflers will bolt right up, and that might be a reality depending on what I want to ride.
The low pipe is going to get a skid plate, but for now the major issue is the muffler configuration.
More video fun
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 05-19-2013, 07:12 PM   #32
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,160
Sweet!!!
Any info on the external FP/fpr?
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 05-19-2013, 08:04 PM   #33
Head2Wind OP
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
Originally Posted by bikyto View Post
Sweet!!!
I'm running a SD pump in the ADV tank right now. Basically the same thing other than the lower adapter. Its still on my list of to-do. I really want to keep the pump in tank (cooling, and room on bike... bla bla..) but move the FPR and filter external. I found a Bosch FPR that is adjustable so it can be set at the factory 51psi where most off the shelf FPR are set at 45-47psi. I also found a nice Bosch inline high pressure filter that is rated a 5-7 micron.... just need to find time to make it all happen. With the bike running and getting closer to being completed the FP/FPR/Filter project will come soon after.
I still have a 950 SE that needs most of my attention to complete by the end of this month and then a ADV that needs major service to be completed by mid/late June. Once these are done and out the door then I will have more time..... There is a 500 exc service job in the wings and a KZ1000 transmission rebuild somewhere in late June too....
At the very latest, my goal is to have the bike ready for the KTM rally this year. The ride to the rally just might be one leg of the IBA 1k24... boarding on a 1500 in 24 hour ride. We will see how that goes with Mrs H2W.
Old 05-19-2013, 11:32 PM   #34
bikyto
bikyto's Avatar
Oddometer: 2,160
You busy man
I agree about the fuel pump staying in the tank.
I'm on the road, so I can't help much but I look forward to a practical solution.
Cheers!
Old 10-18-2013, 06:28 PM   #35
Head2Wind OP
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
Wicked Its RIDES!
I thrashed on it last night until 11PM to get it together so I could ride it to work and also have it for the weekend since the weather is supposed to be half way decent for a while. I still need to finish up the battery box, reg and start solenoid mount, then fab a skid plate..... Oh and it needs the forks gone through with stiffer springs too. I have a set of .64s that are going to go into the forks. Need to replace the brake pads up front, going to slide a set of Galfer Greens (on the shelf). I am also going to put a 'double' screen setup on it, with a few extra mods to hopefully help the slip stream/flow over my head, will have to see how it all works out.
Here is the video of it on the lift. I'm going to try to find a decent mount for the camera and shoot some riding video too, been brain storming a few ideas about do a couple microphones on the exhaust and intake to get the 'full effect' in the video....maybe. :)
Old 10-18-2013, 11:09 PM   #36
mousitsas
mousitsas's Avatar
Oddometer: 2,728
Thats great!
Would you reckon that the superduke headers will work with stock 950 cams?
Would they fit straight on an SE?
mousitsas is online now   Reply With Quote
Old 10-18-2013, 11:19 PM   #37
Head2Wind OP
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
Originally Posted by mousitsas View Post
Thats great!
I don't see a reason why the 950 ADV cams and the SD header would not get along. The SD header will not directly fit a SE without moving the oil tank and cutting the center stand tabs off the frame as well as cutting the rear mount points for the skid plat off to provide clearance for the header to pass through the space.
Old 10-18-2013, 11:24 PM   #38
mousitsas
mousitsas's Avatar
Oddometer: 2,728
I'd rather had the bad news first
Anyway, at least I asked, since there are lots of them around at a good price.
mousitsas screwed with this post 10-18-2013 at 11:53 PM
Old 10-19-2013, 10:23 AM   #39
Head2Wind OP
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
If you really want to run a low pipe on the SE, I _think_ that you could run a oil tank from the SM or SMT and the SM or SMT header. You will still need to cut the center stand tabs off and clip the lower section off of the bottom of the engine mount tabs in the back.
On any of the 990 headers applied to the 950 engine you have to reduce the size of the head port flange of the header so that it will fit inside the 950 port. Everything else fits the engine though.
I just modified my tune after several different attempts I think I got it pretty good. The only issue is the map has the O2 sensors turned off..... which will probably mean that MPG will suck. I'm going to keep working on the O2 enabled map, but use the one that I have in there now as a "it runs!" map.
I needed something to do last night so I got out the polishing and wax compounds to knock off some of the nasty. Looks pretty nice so far, but its hard to polish out getting hit by a car in a alley
Old 10-19-2013, 12:08 PM   #40
mousitsas
mousitsas's Avatar
Oddometer: 2,728
Eventually I will run a low header exhaust to get rid of the heat, but I will have it custom made since I need the center stand.
Many thanks.
Old 10-19-2013, 12:56 PM   #41
Head2Wind OP
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
Again, I _believe_ that you could fit a aftermarket center stand intended for the SMT that bolts onto the cross frame member in a different fashion than the ADV/SE frame/stand.... This is what I am planning on doing/fabing for my ADV, because I want/need a center stand.
Old 10-23-2013, 06:14 PM   #42
crankshaft
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,003
Fired my fuelie project up tonight, runs great! Thanks for your help! 2007 950 SE
Just say'IN
crankshaft screwed with this post 10-23-2013 at 07:31 PM
crankshaft is offline   Reply With Quote
Old 10-23-2013, 08:18 PM   #43
Head2Wind OP
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
Laugh
Fuelie 950! AWESOME!
gotta love the possibility of 115+ HP easily obtained... then applied to the SE....
______________________________EPIC ROOST
Old 10-24-2013, 05:39 AM   #44
crankshaft
crankshaft's Avatar
Oddometer: 14,003
The Super Duke ECU should allow me the ability to enjoy "Super Roost"
My SE is finally where I've always wanted to put it. Closed Chamber forks, updated rear shock, Powercell tank, fuel injected and the best part...LED tail light (5 hp at least)
Just say'IN
Old 10-24-2013, 06:45 AM   #45
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,270
awsome
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Times are GMT -7.   It's 08:24 AM.
