Old 08-30-2013, 05:30 AM   #1
2VEZR25 OP
Recuerde el 911
2VEZR25's Avatar
Oddometer: 60
F800GS Forks into Airhead frame????
Anyone here ever tried to swap forks from an F800GS into an mono frame?... I'm planning a GS project build and am looking for a suitable fork upgrade for all terrain distance touring. The tought of something from a later BMW has some appeal.
2VEZR25 is offline   Reply With Quote
Old 08-30-2013, 05:42 AM   #2
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,299
Not sure about the above but I know forks from the 650x series will fit. Surely you've notice the Austrian tend here
hardwaregrrl is online now   Reply With Quote
Old 08-30-2013, 08:08 AM   #3
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 9,768
If your going to go threw the hassle of a fork upgrade get a set that is adjustable. F800 forks are not. Folks with f800's seem to swap theirs out for ones that are.
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 08-30-2013, 12:25 PM   #4
B_C_Ries
Oddometer: 2,657
Maybe he wants to go this route because he has access to a pair of F800GS forks that were swapped out.
I have an F800GS and a 1977 R100/7 and I do know that the F800GS forks are a lot better than the Airhead forks.
I am not up to date on good dirt bike suspensions so I think the F800GS has a good suspension,
B_C_Ries is online now   Reply With Quote
Old 08-30-2013, 01:15 PM   #5
blaine.hale
blaine.hale's Avatar
Oddometer: 3,070
Sell the f800 forks, if it's a case where you already have access to them, buy dr650 forks and profit. At least we know the dr forks are almost a direct swap out.
1974 BMW R90 /6
1968 Bultaco Matador MK3
1973 BMW R75 /5 Toaster LWB
1969 Bultaco Bandido MK2
2013 Husqvarna Terra TR650
blaine.hale is offline   Reply With Quote
Old 08-30-2013, 02:24 PM   #6
Padmei
enamoured
Oddometer: 3,604
FWIW a mate has a F800GS & isn't that impressed with the standard forks. DRZ are another option.
Padmei is online now   Reply With Quote
Old 08-30-2013, 05:42 PM   #7
B_C_Ries
Oddometer: 2,657
Mounting the F800 forks will be quite a chore
Old 08-30-2013, 10:36 PM   #8
2VEZR25 OP
Recuerde el 911
2VEZR25's Avatar
Oddometer: 60
Open to all suggestions
Yes I did hear the DR650 forks might be a good option. The intended use is for loaded up distance touring and all road & trail conditions, (not competition use) if that changes things any. I've also been advised that the DR450 front might be better suited for the use. I don't know the difference between the two so perhaps someone here could comment on that.
I don't have access to an F800 GS front and at this point in time it was only a thought to stay with the BMW product if it was better in some way.
Old 08-31-2013, 05:33 AM   #9
hardwaregrrl
ignore list
Oddometer: 7,299
You mean DRZ400......they are a tad wider than the DR forks and have adjustable comp and rebound. Where as the drs do not
Old 08-31-2013, 07:07 AM   #10
bully1
bully1's Avatar
Oddometer: 4,312
I''ve got a set of F800 .gs forks on my 92 R100 .GS PD, they are in a set of Emig Racing tripple clamps, bloody great, with a full tank of fuel ( 35.lt) they feel great,with half a tank they are awesome. They may not be adjustable but they don't need to be, a huge improvement over the standard forks.
'02 GSX 1400 outfit........lot's of grin factor
'11 Husky TE 630.......tyre shredder
'06 HUSKY TE610 x 2............ for the boys
'92 R100GSPD ( modified)...........slow and easy
bully1 is offline   Reply With Quote
Old 08-31-2013, 07:50 AM   #11
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,669
if doing a fork swap then why purchase something not adjustable when you can have something better for probably the same money??? If doing a swap I'd go the KTM WP 50mm route. Do it once and do it right. No harder to set them up than anything else, pluss a pretty common fork.
http://www.advrider.com/forums/showthread.php?t=676340
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 08-31-2013 at 07:58 AM
Times are GMT -7.   It's 10:33 AM.
