04-08-2013, 10:39 AM
#1 |
Oddometer: 4
Did I do something stupid?
Well hello there!
Long time lurker who spontaneously bought a 1974 R74/6 last fall. I'm really just working my way through the, I guess, normal steps of bringing a sleeping beauty back on the road. Anyhow. After rebuilding the forks I moved over to the leaking master cylinder under the tank. Not a pretty sight. Anyhow, after search the interwebs for general information about that, I stumbled upon the "switching to handlebar mounted MC"-solution! I bought an old throttle assembly, bad in all the right places, and cut it up. Well, in the middle of that process I stepped back, thinking, of life's inner meaning and my latest.. uhm, mistake? The throttle part of the sliced one is shorter than the one original on the bike. I guess it won't be able to pull the throttle cable as far as the original would..? Am i screwed? ![]() Them things: ![]() That bike: ![]() So, whaddya say, is it a ?
04-08-2013, 12:45 PM
#2 | |
Oddometer: 2,214
Airhead stuff, tools, camping stuff, riding gear for sale/trade. http://www.eskimo.com/~newowl/BMWPARTS.htm |
04-08-2013, 01:04 PM
#3 |
As above, so below
Oddometer: 489
Can't say I've ever seen a throttle cam with a shorter arm like that. You'll need to remove the tops and compare/measure the inner cable channels.
Slash 5 Revive elite-less screwed with this post 04-08-2013 at 01:16 PM |
04-08-2013, 01:20 PM
#4 | |
Oddometer: 4
Plaka: Heres a link for you! http://forum.boxerworks.com/viewtopic.php?f=1&t=5461 |
04-08-2013, 01:50 PM
#5 | |
Knows all - tells some.
Oddometer: 12,889
![]() PS: What's in the boxes?
Remodeling. Please check again later. |
04-08-2013, 01:58 PM
#6 |
Oddometer: 2,214
BTW, from what I can see, that's a special tank. Get it off the petcocks.
04-08-2013, 02:11 PM
#7 |
Windsor NSW
Oddometer: 51
Lever broken off the tip?
whatwouldulike2do.blogspot.com.au |
04-08-2013, 02:22 PM
#8 |
Oddometer: 871
Looks like a generic aftermarket Magura master cylinder and a BMW throttle assemply with the brake cable portion "sliced" off.
No point in worrying about it too much now that the deed is done. ASSUMING you have the carbs and throttle cables, wire it up and make sure the butterflies open all the way to the stops, it should be obvious enough. Note that cams inside the throttle assembly are not all the same. You may wan to use the cam out of your original throttle assembly. Eric
"Good God. Are we going to be assaulted with chrome Sanka cans now? " Dranrab Luap |
04-08-2013, 02:55 PM
#9 | |
Oddometer: 2,214
I really like the paint on the tank in the pic (at the link). Wonder what it is?
04-08-2013, 03:00 PM
#10 |
Horizontally Opposed
Oddometer: 5,294
That would be a 1974 R75/6.....
The shorter cap probably won't work. But you should be able to switch caps to "stretch" the cable correctly. |
04-08-2013, 03:35 PM
#11 |
Oddometer: 118
Tank Stand
04-08-2013, 05:02 PM
#12 | |
Oddometer: 52
When these things get old they get very lumpy. My suggestion would be to test both by assembling them on the handlebar (with cables) and test the feel while applying tension to the cables. You can also measure cable travel at the same time. Go with the smoothest operating one. I replaced the twisty part and the gear and chain part on mine with new parts. This greatly improved things but the wear in the housing is still causing lumpiness, though it's acceptable to me. You will love the new brake. Good luck with it.
Cheers Charlie, and the lovely Brunhilde (74 R90/6) |
04-08-2013, 05:11 PM
#13 | |
Oddometer: 2,214
04-08-2013, 05:12 PM
#14 |
Oddometer: 2,214
A coupla two by fours?
04-08-2013, 05:24 PM
#15 | |
Oddometer: 52
![]() It's matte black Wattyl Killrust Epoxy Enamel, from a rattle can. Not sure if Killrust is available elsewhere than Australia. I baked it by my woodstove between coats, and it is wearing well. Here is the rest of the bike.
