09-27-2012, 05:00 PM
#241 |
clown shoes
I have the Boyer electronic ignition. I may have to wait till Monday to try this balancing. I have family in town. :(
However I ended up trading fr the /6 tank w knee pads. I wanted to get opinions on wether or not the gap between the seat and the tank seem to big. I don't think it is but I often get picky and paranoid. Feel free to share opinions. I'll have to raise the bars a bit as in the current position thy hit the tank. ![]() The gap may actually be ok because the freshly coated Tank will gets scratches from the seat if its too close. I have a new cover for this seat as well as a grab rail coming. I can't find trim prieces so ill use some generic black trim. I'll pinstripe the tank and fenders myself when I get the first coat up. Saw this cat the shop today. Pretty wild. Such a big looking tank and only holds 3.5 gallons. Most of it is for show and the intake system and stuff.
my R90/6 in progress: http://www.advrider.com/forums/showthread.php?t=821078 |
09-27-2012, 07:44 PM
#242 |
clown shoes
the more I look at this tank, and the more black BMW's I see the less I want black. The more its keeps telling me to go raw on the tank. with a nice clear coat. the tank is really straight just really ugly paint job. stripped it think it might work. Maybe I'll strip it saturday and see what it looks like. as long as there is no bondo it could be cool . Maybe raw with black pin stripes? is there a way to maybe strip it to raw then have it get a little surface rust and then keep a little rust here and there then clear it? or is rust like the plague and it will destroy it in the long run? even if its very slight and cleared
Also, under the cap should it have rubber? I'll post pics... . aesthetically I think I have to decide which way to go before i invest a ton of money and decide I don't like it.
09-28-2012, 10:06 AM
#243 |
ShadeTreeExpert
Oddometer: 5,026
As I mentioned before, We used to balance the carbs by lifting the plug caps. This is not allowed any more and a bike that has any after market electronic ignition can blow the ignition module part of the system by lifting the plug caps. You must use the short 4 mm rods on the spark plugs to short each side out in turn to balance the carbs. These rods should be tightened with a wrench because they will vibrate loose if not tight enough.
A too low an idle will cause an oil starved engine. It can ruin the lower end of the engine. A too low an idle will ruin your day. I believe the lowest idle in the book is 6 or 7 hundred. These are quit low. Most riders today have idle set around 1000 on the R90s. Mine is a little below 600 I think. I'll be back.
Never memorize something you can look up. ---Albert Einstein |
09-28-2012, 09:25 PM
#244 |
clown shoes
I went for a little ride today. Just figured it might be nice to run through the gears a bit. Bike ran fine. Steady etc. however I set the idle a little higher before the ride. A couple turns in from zero. I'm not sure if maybe I'm running rich or not but when I went to turn the bike off it wouldn't. It just kept running. Like it was possessed. Maybe I'm running lean? Not sure. I didn't get a chance to balance the carbs yet. As m sure I will take a bit more than 5 minutes for me. Probably an hour or two or three.
I'm just wondering why it kept running after I hit the kill switch and pulled the keys. Lol. I figured the kill switch would end all spark. What gives?
my R90/6 in progress: http://www.advrider.com/forums/showthread.php?t=821078 tete screwed with this post 09-28-2012 at 11:23 PM |
09-28-2012, 10:20 PM
#245 |
ShadeTreeExpert
Oddometer: 5,026
Tete,
You should check to see that the flywheel is properly indexed. There is a mark on the flywheel for TDC. The mark on a BMW is usually OT. Take the spark plugs out. Leave the ignition off for this. Stick a wooden dowel into the plug hole and follow the progress of the piston by feeling the dowel rise as the piston rises. Be careful not to break the wooden stick off in the cylinder or other wise cause any damage. But the piston should be at the top of it's travel anytime the OT mark appears in the timing window. Do not drive this bike any more until you figure out why this strange behavior. I think the engine ignition may be way off and this could be because the flywheel is not properly indexed. If the OT mark on the flywheel corresponds to the piston reaching the top of it's travel then you can recheck the advance and idle timing. The symptom you report of the engine not shutting off sounds like the ignition is Way off. This must be solved before it blows up. Do not run the bike if the exhaust pipes are getting Red Hot.
09-28-2012, 10:57 PM
#246 |
Oddometer: 1,026
Dieseling
Sounds like you're dieseling, i.e. the mixture is igniting without the benefit of spark.
Either your timing is way off, or your ignition actually does not shut off when you turn the ignition off, don't see how though. You mentioned that you're idle screw is turned in two turns from touching the throttle plate. That's a full turn more than what my Bings are set at. Back those screws off to just one turn from touching the throttle plate. Follow disston's advice and verify that OT is OT. A bamboo skewer works well to check the rise of the piston. When you get to TDC, aka OT, you should see that mark in the window. ![]() If you don't, then all your work trying to time the ignition has been for naught. If you can't see that mark then somebody installed your flywheel incorrectly and it needs to be corrected. Kai Ju screwed with this post 09-28-2012 at 11:10 PM |
09-28-2012, 11:22 PM
#247 | |
clown shoes
here is what I did do in the mean time. while the bike was idling I got of the bike and backed off the idle screws. got it idling pretty low and then used the key and the bike turned off. But when I set idle that low the generator light is on. keep in mind the bike starts REALLY REALLY easily. the mixture screw is about 1 full turn out. I figured this is probably a bit rich but since I first leaned it out i'm probably over compensating. Thanks
my R90/6 in progress: http://www.advrider.com/forums/showthread.php?t=821078 tete screwed with this post 09-28-2012 at 11:40 PM |
09-29-2012, 03:39 AM
#248 |
ShadeTreeExpert
Oddometer: 5,026
Leave the mixture screws one turn out. If the carbs are a little rich right now it's fine. The bike will run with the carbs set twice as rich as needed. Too lean will cause problems.
The bike will idle too slow when just started for maybe 10 minutes. It's this time you have to keep it running with the enrichners or the throttle. We balance to carbs for running when they get warmed up but they won't run the same when still cold. Yes, suspect the flywheel is not mounted correctly. Must check. Wooden dowel or bamboo skewer. It's also possible the advance unit is not returning to idle and this is causing the engine to race and be too far advanced. You need to use the timing light to check advance at 2,500, 3,000 rpm. And verify the timing is going back to idle when the idle comes down. I think you did buy a timing light. But I suspect you have been setting timing with the trouble light at idle since you learned that trick. You have to learn a few more tricks to get this thing right. The red light for the charging system will come on at idle. It is normal for the red light to be on when the engine is at idle. It will go off at about 1300 or 1500 rpm. That's normal. It is not a problem for the red light to be on when sitting in traffic. A good battery has enough electricity to run the system for quite awhile with the red light on. And then the battery gets recharged when you raise the rpm. The yellow light for oil pressure should not come on at idle. It should never be on if the engine is running. The yellow light should not flicker when at idle. From the settings given for the carbs only small adjustments should be made. When trying to balance carbs the engine should not be over heated. If the pipes get red hot turn the engine off and let it cool. If you have a big box fan place it in front of the engine when balancing the carbs to prevent this problem. I have to go to work now. Good Luck. Just think. only a couple of days ago this thing would not start or run or anything. Now it can go around the block. Progress.
09-29-2012, 12:45 PM
#249 |
clown shoes
Ok it does look to be at TDC so at least we are good there. Must set timing them. Looks to be way off.
I'll go through the instructions from Boyer once again. Use my timing light and try to get the advance correct. Here is where I am at on the stator plate ![]() And after looking at this pic,it lookalike I need to advance it? This oils mean turning the plate counter clockwise I believe. And the making sure at higher rpm that its flashes an F at the timing hole.
09-29-2012, 01:08 PM
#250 |
clown shoes
Here is a pic of my plug
![]() Gapped correctly. I generally tighten them down a hair past hand tightened. I'm wondering if I'm in far enough. To paranoid to find out.
09-29-2012, 01:18 PM
#251 |
clown shoes
Here is what it looks like w the timing light
![]() Just above the mark should I retard it a bit meaning turn the plate clockwise?
09-29-2012, 01:34 PM
#252 |
clown shoes
The bike feels really good. It doesn't feel like its dieseling. It's not getting anywhere near red hot at the exhaust. Seems about right, the way it's running. No back fires, just really smooth powerband. The idles hit low enough for the generator light to flash a bit NO oil light flashing EVER , NONE what so ever. Just feels really good. Idles low. Feels like I could ride it coast to coast.
BUT when I turn it off it just won't turn off. Neither key or kill. Kinda driving me nuts cause again I feel like the bike is dialed in OK , maybe not spot on but I feel like we are close. That being said I have to stall Otto turn it off. I read a bit up on dieseling ANSI don't believe this I the case. I checked the spark and we are good there and re-gapped.
09-29-2012, 01:56 PM
#253 |
Oddometer: 1,026
Won't turn off
Leave your timing light hooked up when you turn the key off.
If it continues to flash than your ignition switch is not doing it's job and you have your Boyer connected to an always hot lead. Needs to be powered by a switched lead. If it does stop flashing you're dieseling, but I'm tempted to say that your Boyer may be hooked up wrong. BTW, that plug looks great which reinforces my suspicion that the Boyer is hooked up wrong. |
09-29-2012, 02:01 PM
#254 |
ShadeTreeExpert
Oddometer: 5,026
The plug looks a little lean. You should open the plugs, turn them out, each, another 1/4 turn. They are going to look mostly white because it's the way today's gas burns.But it would be better to have them a little black, then you can turn in a little. Too rich is not as bad as too lean.
The timing is two degrees too far advanced. Is your picture of the timing window with the rpm raised? If so you should retard timing so the F is not above the arrow. OK, It's 1 degree off. Not bad. If this is at speed, not idle. If this is idle you are off by almost 20 degrees. You probably need a tachometer so you can know what the rpms are. If the pipes are getting red hot when you ride it, something is wrong. The pipes get hot, hot enough to burn but they shouldn't "glow". You should try to hook up with another Airhead close to you or even better a Tech Day where there are several experienced gear heads. From here I'm out of ideas. The bike didn't have this problem of not turning off before you installed the Boyer? Did it? This is why we want you to fix the OEM system before adding such stuff. It appears the Boyer is hard wired to positive. You turn the rest of the electricity off and on with the key but the coils might be hot all the time. With the key off. Take the gas tank off. With the test light grounded at the clip, touch the pointed end to the outer terminal of the right hand coil. If key is off the light should not glow, if it does, the coils are hot.
09-29-2012, 02:19 PM
#255 | |
clown shoes
I was thinking the same thing about the coils still being hot etc.. maybe I wired something wrong etc.. I'll do as suggested in the morning. I also plan on setting the valves again once the timing is dead on. I'll make a mention on my boyer install thread , perhaps someone else has had this same issue. I'm really excited about how well its running. I WENT FROM NOT BEING ABLE TO START THIS BIKE - NOW I CAN'T TURN IT OFF? such is life.
